06-18-2019, 11:47 AM | #1 |
Rep 602
Lane Change Assist
I think this has been covered elsewhere but I am unable to find it. Has anyone gotten their X5 to change lanes for them. I’ve tried holding the signal stalk in the direction I want to turn but no matter how long I wait or how big an opening, it never changes lanes. I’ve got the traffic assist professional package and all the other driving aids but it seems not to be working.
06-18-2019, 12:00 PM | #2 |
Rep 668
Yes, I use it all the time. Are you pushing it past the point of resistance so that the stalk stays down or up? Or are you holding it just before the point of resistance? It only works in the latter case.
Also, you have to have cruise control engaged with drive assist active. You also have to be going above a certain speed. |
06-18-2019, 12:08 PM | #3 | |
Rep 602
06-18-2019, 12:12 PM | #5 |
Rep 602
I think you get a graphic pop up if it’s going to change for you? Something with a car and arrow showing the direction the assist will be going. Saw it in a video, just never been able to replicate.
06-18-2019, 12:41 PM | #6 |
Rep 214
It seems to work only when your cruise control is set to steering & lane assist. Which is when you have to hold your hand on the wheel, you have the active cruise control set, and the green lane markers lit up. It also works above a certain speed. I think 40mph is the minimum. It does NOT work when cruise control mode is active traffic assist. If you turn on the blinker, it will just cancel the active traffic assist and revert to steering & lane assist.
Once these are satisfied, you just push it up to the point of resistance and HOLD it. After 2-3 seconds (it checks if everything is clear) it will show the lane as gray, and a green arrow over it, then the car will start moving. You are still advised to hold the steering wheel while this is happening. Once the car starts moving you can let go of the stock.
Current: 2019 G05 x5 50i M-Sport
Past: 2016 F10 550i M-Sport ~ 2015 F83 M4 Convertible ~ 2013 F30 335i M-Sport ~ 2006 E85 Z4 30i |
06-18-2019, 12:59 PM | #9 |
Rep 602
Those are all showing during my many attempts. I guess I’ll just have to bring it up with the dealer next time I’m there. It sounds like I’m doing it correctly.
06-18-2019, 01:28 PM | #10 | |
Rep 127
06-18-2019, 01:37 PM | #11 |
Rep 284
06-18-2019, 02:13 PM | #12 |
Rep 165
Drives: 2019 BMW X5; 2017 Audi Q7
Check your setting. The auto change lane feature can be turned on and off separately from everything else.
06-18-2019, 05:05 PM | #13 |
Rep 602
It was turned on already. I did finally get it to work today. There was hardly any traffic around when it decided to work. You could have fit three 18 wheelers with 53’ trailers in the space I had. That seems to be the issue; it ignores perfectly acceptable opportunities to change lanes. So it seems this truck drives like an old women!
I’m seeing a pattern here. Doesn’t see openings for lane changes and doesn’t see parking spots. |
06-18-2019, 05:36 PM | #14 |
Rep 602
My other thought is that I tend to unconsciously let go of the wheel when I’m trying to get it to do the lane change. Maybe I would have more success if I consciously made an effort to hold onto the wheel during the process?
06-18-2019, 06:06 PM | #15 |
13262
Rep 19,783
I usually let go also to hold the turn signal on and I have never had it not make the lane change. It will just flash the yellow "put your hands on the wheel" warning.
06-19-2019, 02:53 AM | #17 |
210
Rep 323
Drives: BMW X5 G05 30d/BMW M5 F90 Comp
I can't do it either. Does it work in Australia, or USA only?
06-19-2019, 06:44 AM | #22 |
Rep 5,324
I really like how smooth the lane change works. I use it on long trips. It really makes you feel it’s autonomous driving to the next level. When passing a slower vehicle with acc on, a slight hold on the turn signal stalk and the system evaluates the entire area and proceeds to move over and around the car in front of you. It’s kinda spooky the first few times you use it as you feel the X5 might keep moving left off the road but it never does. The entire motion is smooth and seamless. Your passengers will never know you are not driving.
This has a “Geewhiz” factor of about 11 on the scale of 10. It will either blow the minds or terrify your passengers when you first demonstrate it. |
