11-14-2019, 11:54 AM | #1 |
Rep 62
Premature wear on front tires 22"
was wondering if anyone has experienced premature wear on front 22" Continental tires?
My car is only 10K kms and the tires have worn about half of the tread and also show excessive wear on the top of the sidewalls. Any input is greatly appreciated |
11-14-2019, 01:06 PM | #2 |
1053
Rep 1,952
It's going to be hard to gauge whether or not this is excessive. So much of this depends on driving style. If you routinely take turns at 70 km/h, you're going to see those tires wear a lot faster.
With that being said, 10k km at 50% wear does seem pretty excessive. I would guess with UHP summer tires you should get at least 20k miles, or 33k km. |
11-16-2019, 09:42 AM | #6 |
Rep 5,728
Drives: '24 iX50; '23 i4 M50
What psi are you running?
Ever require an alignment?
'24-I20 iX 50; '23-G26 i4 M50; '22-G82 M4Cx*;20-G05 M50i*; '20-F82 M4CS*; '18-F80 M3CS*; '18-F80 M3CS*; '18-F85 X5M*; '18-G01 X3M40i*; '18-F80 M3ZCP*; '17-F80 M3ZCP*; '15-F15 X5*; '15-F82 M4*; '12-E92 335is*; '11-E70 X5d; '11-E89 Z435is*;'09-E89 Z435i*; '08-E92 335i*; '06-E90 330i*; '05-E83 X3*; '04-E83 X3*; '03-E46 325Ci* *retired |
11-16-2019, 09:44 AM | #7 |
Rep 106
I replaced mine at 16k and they appeared just the same. I did not put Continentals back on though, went with the Pirelli P Zero's. The ride quality and handling is much better. Plus the Pirelli's also have a tire bead that somewhat protects the wheel.
11-16-2019, 10:15 AM | #8 |
Rep 4,246
I'd have an alignment check - definitely looks like to much positive camber. It's odd how much the shoulder treads is raised compared to the middle.
11-16-2019, 12:20 PM | #11 | |
Rep 62
Still doesn't make any sense that it should be out with only 10K kms and given the fact that I only drive on paved roads and very carefully. Unless it came unaligned from the factory. But you know, as usual the dealer says the wear is normal. Will update after I put it on the alignment bench next week. |
11-17-2019, 01:15 AM | #13 |
Rep 565
Of course it could come unaligned from the factory. I would not trust dealer to do / check alignment. BMW specs are very wide. Do your research what the target specs are and go to reputable shop with proper equipment.
11-18-2019, 07:24 PM | #15 |
Rep 6,121
I drive pretty damn hard and my tires have 0 abnormal wear. I don't have 22's just the baby 21's I'll take pics when I get back home later this week
11-21-2019, 11:11 AM | #16 |
Rep 62
UPDATE!
just came from the dealer and put it on the alignment bench and all measurements are OK within limits. Can anyone with 22's tell me what psi's are you using on the tires. According to the door plate it should use 32 in the fronts and 34 on the backs with light loads which seems too low to me and that will worsen the wear on the front tires shoulders. Appreciate any inputs on the tire pressures and how the wear is behaving on the fronts |
11-21-2019, 11:22 AM | #17 |
Rep 5,728
We've been debating the ideal 22" psi for low load (driver/passenger) over in the wheel/tire subforum.
39/45 (albeit full load, up to 100. Our door sticker/manual doesn't provide a psi for low load) is what is recommended for my US-spec 2020 M50i, which I find is too high, but I have yet to lower it. Was thinking of going 36/42 https://g05.bimmerpost.com/forums/sh....php?t=1669914 https://g05.bimmerpost.com/forums/sh....php?t=1668176
11-21-2019, 04:23 PM | #18 | |
Rep 62
11-21-2019, 04:32 PM | #19 | |
Rep 62
11-21-2019, 05:21 PM | #20 |
Rep 5,728
I thought you were already running 35/37 and still ended up with that front wear?
11-22-2019, 07:22 AM | #21 |
Rep 62
11-22-2019, 08:19 AM | #22 |
1053
Rep 1,952
I can't imagine the difference between running 32 and 35 would cause this extreme wear. When tires are under inflated you see excess wear on the outside treads, but on both sides (inside and outside). Is that the case for you? I always thought this type of wear happens when tires are severely under inflated - like running 25 PSI for a long time.
I'm running 20" Contis on my ML and have them at or close to 40psi - tire shows 50psi max. |
