04-15-2019, 10:11 AM | #1 |
Rep 3,506
Key Card and Cell Phone Question
I'm looking to just clear up a couple questions. My searches got me more confused and my car doesn't help either.
X5 Currently unable to use anything but a Samsung phone to use the phone as a Key? My X5 did not come with the Card that sits in the charging spot. Does this mean my X5 is missing the ability to use this? If so what exact option am I missing?
2022 M8 Comp Convertible
04-15-2019, 10:32 AM | #2 | |
Rep 976
Key card should have come with your car, ask your dealer about it! Your X5 still has the feature unless you don't have comfort access package/feature which I doubt. |
04-15-2019, 10:38 AM | #3 | |
Rep 3,506
Network should have nothing to do with it since its using near field transmission that is a standard industry. I'm guessing it would be on the part of how the phone OEM communicates software to hardware than..... Bummer I have a pixel 2.
04-15-2019, 10:44 AM | #4 | |
Rep 579
04-15-2019, 12:46 PM | #5 | |
Big Beaver Smile
2101
Rep 3,791
You just need comfort access wireless charging.
04-15-2019, 02:02 PM | #6 |
2019 X5 40i
115
Rep 226
I have an iphone x , with sprint service and my car has comfort acess
dealer gave me the key card at the time of delivery I can use, bmw connected app to unlock the car.. then I have to keep the key card on the charging tray in center console, i can then start and drive without the physical key... Tested above with BMW Genius and it works well... |
04-15-2019, 02:36 PM | #7 | |
Rep 533
04-15-2019, 03:45 PM | #9 |
Rep 74
Wish this process worked better and had widespread deployment
I also have a November build with comfort access, my X5 was delivered without a key card. I've spoken with BMW National Genius support, local genius and my local service manager; there is supposed to be a program in place "soon" that will provide a complimentary key cards to those early build vehicles delivered w/o out it.
In the meantime it's my understanding that digital keys can be installed in some Samsung phones but not on those on Verizon. For some reason Verizon is blocking NFC (Near Field Communications). I purchased an "unlocked" Samsung Galaxy S9+ directly from Samsung and then installed a Verizon SIM; I was curious if I could get it to work as it was not a totally Verizon version. My results are a little mixed, in that I can start the car but not unlock the doors using phone, however I can still use the app to unlock the doors but that a bit slow, and potentially a bit risky as I'd be counting on BMW's connected services to be working - so far I always still carry my keys. *** Update 4/29/2019 *** I traded in the Samsung S9+ for an S10+ purchasing an unlocked phone direct from Samsung and then added a Verizon SIM card; I am now able to open the doors and start the car using the NFC capabilities of the Digital key installed in the phone It's worth noting that BMW is selling this capability as a "subscription service" complimentary for the first twelve months but at a cost after your one year delivery anniversary. Sure would hate to get locked out of my car with an expired subscription, it will be interesting to see how this works. Your dealerships service department will need to help with the initial steps, my local dealer was not familiar with the process but I had these instructions and a service advisor completed the steps detailed below: The customer will need the following to accomplish this: Last edited by ddelX52019G05; 04-29-2019 at 02:46 PM.. Reason: updated info |
BayAreaBimmers359.50 rdrcontact12.00 |
04-15-2019, 08:47 PM | #10 | |
Rep 162
Drives: 2019 BMW X5; 2017 Audi Q7
04-16-2019, 06:32 PM | #11 | |
Rep 74
04-16-2019, 07:34 PM | #12 | ||
Rep 251
04-16-2019, 10:35 PM | #13 |
Rep 429
I had a new key card ordered for my car but it still doesnt work ..dealer said these things aren't working yet.
Same with the connected app..installed the app on my phone created an acct etc..then when it asks to enter code received in car under messages i get nothing. No code. So net net neither the key card nor the app work for me at all. Where do i go from here any tips? |
04-16-2019, 11:01 PM | #14 | |
Rep 251
Also apparently there is a password issue if you set up the account from the app. The password protocol on the app lets you have a simple password like Hello1, whereas that is not sufficient for the protocol on the website and appare tly causes issues. At least this is according to another member on here. Make sure you have a complex password with at least one capital, a digit and a symbol. |
04-17-2019, 08:41 AM | #15 | |
Rep 74
Ask the service advisor to complete Step 1 outlined above and below with the service department. (My dealership service advisors at first did not understand the steps they needed to take; "ConnectedDrive Service Cockpit" appears within the service advisors view, the genius did not have the same view) Step 1 You'll need to establish a PIN code with dealerships help: "The Service Department will then open up ConnectedDrive Service Cockpit and verify all the information is correct and have the customer set up a Pin. This Pin will be used to set up their Smart Phone Digital Key or if they would like to add other Smart Phone Digital Keys." For the phone app I needed to logout of the Connected Drive App and log back in, it was at that point the app prompted me to authorize a download of the digital key, it then took a few minutes and a number of failed attempts to get the car to recognize the phone with the digital key, but I finally got it to work. I don't yet have a key card so not sure how the steps might differ for the key card, but I suspect being on the most recent software version should help. |
04-17-2019, 08:48 AM | #16 |
Rep 74
Huh that's interesting, wish my version did that. Hopefully they'll be able to make remote start and ventilation available across all carriers, countries and phones soon. I did see another post where a Galaxy S10 user on TMobile was noting added features between the S10 over the S9+.
06-03-2019, 09:22 AM | #17 | |
Rep 7
I have a Samsung galaxy S10+ ATT device and dealership has setup pin but my device won't go to install screen for digital key. Been week since dragnet activated in their service cockpit portal. Very frustrating to say least. Anyone else having similar issues or have a solution. No one from BMW knows how to fix.
06-03-2019, 01:11 PM | #18 |
Retired soccer mom
252
Rep 937
Drives: x5 40i 2019
Garage List 1998 Jeep Cherokee ... [0.00]
2011 Toyota Highlander [0.00] 1998 Plymouth voyager [0.00] 2019 X5 40i [0.00] |
This is what my dealer told me: each car comes with the two key fobs and a digital key.
I have also read somewhere that you can have ONE functioning digital key, so if are using the digital key with your non-Apple phone, the key card will be disabled. So if you are trying to use both, you probably will have issues. Yes, dealer has to register your digital key. I’m picking my car up Wednesday, and plan to spend as long as it takes for them to activate the digital key and connected drive. And help me set up profile and settings. |
06-03-2019, 01:38 PM | #19 | |
Rep 976
06-03-2019, 01:49 PM | #20 | |
Rep 177
This is how I'm using it too, except it doesn't make much sense to me to have to unlock the car with the connected app. I want to use the card when I don't have my fob or phone but I can't do that. The card will not unlock the car. FWIW, first delivery Nov 2018 - no digital key. They never even told me about it. Took second delivery last week and it has a card. |
06-04-2019, 12:20 AM | #21 |
Rep 7
Does anyone know a fix to this? Or why this is happening?
06-04-2019, 03:34 AM | #22 | |
Rep 251
