      12-15-2019, 08:45 AM   #1
THinthedesert
14
Drives: 2020 BMW X5 M50i
How To Get M Brake Calipers Clean
I recently purchased a new 2020 X5 M50i and I love it. I try to keep it clean by hand washing it.
I realize the M brakes do emit more dust than the standard brakes. Maybe in time I’ll switch out the pads to ones that don’t emit as much dust, but for now I wonder how best to get the calipers clean. I use a spray non acidic wheel cleaner (P&S Brake Buster) and a brush that looks like a parts cleaning brush that’s meant for lug nut recesses, yet it’s very hard to get those calipers clean short of removing the wheels, which I’m not going to do.
I’ve considered buying a fairly ‘low pressure’ pressure washer to give the calipers a quick spray to try to get some of that dust out of the hard to get areas on the calipers.
Does anyone see any potential issue in doing so? I know some pressure washers can literally remove paint, so I’d intend to be very careful, but would like to hear opinions of any other suggestion as to how to get them cleaner. The look so nice when they’re new in that nice metallic blue color.
      12-15-2019, 10:02 AM   #2
dadzer
dadzer's Avatar
19
Drives: 2024 X5M60
You might want to look into having your wheels and calipers ceramic coated. I had mine done for around $380 = much easier to keep them clean!
      12-15-2019, 10:06 AM   #3
jumpingpint
Drives: BMW X5 50i 2017
Dust shows the power of the brake
Looks gorgeous to me
      12-15-2019, 12:45 PM   #4
Mbbrewer
Mbbrewer's Avatar
150
Drives: 550i
You'll be fine. A consumer grade electric power washer is perfect for wheels and won't remove the paint from the calipers
      12-15-2019, 12:58 PM   #5
MystroX5
MystroX5's Avatar
6282
Drives: 2020 X7 M50i/ 911
Yea, but it can introduce other issues. Every power washer has to have its power strength really monitored. I have seen and experience enough issues with power washers I don’t recommend using them on a vehicle like a modern BMW.
Don’t let the brake dust build up too long as it will make a easy job very ugly. Use a foam gun on the calipers and a wheel brush.
      12-15-2019, 01:11 PM   #6
Denk
Denk's Avatar
1006
Drives: 2021 X5M
Which wheels do have? 741's have the most open design for getting in there with a brush.
      12-15-2019, 05:15 PM   #7
THinthedesert
14
Thanks for all the comments.
I do have the 741 wheels and I certainly do have good access into the wheels, to clean the inside surface of them.
It's the parts of the calipers, especially the fronts that are hard to get clean.
      12-15-2019, 05:43 PM   #8
polychromatic
polychromatic's Avatar
Drives: E30, E44, E61, E07
I don’t know how well this works as it was mentioned in another thread, however it’s worth a try: Brake dust prevention
      12-15-2019, 07:09 PM   #9
DgjoX6M2016
F86, G05, E91
DgjoX6M2016's Avatar
Drives: F86 X6M
Iron X for 3 min on cool wheel. Hose. Drive. Enjoy.
I have had a ceramic coating on winters and that seems the help as well.
      12-15-2019, 08:11 PM   #10
dubsesd
#dubspec
dubsesd's Avatar
6327
Drives: G05 X5/ 2016 F80 M3 INDVL
Nothing will really fix this issue. You either wash your wheels everyday or swap pads. I got powerstop pads for 120 bucks and now live a 98% dust free life haha. Pedal feel and bite feels oem
      12-16-2019, 06:42 AM   #11
screamace
screamace's Avatar
304
Drives: 2020 BMW X5M Competition
The brake dust is still difficult to remove with pressure washer. Like above posts mentioned, ceramic coat and iron X is the way to go.
2019 Porsche Panamera 4 E-Hybrid
Past BMW: 2018 M550i, 2016 X5 40e, 2014 335xi, 2011 X5 50i, 2010 550i
      12-16-2019, 07:16 AM   #12
gofast182
Drives: 2020 M340i xDrive
I removed the wheels and coated them and the calipers with Pinnacle Black Label Diamond Wheel Coating. It's not the miracle product I envisioned but it does make everything very easy to clean.
I use a cheap Ryobi 1600psi pressure washer, 15* tip, and a MTM hydro gun and it washes most dirt off instantly.
A quality wheel cleaner like Sonax will also work very well but it doesn't offer any added protection and can get expensive long term.
      12-16-2019, 08:31 AM   #13
atl_1M
Drives: '11 1M, '20 X5 40i
Which powerstop pads did you get? I don't see anything listed for the G05 X5s on their site. Thanks
      12-16-2019, 09:49 PM   #14
Mbbrewer
Mbbrewer's Avatar
150
Drives: 550i
Yea, but it can introduce other issues. Every power washer has to have its power strength really monitored. I have seen and experience enough issues with power washers I don't recommend using them on a vehicle like a modern BMW.
Don't let the brake dust build up too long as it will make a easy job very ugly. Use a foam gun on the calipers and a wheel brush.
You're being dramatic. I wash my cars almost every week using one and never experienced a single issue. In your experience what "other issues" have you had using a pressure washer? A consumer grade electric pressure washer, like one you can find at Home Depot will not create any problems.
      12-16-2019, 09:54 PM   #15
mhodx5
Drives: X5 M50i ordered
Please elaborate. Where did you get the power stop pads? Did you install yourself. 120 is super cheap
      12-16-2019, 10:22 PM   #16
ferrarif1
Drives: F85, G05, E46M3
Check out some of the videos on YouTube from Money2536 aka Obsessed Garage. A low psi pressure washer, p&s or Adams wheel cleaner and a good set of brushes will clean them up nicely.
      12-17-2019, 09:10 AM   #17
AndroidRobot
AndroidRobot's Avatar
  [0.00]
for what it's worth mine are ceramic coated, as are my wheels and it doesn't really help that much if at all.
      12-17-2019, 10:41 AM   #18
Tenac
Tenac's Avatar
4537
Drives: All
I agree with this.... I use the new turtle wax hybrid with ceramic and all it really does is make it easier to clean off. They still get dirty just as fast and much but no more really scrubbing.... I would say it takes half the time to clean the wheels.
2022 M8 Comp Convertible
2023 718 Cayman GTS 4.0
2019 718 Cayman Base
2015 M235 Manual
On the list for the M2 CS
      12-17-2019, 02:24 PM   #19
AndroidRobot
  [0.00]
Yes, it helps, but is far from a night/day type of deal. I don't need to scrub, only wipe it off after using my foam cannon.
