      06-14-2020, 12:13 PM   #45
VTENGR
1044
Drives: 2020 X5 M50i
Originally Posted by ifr View Post
Try this link. I'll leave it up a couple of days:
https://drive.google.com/file/d/1ore...ew?usp=sharing
Thank you!
      06-14-2020, 12:48 PM   #46
VTENGR
1044
I'm assuming the modules that are crossed out should just be ignored?
      06-14-2020, 01:39 PM   #47
LexxM3
LexxM3's Avatar
1698
Drives: E46M3, G05X5
2019 X5  [0.00]
Yes, VIP coding for aSLA can be skipped (but doesn't hurt).
VTENGR1043.50
      06-14-2020, 02:31 PM   #48
VTENGR
1044
Just took a quick spin after coding. It now will set the speed with the offset I chose however it didn't seem to auto adjust the speed when the limits would chage. I'm not sure if it was the types of streets I was riding on or what. I would get the notification that the speed limit changed with "SET"the next to it, but wouldn't do it automatically.
      06-14-2020, 03:01 PM   #49
jeet
Australia
26
Drives: BMW X5 (G05)
Are you driving on acc then only it will change the speed automatically also you need to change the speed settings in iDrive for this to work.
      06-14-2020, 03:30 PM   #50
VTENGR
1044
Yeah... I'm thinking it may be just the types of roads I was on. I have everything set to automatic with the offsets set to +10mph using the ACC with steering assist.
      06-15-2020, 01:56 PM   #51
VTENGR
1044
Update: I went through my coding steps and it looked like the code for "C_SLA_aSLA_vorhanden" did not take the first time around. Either I accidentally changed it back or whatver. Either way, I changed that back to "Nr001_vorhanden" and recoded the car. Took her out for a spin and everything is working the way it should! Pretty neat feature, it's a shame the US has it disabled for some reason.
In any event, thanks to everyone for your help!
      06-17-2020, 08:01 AM   #52
OzJedi
Australia
107
Drives: X5 2019 40i MSport Carb Black
I have successfully coded aSLA as per the cheatsheet and it works fine except I don't see "Adjust to route" option in settings? Am I missing anything?
Thanks!!
      06-18-2020, 03:02 AM   #53
ifr
ifr's Avatar
United Kingdom
1197
Drives: Tesla MY LR AWD
Thanks!!
You could try enabling Sicht_absicht in hu_mgu and dkombi, or similar.
OzJedi107.00
      06-19-2020, 03:38 PM   #54
up2up
up2up's Avatar
Drives: X5M 2019
Hi guys,
can i have the coding lines please. the file has been removed
Abdol (X5m, 2019)
      06-20-2020, 12:55 AM   #55
ifr
ifr's Avatar
United Kingdom
1197
Originally Posted by up2up View Post
Hi guys,
Try here:
https://drive.google.com/file/d/1sLa...ew?usp=sharing
      06-22-2020, 11:19 AM   #56
up2up
up2up's Avatar
Drives: X5M 2019
Thank you
Abdol (X5m, 2019)
      06-25-2020, 02:23 AM   #57
OzJedi
Australia
107
Thanks! I tried without any luck.
I will also try coding parameters which are crossed out in cheat sheet, i didn't code them as they are crossed out so thought not required.
      06-25-2020, 03:33 AM   #58
ifr
ifr's Avatar
United Kingdom
1197
Yes, I didn't think that would work.
It could be worth a try with the VIP codes. Others have not needed them, but the land masks may be more relevant to an AUSY car.
Also double check that STECKENVERLAUF is set correctly in BDC and HU_MGU, and all landmasks reference FFFFFFFF.
Try these additional codes at your own risk. Can you let me know which you already have set, and which you had to change pls?
SAS
C_SLA_Vorausschau_Auspraegung - NR001_ACC
C_VZA_Funktion_Land_aktiv 0xFFFFFFFF
C_VZA_Funktion NR001_aktivert
HU_MGU
VORAUSSCHAU gen_1
GUIDING_VORAUSSCHAU_SLI_ENABLE aktiv
DKOMBI
HMI_HUD_VORAUSSCHAU_ENABLE: aktiv
HMI_KI_VORAUSSCHAU_ENABLE: aktiv
LDM_VORAUSSCHAU_ENABLE: aktiv
LDM_VORAUSSCHAU_SLI_ENABLE: aktiv
PIA_HUD_VZA: aktiv
PIA_HUD_VZA_PORTIERUNG: aktiv
PIA_KI_VZA: aktiv
PIA_KI_VZA_PORTIERUNG: aktiv
VZA_ENABLE: aktiv
BDC_BODY [7083]
VORAUSSCHAU: aktiv
OzJedi107.00
      06-29-2020, 07:17 AM   #59
OzJedi
Australia
107
SAS
HU_MGU
VORAUSSCHAU gen_1
DKOMBI
PIA_HUD_VZA: aktiv
PIA_KI_VZA: aktiv
VZA_ENABLE: aktiv
BDC_BODY [7083]
VORAUSSCHAU: aktiv
Thanks a ton!! Still no luck even after enabling all the crossed out settings in the cheat sheet, there is something I am doing wrong. Someone has already done it in Aus so I am sure it can be done
Overall SLA is working fine without any issues only option I don't get is 'Adjust to route' setting.
My settings below
BDC/7083
AUTOMATISCH - aktive
STRECKEN_VERLAUF - aktive
VORAUSSCHAU - aktive
VOFFSET_LANGSAM - gen_1
VOFFSET- gen_1
HU_MGU/3E52
SLAAUTOMATISCH - gen_1
STRECKENVERLAUF - gen_1
VORAUSSCHAU - gen_1
VOFFSET - gen_1
SAS2/42C1
C_SLA_Anzeige_Zusatztexte - Nr001_aktiviert
C_SLA_aSLA_Land_Aktiv - 0xFFFFFFFF
C_SLA_Vorausschau_Land_Aktiv - 0xFFFFFFFF
C_SLA_Streckenregelung_Land_Aktiv - 0xFFFFFFFF
C_SLA_Streckenregelung_vorhanden - NR_002_vorhanden_SLA_entkoppelt
C_SLA_aSLA_vorhanden - Nr001_vorhanden
SLA is working fine even without below set of settings except for 'Adjust to route' option
DSC_VIP/3D14
Some additional settings as suggested
SAS2/42C1
C_SLA_Vorausschau_Auspraegung - NR001_ACC (factory, no change)
C_VZA_Funktion_Land_aktiv - 0xFFFFFFFF
C_VZA_Funktion NR001_aktivert - NR001_aktivert (factory, no change)
HU_MGU/3E52
VORAUSSCHAU - gen_1
GUIDING_VORAUSSCHAU_SLI_ENABLE - aktive (factory, no change)
DKOMBI
HMI_HUD_VORAUSSCHAU_ENABLE: aktiv (factory, no change)
HMI_KI_VORAUSSCHAU_ENABLE: aktiv (factory, no change)
LDM_VORAUSSCHAU_ENABLE: aktiv (factory, no change)
LDM_VORAUSSCHAU_SLI_ENABLE: aktiv (factory, no change)
PIA_HUD_VZA: aktiv (factory, no change)
PIA_HUD_VZA_PORTIERUNG: aktiv (factory, no change)
PIA_KI_VZA: aktiv (factory, no change)
PIA_KI_VZA_PORTIERUNG: aktiv (factory, no change)
VZA_ENABLE: aktiv (factory, no change)
Someone suggested to code sicht_absicht in HU_MGU and BDC. I think this coding enabled 'Show Anticipation' option under Driver Assistance/Driving/Speed Assistant/Speed Limits menu.
While coding these settings I came across below in HU_MGU and BDC
SITUATIVERABSTAND - changed to aktive.
This enabled automatic distance control according to situation. I tried to test it on road but didn't notice any difference. I was expecting distance between my car and the car ahead me would adjust automatically depending on car speed instead of me manually setting it but that didn't happen so not sure if this setting is really working.
[EDIT]
  • When I looked at definition of 'Adjust to Route' in Driver's guide(refer second image), I realized that functionality is working as per the definition. Car does slow down at round about, turning off, bend, etc. only thing missing is the option to switch on/off this in iDrive menu.
ifr1196.50
      06-29-2020, 07:43 AM   #60
ifr
ifr's Avatar
United Kingdom
1197
Who was it who did it in Oz? Margos?
I'd back-out SITUATIVERABSTAND as its not supported yet - future feature slated for 07/2020 or 11/2020 i-step.
One other punt, which relates to aSLA although not directly-
40F8
VFW_COUNTRY_VARIANT_MODE
change werte to
FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF
      06-29-2020, 07:48 AM   #61
OzJedi
Australia
107
40F8
change werte to
It was this post
https://g05.bimmerpost.com/forums/sh...54&postcount=4
Ok,will remove SITUATIVERABSTAND and try VFW_COUNTRY_VARIANT_MODE setting.
Thanks!
      06-29-2020, 09:28 AM   #62
ifr
ifr's Avatar
United Kingdom
1197
It was this post
Thanks!
Ah right. I believe that poster just coded aSLA.
Maybe they also used the VFW_COUNTRY code as well, as I vaguely recall them posting about it.
      06-30-2020, 04:53 AM   #63
marcosg
marcosg's Avatar
Australia
25
Drives: 2024 G05 X5 M60i
I have the 'Adjust to Route' working and can be set it from iDrive as per attached pic. I checked OzJedi code, it is the same as what I coded.
I didn't code VFW_COUNTRY.
The only exception is I had VOFFSET- gen_1 set by default. I didn't code it.
ifr1196.50
OzJedi107.00
      09-01-2020, 02:22 PM   #64
Xmel`
Drives: BMW X5 G05
VO Code would be 3E3 to FA and Code 7083, 3E52, 3D0E
Quite a few codes changed but not sure how you can switch modes without a rocker, even assuming you have GHAS?
Thanks a lot for your help man once again!
I have finally done it.
New rocker switch, VO coding as you described and that's it
Didn't test it on some off-road jet but it changes the level of air suspension and writes something abut stabilisation modes))
Can you please tell what you use to find which ECU should be coded after adding new code to FA?
      09-02-2020, 02:23 AM   #65
ifr
ifr's Avatar
United Kingdom
1197
Use coding-verification in esys to do a compare of the fwl files generated before and after an FA change.
This will not only identify the ECU/cafd modified but also the specific FDL codes within them.
Xmel`6.50
      09-04-2020, 03:41 AM   #66
Saunders17283
Saunders17283's Avatar
Drives: 2020 M850xi Gran Coupe
Thanks to all! I just finished successfully coding aSLA in my MY20 M850. It has 03/2020.40 on it. I followed all the great help from this thread and it worked like a charm the first time!
Side note, albeit ambitious, this was my first code ever with eSys/eSysX so I was quite nervous going into it but with the awesome help and that killer spreadsheet, I was able to stumble my way through it.
For those reading this in the future, I coded the following just the way OzJedi described in his post. I also skipped the VIP items which are crossed out in the spreadsheet.
My settings below
BDC/7083
VOFFSET- gen_1
HU_MGU/3E52
VORAUSSCHAU - gen_1
VOFFSET - gen_1
SAS2/42C1
Current Ride
Previous Rides
2019 X7 / 2018 X5 / 2012 X5 / 2014 750xi / 2011 750Lxi / 2008 335xi
OzJedi107.00
