09-27-2019, 09:52 AM | #1 |
Rep 4,503
Drives: 2022 iX xDrive50, DGM
Hood Adjustment
Anyone know if there is an (easy) way to adjust the hood position? My spouse's Bimmer hood is about 1/4" (yes, OCD) off center when closed. Not readily apparent, but when you notice can't be unseen. Or dealer?
09-27-2019, 09:56 AM | #2 |
Rep 3,507
I've seen to many mistakes doing this in the past.... Go to the dealer they shouldn't charge much at all and probably can find WHY its not aligned. Just my thoughts..
2022 M8 Comp Convertible
09-27-2019, 09:58 AM | #3 |
Rep 4,503
Good advice - don't see anything like an adjustment screw under the hood.... Looked at several others and haven't seen it repeated.
09-27-2019, 09:58 AM | #4 |
13251
Rep 19,765
A 1/4" is actually quite a bit given the normal seam is fairly small. I wonder how it even closes without hitting something. Why fool around with it, it is brand new so let the dealer handle it.
09-27-2019, 10:17 AM | #5 |
Rep 506
When you say the hood is off-center by about 1/4" do you mean the difference in the gaps on either side is 1/4"? The overall gap on my hood is uniform and about 1/8".
That is something better fixed by the dealer. BTW don't look at the folded mirrors... driver folds different amount than the passenger side. |
09-27-2019, 10:24 AM | #6 |
13251
Rep 19,765
09-27-2019, 10:39 AM | #7 |
Rep 4,503
Hard to tell with all the shiny, but probably more obvious is the front gap, right and left:
09-27-2019, 10:49 AM | #8 |
Rep 4,503
Hard to get a perfect 90 degree shot, but this may be a little closer:
09-27-2019, 11:09 AM | #10 |
Rep 4,331
IF the hood is off center due to the hinges, they are a loooong way away from the snout so even a tiny, tiny adjustment at the hinges will have a huge impact at the snout. I'd just have the dealer do it, they screw it up, they pay for it.
Could it also be that the receiving latch is pulling it to one side? Meaning that maybe the hood is centered until it latches. Close it to just before the point of latching and see if you can tell. If it looks good, slowly bring it down to the latch and latch it and see what happens. Either way, with the small gaps of todays hoods, any misalignment could be crunching the hood against the fenders and sending paint chips flying. |
09-27-2019, 11:30 AM | #11 |
Rep 4,503
It actually looks like it partially straightened itself after several closings (I notice you need to slam these pretty vigorously), but still off as pictured. It was a LOT more canted when we picked it up. Back to the dealer for ceramic and PPF, so will address....
On a separate note, my passenger side tailpipe looked like they dropped it off the pallet, so one side is partially flattened on the end instead of oval. Currently in for the same exterior treatment, so will ask about that. I'm assuming fairly simple straightening on a mandrel, or just replacement of the end (looked like it was a short run). If that's all I find, I'll call it good. Q7s required a deal more freshening up when received. |
09-27-2019, 11:37 AM | #12 | |
Rep 4,331
09-27-2019, 12:02 PM | #13 |
Rep 4,503
Spouse's are both uniformly oval, and the damaged side on mine has clearly been scraped as well as flattened. Don't have pics yet, but will post. Looks like an easy fix, but it is BMW....
09-27-2019, 12:21 PM | #14 | ||
Rep 4,331
09-27-2019, 01:08 PM | #15 | |
Rep 4,503
Spouse Left Spouse Right Loaner Left Loaner Right |
09-30-2019, 08:06 PM | #16 |
Rep 4,503
Aaaaand, the pipes on my newly-delivered 40i:
Left Right |
09-30-2019, 08:12 PM | #17 |
Rep 4,331
[QUOTE=Paladin1;25301535]Aaaaand, the pipes on my newly-delivered 40i:
Wow, that had to be that way before assembly, as least that is how it appears to me. If it were my car, I'd fix it myself. |
09-30-2019, 08:21 PM | #18 | |
Rep 4,503
[QUOTE=Marty in Bgm;25301557]
If I had a mandrel or a form big enough, I'd probably try. Problematic though with the pipe still attached, and I'm leery of whacking on the tailpipe (it's actually pretty substantial metal) and then having the dealer tell me not their responsibility.... |
10-01-2019, 05:35 AM | #19 |
Rep 506
My goodness, that's more than an aesthetic fault! Whatever bent it must have whacked or sat on it pretty hard; that is heavy-duty metal, not tin foil. Have you checked underneath to see if the rest of the pipe is damaged?
What did the dealer mean by "not their responsibility". Aren't they going to repair it? On the other hand, if the dealer repairs it, they might just flatten the one on the driver's side [QUOTE=Paladin1;25301586] |
10-01-2019, 06:53 AM | #20 | |
Rep 4,331
Go to Auto Zone or Advanced Auto, they let you borrow tools and get their expanding mandrel kit made for exhaust pipes and get your tailpipe back to normal. Looks like the one in this video.. .. https://www.youtube.com/watch?v=zcz6CSVmxQU |
Paladin15556.00 |
10-01-2019, 08:22 AM | #21 | |
Rep 4,503
[QUOTE=Marty in Bgm;25301857]
10-01-2019, 02:35 PM | #22 | |
13251
Rep 19,765
"I'm leery of whacking on the tailpipe (it's actually pretty substantial metal) and then having the dealer tell me not their responsibility" |
