11-22-2019, 11:35 AM | #23 | |
Rep 62
11-22-2019, 12:06 PM | #24 | ||
1053
Rep 1,952
11-22-2019, 07:52 PM | #25 |
Rep 810
Sounds like a camber issue, and pressure issue - maybe both from the factory.
I run mine at 34/36; remembering I've only got 20" (744 Ms), but in my experience running tyres down at the low end you give a softer ride, a little extra grip (since there's more tyre surface on the road) and your tyres last longer. Not sure why anyone wants to run up at 40psi or beyond?? Tyre wear can get really bad, and you end up with a hard ride - especially with low profile tyres in the 21" and 22". Also, running tyres at high psi also makes you more susceptible to picking up nails/screws or anything else that can give you a puncture. The only time I run higher is when I do long towing trips, and by higher I mean 36/38-39, still dont go into the 40s. |
11-23-2019, 12:04 AM | #26 |
24
Rep 34
I’m very interest, i have to take the decision if 22 or 21 next week, are the 22 premature wear or its just this case ?
I prefer the design of 22, but if only are good for 10,000km I’m out for 22 Thank you. |
11-23-2019, 08:14 AM | #27 |
Rep 2,699
Drives: 23 X5MC
Assuming alignment and tire pressure are within spec, in an all wheel drive vehicle the front tires tend to wear down faster due to more friction. Any spirited driving would accelerate the wear.
11-23-2019, 08:22 AM | #28 | |
Rep 62
12-05-2019, 09:36 AM | #29 | |
Rep 1,208
i've got a 40i with 21s all around (all season run flats) and noticed some early wear on the fronts, outside only. sure it could need alignment, but isn't it just as likely a function of the mass of this vehicle and the fact i toss it around a bit? |
12-05-2019, 10:00 AM | #30 | ||
Rep 2,699
Drives: 23 X5MC
ppagiga660.00 |
12-05-2019, 10:36 AM | #31 |
Rep 236
I’m having exactly the same issue on the 22 contis and only done 2500 miles from new!! Was running at 32/35 as per door plate in the UK for the 30D M sport. The dealer looked and said to up the psi so im now at 35/39
Ill see in another 2000 miles how it looks but it appears as if understating the psi is happening on a few models according to the dealer feedback. The outerwear on the shoulder is on both sides of the tyres though. |
12-05-2019, 10:57 AM | #32 |
Rep 90
The manual on my X5 40i for my 22” wheels states for my front 275/35R should be 38 psi while my rear 315/30R should be 45psi for up to 100 MPH. I have Continentals.
Don’t understand why dealers are stating lower PSI’s? I would have thought the manual and the same reading on the door would be the correct PSI? |
12-05-2019, 11:51 AM | #33 | |
Rep 5,728
Drives: '24 iX50; '23 i4 M50
So are you running 38/45? Any premature wear on the Contis, and how many miles? FWIW: Here is the M50i psi recommendations (full load) under 100 mph. There's nothing noted for light loads however:
'24-I20 iX 50; '23-G26 i4 M50; '22-G82 M4Cx*;20-G05 M50i*; '20-F82 M4CS*; '18-F80 M3CS*; '18-F80 M3CS*; '18-F85 X5M*; '18-G01 X3M40i*; '18-F80 M3ZCP*; '17-F80 M3ZCP*; '15-F15 X5*; '15-F82 M4*; '12-E92 335is*; '11-E70 X5d; '11-E89 Z435is*;'09-E89 Z435i*; '08-E92 335i*; '06-E90 330i*; '05-E83 X3*; '04-E83 X3*; '03-E46 325Ci* *retired |
12-05-2019, 12:31 PM | #34 |
Rep 90
Sorry I can’t help with mileage since my X5 is only two weeks old, with 200 miles on it. Your chart shows the 38/45 PSI that I set mine at. I have my own pump and my trusty gage to confirm correct PSI.
10-25-2020, 09:12 PM | #35 |
91
Rep 306
I have same problem with my front tires. 3 months I paid dealer to do alignment. Now the right tires need to be replace. Should I take it to dealer have them look at it or just replace front 2 tires?
10-26-2020, 12:39 AM | #36 |
Rep 6,796
If I read the spec correctly, those are summer, high performance tires that tend to be soft and sticky...they also are geared very much towards maximum traction than longevity.
If you're in the USA or have a tire sourced for the US, the tire will have a three digit number on it, maybe something like 240 with some letters to indicate traction and temperature for the tire designation after the size. That's the estimated percentage of a 'standard' tire. That would represent 240% of the standard tire's life. It's a good relative guide, but your results will easily vary from that 'standard'. Tires sold for European delivery (and maybe other markets) will have a different designation. The Continental website didn't seem to say what that value was, and the US market doesn't seem to get that model. It seems like the recommended pressure for the 22" tires is higher than you indicated...that would partially account for the greater wear on the outsides of the tread. |
10-27-2020, 05:01 AM | #37 |
Rep 583
Drives: F10 535i, M2 LCI, G05 X5 40i
I'm running the same tire and pretty sure the manual recommends higher pressures. I would up them to around 38 front.
The X5 isn't a light car! |
10-27-2020, 08:53 AM | #38 |
Rep 5,196
low tyre pressure.
with it being a heavy car with thin sidewall the sidewall will prop up the car greatly when cornering steering etc and hence the wear. If manufacturers recommended a higher tyre pressure tyre life will improve but ride will be stiffer and the manufacturers Don't want that. I would up the psi by 10%all around ride might get a tad harsher but car will drive better. The above is the conclusion I reached when my front tyres outer shoulder wore faster on both my cars and ive gone with 10%over recommended. |
10-27-2020, 08:56 AM | #39 |
1053
Rep 1,952
when I go into iDrive to see what it recommends for my 22" tires it shows 42 front 45 rear - this takes into account the temperature of the tire, so it varies. but after about 5 minutes of driving that's what it constantly has been showing me.
10-27-2020, 09:09 AM | #41 |
91
Rep 306
Did you put 42 psi on the front and 45 in the rear?
10-28-2020, 06:51 AM | #43 |
Rep 136
I'm looking @ the P ZERO ALL SEASON Ultra High Performance All-Season tires and they're saying they have a 50k tread coverage warranty - does that mean if they experience "premature" wear they will be replaced?
Tires https://www.tirerack.com/tires/tires...0Sport%20Brake Warranty https://d3nv2arudvw7ln.cloudfront.ne...erWarranty.pdf |
