      12-17-2019, 06:57 PM   #1
rebekahb
3130
Drives: 2020 X5 M50i
Connected App Help
Has anyone received this message before? I am logged in and am allowing data use. I have also deleted the app and then added it again.
      12-17-2019, 09:12 PM   #2
jasrboyd
Drives: 2021 330i Xdrive
I think I have and I checked the box and then close
2021 330i xdrive Phytonic blue
      12-18-2019, 08:14 AM   #3
gpitts
gpitts's Avatar
247
Drives: 2023 G07 X7 40i
I vaguely remember that I had the same issue and had to enable location in the Connected app. Seems counterintuitive that this setting would matter but maybe worth checking your settings in the app.
2019 G05 X5 40i, Phytonic Blue, Black Extended Merino Leather Interior
      12-18-2019, 10:07 AM   #4
randybobandy
Rick James
randybobandy's Avatar
305
Drives: 2020 BMW M340i xDrive
check the box and hit close...itll probably give you the prompt about the mirrors folding, then you're good. just did it after deleting everything post-update
      12-18-2019, 10:17 AM   #5
ChiTownM
ChiTownM's Avatar
Drives: M and i BMWs
Same here....something I had to do too when I got the app going for the car.
      12-18-2019, 04:19 PM   #6
rebekahb
3130
I did all that and when I click on remote 3D view this is all I get. No image ever loads. Also, I entered an address and it didn't send it to my car when I started it.
      12-18-2019, 04:24 PM   #7
randybobandy
Rick James
305
What happens if you hit loading. You'll see the steps. It takes a little bit of time sometimes. Also, go into your car and go to the apps page. Hit option button on iDrive and you'll see a prompt to update apps and services. This fixes it sometimes too.
      12-18-2019, 08:50 PM   #8
ElectroGeek
Drives: X5 G05 50i
I can not remember where but there are several box's that must be checked in the iDrive system to allow remote 3d view to operate.
      12-19-2019, 07:10 AM   #9
randybobandy
Rick James
305
If you go to privacy, just make sure everything is accepted. If you go into CD App, at the main page...hit INFO and go down to enabled/disabled features...do you see Remote 3D View under enabled?
