01-18-2020, 07:23 AM | #1 |
134
Rep 326
Following link for aSLA coding. Verified on US model with 7/2019.55:
https://drive.google.com/file/d/1U9h...Mds3cFmzt/view Anyone with questions, answers or recommendations feel free to post... Credit goes to Eaglesrest... |
01-18-2020, 07:39 AM | #2 |
1197
Rep 1,587
I'd be interested in feedback on the following points:
- Is coding DSC_VIPx necessary - worth trying without first - I'm not sure if STRECKEN_VERLAUF is strictly needed for aSLA. Suspect it activates predicted deceleration for junctions/roundabouts, etc. VOFFSET* introduces an additional option to set the manual speed adjustment up to 40mph and also above 40mph. This gives me control over the manual adjustments e.g. I set the first param to + 2mph up to 40mph, and +5 above 40 mph. This ensures there is no chance of a speeding ticket while maintaining a reasonable speed. This additional capability is not available with aSLA even in countries where its supported, so might be worth coding even if you already have aSLA. Can confirm working on US G05/G07, CA G05 and AUSY G05. i-step >= 07/2019.x Some potential behaviour changes in some regions on i-step 11/2019.x |
01-18-2020, 07:53 AM | #3 |
Rep 2,609
Only thing I noticed different from descriptions on my April 2019 CA build now on 11/2019.40 is that two of the original country bitmaps were different from @ifr's table. Looks like more countries got aSLA enabled stock on 11/2019.40.
Also all my stuff is properly in km/h and the 40mph threshold is 65km/h on mine. Max over/under you can set is 15km/h, which for me is not enough (those driving 401 within 100km of TO will understand). I coded all parameters indicated. All functions work, including predictive slow down/speed ups.
01-18-2020, 04:49 PM | #4 |
Rep 71
aSLA 2019/11 AUSY G05
I have successfully coded it. I am on 2019/11, AUSY car.
I changed two options from the list VOFFSET to gen_2. I see the option to "Adjust to route" which enables roundabout, turns... this can be turned on/off as well if not required. Everything works fine. |
01-18-2020, 04:53 PM | #5 | |
1197
Rep 1,587
On 07/2019.x, changing voffset to gen2 limited the adjustable speed to 5mph instead of 10mph. Gen2 is not designed for the g05, I think it was g01 only as I recall. Would need to double check. |
anuj452115.00 |
01-19-2020, 06:14 AM | #7 |
Rep 199
Is aSLA showing in your (US/CA/AU) iDrive menu before this coding? For me (FI, 07/2019.59), automatic speed limit adjustment and speed adjustment to route are visible menu options but selecting them results in a message about them not being available in this country and later warnings when activating any assisted driving features.
Manual adjustment for speeds up to 60 km/h and separately for over 60 km/h is available for me without coding and works fine. I am trying to estimate the minimal amount of coding required to have aSLA. |
01-19-2020, 07:29 AM | #8 | |
1197
Rep 1,587
Best bet is simply to set what you don't have, and absolutely set the land masks to FFFFFFFF at the minimum. |
perikifi165.50 |
01-19-2020, 11:34 AM | #11 |
Rep 989
nice! this is a great feature. Can anyone coded it for US models? I am on latest iDrive (I believe 11/2019.40?) . Can I code using Bimmercode app expert mode?
01-19-2020, 12:26 PM | #12 | |
134
Rep 326
ifr1196.50 |
01-19-2020, 06:25 PM | #14 |
Rep 2,609
My defaults were not quite the same as per this spreadsheet either. That could be for a variety of reasons, one being that @ifr is on 07/2019.xx you and I are on 11/2019.xx. I reported my defaults back to @ifr.
01-20-2020, 07:49 AM | #16 |
Rep 602
Here’s a general esys/esysx coding question since the aSLA function affects so many modules. Can you perform changes to multiple modules and then do the Code ncd step once rather than having to do it for each module individually? Thought I saw somewhere it wouldn’t work with esysx. Thanks!
02-01-2020, 09:15 AM | #17 |
Rep 199
After a lot of reading and some trial and error, I got Esys+EsysX working and was able check the aSLA settings on my MY20 October 2019 build Euro 45e with 07/2019.59 factory software.
All the other listed keys had the correct values, only the six *_Land_Aktiv keys had non-0xFFFFFFFF values, keeping me from using aSLA, as one of the 0 bits is for Finland (or Nordic or something else). Note that I have been able to select aSLA in iDrive since start but it has produced a 'This feature is not supported in your country' message and later warnings every time you activate adaptive driving. Having coded all six land keys to 0xFFFFFFFF I am able to set SLA as Adjust automatically, as well as check on Adapt to route, without any messages. So everything is great, but due to this weekend's schedule I will not be fully field testing this before Monday. A few final notes:
02-03-2020, 09:46 AM | #18 | |
1197
Rep 1,587
There are basically 3 scenarios: 1) Car is coded to allow aSLA, region vehicle is physically located is NOT allowed to use aSLA 2) Car is coded to allow aSLA, region vehicle is physically located IS allowed to use aSLA 3) Car is not coded to allow aSLA, region vehicle is physically located may or may not allow use of aSLA but wont work regardless The codes should address all scenarios give or take a setting or two, plus add the adaptive driving, slowing for roundabouts etc Technically the land bitmask could be modified to allow additional 'specific' regions, but no need when FFFFFFFF does the trick. |
02-03-2020, 12:09 PM | #19 |
Rep 199
And it works like charm! aSLA is important to me as I really want to avoid accidental speeding tickets from the increasing numbers of automatic speed cameras around here (the cheapest ticket is around $200 and I only ever got one of them). Thanks LexxM3, ifr and homerrr for your examples, encouragement and warnings
02-03-2020, 12:19 PM | #20 |
1197
Rep 1,587
I love it too. I was constantly setting, adjusting and readjusting the active cruise on my previous X5, which is rarely necessary with this feature. Just turn it on and let it do the work.
The fact its safer and almost eliminates the risk of a speeding ticket is even better. BMW just need to sort the occasional aggressive deceleration, and improve the false positive recognition from discarded/offset speed limit signs. Cloud connected machine learning will help with that. |
perikifi165.50 |
04-13-2020, 02:03 PM | #22 | |
Rep 253
Does the coding below above cover fix this issue for me? im in ksa would love to enable automatic sign recognition. |
