10-24-2019, 03:53 PM | #3 |
Rep 28
10-24-2019, 04:02 PM | #4 |
1051
Rep 1,951
It sounds like it's clicking into place after you go from sport mode into park - it moved the selector automatically back to the standard position, clicking into place. I don't see an issue here.
10-24-2019, 04:52 PM | #6 |
Rep 903
10-24-2019, 04:57 PM | #7 |
Rep 3,411
Your 428 does it too. Moving the lever to the left puts the transmission in Sport Mode. You can still let it shift automatically if you want, but can also select gears manually. Chosing this mode wakes up the car. Go try it and you will see. When you hit the stop button, the gear shift moves automatically back to the right position. The G05 X5 does the same thing. Go try it and report back. |
10-24-2019, 04:58 PM | #8 |
Rep 3,411
Your 428 does it too. Moving the lever to the left puts the transmission in Sport Mode. You can still let it shift automatically if you want, but can also select gears manually. Choosing this mode wakes up the car. Go try it and you will see. When you hit the stop button, the gear shift moves automatically back to the right position. The G05 X5 does the same thing. Go try it and report back. |
dream54ing485.50 |
10-24-2019, 08:23 PM | #9 |
Rep 3,919
10-24-2019, 09:09 PM | #10 |
Rep 158
The gear shifter is motorized in the G05, so switching to Park from Sport mode (shifter in the M/S position/pushed toward the driver) prompts the motor to activate for the shifter to return to its original position. This was previously non-motorized in prior model years, so the noise was much louder and more mechanical.
10-31-2019, 01:13 PM | #12 |
Member
55
Rep 92
My 2019 does not make a pronounced sound either.
Past BMWs:
2015 F82 M4 6MT/2013 535i xDrive/2005 325ci/ 2001 X5 4.4 Sport/2000 Z4/1998 528i/1995 525i 5MT/1994 318i |
