      06-11-2020, 03:22 PM   #45
130FeetDeep
Drives: BMW X5 M50i
Originally Posted by babyghost View Post
https://www.fabspeed.com/universal-9...nverters-pair/
Something like this should remove the CEL.
I have used spacers on some cars. All I will say is good luck with this vehicle. I am not sure you have the room and this DME is finicky.
      06-11-2020, 10:38 PM   #46
BimmerVinyl
401
Drives: 2022 M240i
Stock tune for now, just got an cel unfortunately.
Good info. I cannot imagine there is any way to avoid a CEL without a tune to remove it.
Spacers DO NOT fit on the G05. They do however fit on the G30. This has been confirmed. Too many heat shields in the G05.
Only way to effectively remove CEL is with a flash tune. I reckon BimmerCode or OBD2 reader would only be a temporary fix..
      06-12-2020, 01:25 AM   #47
babyghost
babyghost's Avatar
95
Drives: 2020 X5 M50i
Good to know, bench tuning soon.
      06-13-2020, 02:57 AM   #48
babyghost
babyghost's Avatar
95
My CEL disappeared for some reason, hopefully it stays that way.
      06-13-2020, 01:17 PM   #49
BimmerVinyl
401
Drives: 2022 M240i
It may disappear for two or three days, but it's bound to come back.
      06-13-2020, 01:54 PM   #50
x5m50i
x5m50i's Avatar
301
Drives: X5 G05 M50i
Although i have Stage 2 from G-Power (catless dps) and it shouldn't throw any CEL....well suprise...it shows, it dissapears. It's like is having a mind of it's own
180101 - Catalytic converter 2: Efficiency too low.
FBG M4 CSL
      06-13-2020, 02:02 PM   #51
130FeetDeep
Drives: BMW X5 M50i
They didn’t code it out with their flash? They can code that out with the flash. I would bring that up to them.
      06-13-2020, 02:19 PM   #52
x5m50i
x5m50i's Avatar
301
Drives: X5 G05 M50i
The strange thing is that they did it in the tune, so the ECU should not read values from the unexisting cat. I am 2400kms away from them, but they sent a tool to do some rolling logs and do a V2 tune
FBG M4 CSL
      06-13-2020, 05:16 PM   #53
130FeetDeep
Drives: BMW X5 M50i
That is encouraging that the will help. Let us know us know how it works out.
      06-14-2020, 02:18 AM   #54
x5m50i
x5m50i's Avatar
301
Drives: X5 G05 M50i
i will. They are nice guys and willing to help. They sent a bFlash Master.
FBG M4 CSL
      06-17-2020, 04:50 PM   #55
Hammer205
Drives: BMW X5 50i M
Baby ghost did you call the main number to order these DP’s?
      06-17-2020, 05:05 PM   #56
130FeetDeep
Drives: BMW X5 M50i
So you didn't have to do a bench flash? Wow, that would be HUGE news!
      06-18-2020, 01:49 AM   #57
babyghost
babyghost's Avatar
95
Originally Posted by Hammer205 View Post
Baby ghost did you call the main number to order these DP's?
No I ordered through Justin at Auto Talent.
      06-18-2020, 01:50 AM   #58
babyghost
babyghost's Avatar
95
I think he got bench unlocked already, so now he can flash via OBD.
      06-18-2020, 11:00 AM   #59
130FeetDeep
Drives: BMW X5 M50i
So if you update the car software via BWM after, does it OBD2 relock?
      06-18-2020, 12:10 PM   #60
Hammer205
No issues With fitment? Any modifications needed?
      06-18-2020, 12:43 PM   #61
babyghost
babyghost's Avatar
95
Fitment was ok, I think one bracket was off and need to be adjusted. I only went with fi because they have catted version. If you want catless don't buy from fi (priced too high).
      06-18-2020, 02:08 PM   #62
x5m50i
x5m50i's Avatar
301
Drives: X5 G05 M50i
Not via OBD, but they created their own tool which you plug directly into the ECU's slots without removing it from the car or "open" it
FBG M4 CSL
      06-18-2020, 03:06 PM   #63
130FeetDeep
Drives: BMW X5 M50i
So this is called the B-flash master? Do we know if other shops have one yet? DME? RK-Tunes?
      06-19-2020, 08:54 AM   #64
Hammer205
I too want cats. Thanks for info. Yeah they are a lot more $$.
      06-19-2020, 01:33 PM   #65
x5m50i
x5m50i's Avatar
301
Drives: X5 G05 M50i
I think it's an adaptation of bFlash in order to connect directly to the ECU:
FBG M4 CSL
      06-19-2020, 01:40 PM   #66
BimmerVinyl
401
Drives: 2022 M240i
I'll be reaching out to DME to see if they could adopt something similar.
