03-07-2020, 02:18 AM | #1 |
Rep 2,420
I was updated to 03/2020.24 last Monday.
Found the first difference: As before when pre heating the steering wheel heating also turns on. Before if you wanted to turn it of and you pushed the button on the first push nothing would show. Second push would show "steering heating on". Third push off. Now it directly shows steering wheeling heating off on the first push. Keep you posted on other differences |
03-07-2020, 04:26 AM | #2 | |
Rep 2,935
03-07-2020, 07:25 AM | #3 |
Rick James
305
Rep 784
Not sure if you notice this, but does the comfort access seem any smarter? Ever since I went to 07/2019.xx and 11/2019.xx, it seems “stupid”. I turned off the unlock when approaching, but left on lock when leaving. Biggest gripe, I go to fill up the tank, and the car is instantly locking itself as if someone was inside hitting the lock button every 5 seconds. I refuse to leave my fob in the car out of commonsense.
maxim38rus11.00 |
03-07-2020, 07:32 AM | #4 | |
1053
Rep 1,952
03-07-2020, 08:22 AM | #5 | ||
Rep 2,420
I will turn it on somewhere these weekend to see what happens. |
03-07-2020, 08:53 AM | #6 | |
Rep 5,323
I have mine to just Auto Unlock and even then it’s a bit maddening when I am working in the garage with the key fob on me. We are so far past just a luxury/convenience feature that I wonder if it’s going the other way of over complicating its purpose???? Last edited by MystroX5; 03-07-2020 at 08:58 AM.. |
randybobandy304.50 |
03-07-2020, 08:58 AM | #7 | ||
1053
Rep 1,952
03-07-2020, 09:03 AM | #8 | |
Rep 5,323
03-07-2020, 10:58 AM | #9 |
Rick James
305
Rep 784
It's just been a FAR different experience with this car and previous vehicles. You could rip a fart right next to it, and it'll turn on. The one thing I hate is the circumstances in which the car powers off after stopping the engine and opening the door. It works, but if you're on a call, you either have to manually swap over to the phone or wait until you get out and lock the car or just power off with the 3 second hold. Same goes for when you open the door after jamming to some music, then tap something by accident and she comes alive.
Ole Betsy and I are constantly fighting to shut er up. |
M40i4me1037.00 |
03-08-2020, 06:48 AM | #12 |
Rep 2,420
It was done at the dealer In Belgium. Didn't get a notification for over the air update. Mine was delivered in December with 07/2019 and it had to go for another reason and I asked them to upgrade.
03-08-2020, 07:24 AM | #14 |
Rep 810
This has been discussed in previous threads, but I think OTT software updates are starting to rollout, but only on an n-1 version basis, where n = is the newest release.
So I'm currently on 11/2019.34, and for me I wont get an update OTT until BMW releases 07/2020.xx some time in July 2020, and then only to version 03/2020.xx (the previous version to the latest). Apparently BMW do this to assure stability of the upgrade. When I do the OTT S/W upgrade check in my car, rather than just "No updates available", it now says .."no current update available for your vehicle" - so something's changed. Bring on July 2020 ! |
03-08-2020, 07:43 AM | #15 |
Rep 2,420
After the update my charging times almost doubled.
Fortunately just because the max power was automatically set back to 6A. Corrected it to 16A and problem solved. |
03-08-2020, 09:30 AM | #16 |
Rep 82
03-08-2020, 11:34 AM | #17 | |
Rep 2,420
But now it is back to normal like I was used to. |
03-10-2020, 10:49 AM | #18 |
Rep 135
How you set it back to 16A?
BMW X5 2019 - Software version 03/2021.36
Mineral White on Canberra Beige + Walknappa Leather Dashboard |
03-10-2020, 12:09 PM | #19 | |
Rep 2,420
I just didn't notice at first it was set back to 6A which is the default factory setting. |
03-10-2020, 01:53 PM | #20 |
Rep 228
Anyone having an issue on the 11/2019 SW where the mirror fold doesn't work on locking the car?. I have to keep selecting that every couple of day but then it keeps getting unticked.
03-10-2020, 02:12 PM | #21 | |
Rep 5,323
Mine doesn’t do that. Did you do a iDrive reboot? My only issue with that firmware update is my “Home” location in the GPS has to be constantly reset. |
03-10-2020, 05:12 PM | #22 | |
Rep 810
It might be your profile, do you use your same key fob? ..is the other fob in range when you approach the car? My wife keeps her key fob in her handbag, and if she approaches the car first (before me) then when I open the drivers door, her profile shows up - and settings are of course different. Might be worth rebooting iDrive (hold down the radio volume button for 30 seconds, and it reboots the iDrive system). If that doesn't fix it, delete all profiles and setup a new one. |
