12-14-2019, 03:11 PM | #1 |
Rep 106
X5 sDrive or xDrive?
I live in the flat south where it never snows and I am looking at getting the sDrive. Almost all of my driving is city. Would there be any great advantage of getting the xDrive?
Thanks. |
12-14-2019, 03:20 PM | #2 |
Rep 1,136
See this thread. I asked the same question as I’m in the south as well and ended up ordering xdrive. General consensus is that xdrive should still be ordered for the added traction not just for snow but for the rain as well.
https://g05.bimmerpost.com/forums/sh...ghlight=Sdrive |
12-14-2019, 08:31 PM | #5 |
Rep 4,502
Drives: 2022 iX xDrive50, DGM
AWD does improve traction, acceleration and towing in slippery conditions, rain or snow. It's been suggested it improves braking as well, although I'm guessing that's an "it depends" answer, and certainly with normal emergency braking and all 4 wheels locked, whether 2WD, AWD or 4WD makes not a particle of difference, except a 4WD or AWD may be slightly heavier and therefore have a slightly longer stopping distance. There are also minuses to AWD. Edmunds' take:
https://www.edmunds.com/car-buying/d...drive-car.html Last edited by Paladin1; 12-14-2019 at 10:08 PM.. |
12-14-2019, 09:59 PM | #6 |
134
Rep 326
With all due respect, totally disagree. Exceptionally different to have xDrive VS sDrive on wet roads, especially in the south where it doesn't rain a lot. You'll not be dealing with just water but also all the oil and grime on the road mixed in with the rain. After having experienced both, it's a no-brainer for every car I have the choice
12-15-2019, 07:17 AM | #7 | |
1053
Rep 1,952
Is the sDrive a death trap? No, absolutely not. I've been driving a RWD ML350 for years and I was able to make it through unscathed. Will the xDrive be noticeably better? No question it will. |
12-15-2019, 11:29 AM | #8 |
150
Rep 365
12-15-2019, 12:43 PM | #9 |
Rep 672
I've had both and I don't notice a difference at all in the rain. If you live in the south skip the X drive and put that money to other options.
12-15-2019, 06:36 PM | #11 | |
13238
Rep 19,728
That is correct, AWD doesn't effect handling in the rain it is for traction during acceleration. The biggest problem about driving in the rain is hydroplaning and there is nothing about AWD that will counteract that since it is a function of the tires and road surface. Some argue it is actually more dangerous since people think it will help them in situations it is not designed to. "However, my experience—hard-earned from wrecking more than one AWD vehicle during snow-handling tests for a tire company—is that AWD is counter-productive when the roads are slick. At the same time AWD doesn't improve your handling, it does offer an overly optimistic sense of available traction, and it provides the potential to be going so much faster when you need to stop. (Note to those from warm climes: Snowbanks are not puffy and cushiony.) The laws of physics mean a vehicle's cornering power is the job of the tires and suspension." . . . "Some disagree, saying AWD helps bad-weather handling because it quells power on oversteer, the fishtailing rear-drive cars experience when a ham-footed driver is too rough on the accelerator. It is true that AWD is excellent at preventing the tail from stepping out under power. But this is not "improving handling." It's really aiding acceleration." https://www.popularmechanics.com/car...rive-15202862/ "False sense of security: It is easy to be lured by an automaker's advertising and think that having AWD means you can drive in the snow or rain as easily as you would in dry conditions. But the truth is that AWD and 4WD help only with acceleration and traction. Braking distances and handling will be the same as with a 2WD vehicle." https://www.edmunds.com/car-buying/d...drive-car.html |
12-15-2019, 06:38 PM | #12 | |
134
Rep 326
12-15-2019, 09:27 PM | #13 | ||
1053
Rep 1,952
It's all a matter of keeping the torque levels at the wheels below the threshold of traction for that particular wheel. If you need X amount of torque to get going then it makes sense that if that amount is spread over 4 wheels vs 2 than your chance of exceeding the traction threshold is a lot less. That doesn't mean that your tires are magically better and you can take a corner going twice as fast. However, what it does mean, is that when you accelerate out of the corner, your chances of under steer or over steer are reduced. |
12-15-2019, 10:04 PM | #14 | |
13238
Rep 19,728
What seemed to start the firestorm of misinformation and misunderstanding was my comment that AWD does not affect handling in the rain, both articles are very clear on that and concur with that point of view. |
12-15-2019, 10:31 PM | #16 |
Rep 4,502
Paraphrasing the OP's original question, "if I only drive in the city in good weather, is there an advantage in getting a car with AWD/4WD over 2WD?" Correct me if I misstated. The answer, discussed to a fair-thee-well in this and other threads, is most likely "marginally." That said, if you anticipate ever driving in less than optimal weather, on dirt roads to a campsite, or snowy roads to a ski lodge, or outside "the city" on unknown terrain - maybe to Gramma's house during the holidays when the weather might be unknown or unpredictable, and you think you would benefit from improved traction or acceleration, or would appreciate those benefits when towing a load, the answer is almost certainly "yes." I think.
*And just reading the above, xDrive is more expensive to buy, more complex to maintain, potentially more expensive to repair, and adds slightly more weight. On the plus side of the ledger, a (potentially) higher resale value, and benefits as described. Another consideration, unlike some factory options discussed, is you can't just slap on AWD as an after-market add if you want it later. Last edited by Paladin1; 12-15-2019 at 10:38 PM.. |
12-16-2019, 06:43 AM | #17 |
13238
Rep 19,728
Paladin1 laid it out very well. I personally would choose the AWD in your situation since it is readily available and the initial cost only adds about 4%.
In total, I think the advantages of AWD outweigh any disadvantages. Besides, should you ever want to whisk your significant other away for a romantic getaway, you may not be limited as to when/where you can travel due to the vehicle you have. |
12-16-2019, 07:37 AM | #18 | |
Rep 199
In Europe we don't get to choose which is perfectly fine by me. |
12-16-2019, 09:47 PM | #19 | ||
Rep 672
12-17-2019, 09:14 AM | #20 |
Rick James
305
Rep 784
Late to the party, but to me...it would be the equivalent of buying a 2WD truck. I guess it's a thing in southern weather, but you never know...you might move, you might go to an event where you park on the grass...it rains...then you wish you had it. What if there's a 1% chance you move somewhere north, or go visit someone. At face value, sDrive seems like "it would get by", but to me...it's better to have it and not need it than to not have it and need it.
Even if there's one or two instances where it would be beneficial, it's worth it. Plus, if you have to ask, I know you're leaning towards the xDrive! In my opinion, even if I was down south...if I was shopping used X5s, I would go for the xDrive over the sDrive. I bet the dealership would give you a little more since it would be easier for them to unload. Can't go wrong either way, but again...anything could happen and you don't want to be stuck! |
12-17-2019, 10:30 AM | #21 |
114
Rep 325
All the above arguments aside, I think you'll get a much lower resale % and have a harder time selling the sDrive vs the X down the road. But if leasing, doesn't matter.
____________________
Current: 2019 g05 X5 xDrive40i 2020 f30 440 xDrive Convertible 2004 e85 Z4 3.0 |
