10-28-2019, 05:01 PM | #1 |
11
Rep 36
The worst part of the car - dirty door jambs
Does anyone know why BMW won't make doors that cover the lower door frame? It gets dirty after a drive in the wet, unless you are taller than average then your pants will inevitable rub on it when getting in/out of the car.
[IMG]https://share.getcloudapp.com/4gu7P0AY[/IMG] This is one of the worst part of an otherwise very satisfying vehicle. |
10-28-2019, 05:25 PM | #4 |
Rep 4,331
10-28-2019, 10:50 PM | #6 |
Rep 4,503
Drives: 2022 iX xDrive50, DGM
Or just buy an Audi. There are a few downsides to that approach though...
10-29-2019, 06:00 AM | #7 | |
11
Rep 36
I have owned 4 cars (Honda, Nissan, Mercedes, Ford), and never had this issue. |
10-29-2019, 06:28 AM | #9 |
Rep 195
When I was getting quotes for PPF and Ceramic Coating these areas were recommended to get protected, the PPF would prevent scratches and the Ceramic Coating should keep the muck off.
G05 X5 M50D - Carbon Black - Tech Pack - Comfort Pack - Sky Lounge - Individual Merino Leather
10-29-2019, 06:36 AM | #10 |
Rep 124
It is definitely a bad design and one BMW has not thought through.
I am still trying to work out how to wash the inside door area - it is a PITA. Any clues how to do this properly? |
10-29-2019, 07:08 AM | #11 |
Rep 5,323
The doors have to drain so a flap over that area is a bad idea. I have had rust issues with Audis in the past because of this. What happens with Audi door seal/flap is you get rust where the flap meets the door so that idea isn’t a good one.
I wax and detail that area and it helps a lot. This is not a new issue and is very common with cars from BMW, Porsche, etc.... Make sure you clean around the doors regularly and you won’t get heavy dirt draining on the sills. Use a detail spray and towel over the sills after you wash your car and it will that area immaculate. I have had to do this for decades with Porsche. |
