07-07-2020, 11:13 PM | #1 |
Rep 459
Distorted/Rotated SurroundView Camera - Resolved!
One item that made it through quality control when I took delivery of my G06 back in late March was a crooked/rotated/distorted SurroundView camera. To me, it seemed like the driver's side camera was simply rotated a bit.
I noticed it the day I drove it home and figured I'd simply have it looked at during my first service appt. The first attached picture shows the "before" situation, which I thought made it pretty obvious, but others haven't really seen it... I had to take it in to have something else more urgent dealt with, so I had them take a look at the camera. The Tech didn't believe there was any way to rotate it (he indicated it just fits "one way") and they decided they're replace the camera. Parts took a few days to come in, so I took it back a week later. During the week that passed, the Tech or Service Manager found that there was a BMW SIB (#66 29 19) out there indicating the problem and rather than replace the camera, it should be shimmed in place using some felt. Recalibration is then needed...I attached a PDF of the SIB below. In the end, I still don't think it's quite perfect, but it's pretty good and with the fish-eye cameras, there has to be some distortion somewhere as you go out radially from the camera, so I think it's pretty good. I shared a final picture of how it looks now... Maybe others have run into this and have a better suggestion?? Just wanted to share in case someone else is experiencing this issue. |
07-08-2020, 06:29 PM | #2 |
Rep 204
Was this a brand new car when you got it in March ?
I am currently waiting for my G06 to be built (currently 5300 Pre Assembly Start) so just curious if this is something thats still leaving the factory like this or was a fault that they would have corrected by now. The SIB is from 5th December, hence the question. Thanks
Ordered: 2024 BMW M240i XDrive Current: 2020 BMW X6 Xdrive40i M Sport Previous: 2020 Porsche Cayman S Previous: 2017 BMW X6 Xdrive40d M Sport |
07-08-2020, 08:06 PM | #3 | |
Rep 459
2020 BMW X6 (G06) M50i - Manhattan Green/Coffee - 11/2022.63
07-08-2020, 10:38 PM | #4 |
15
Rep 47
I took delivery of mine March 20/2020. I believe it was fine at first but not 100% sure now and had the same issue with the driver side camera.
I know the bulletins are a bit different between Canada and the States. However, they had to escalate to BMW Puma as they have never seen this before and my work order shows the following: reset trsvc, updated software including trsvc, allow sleep mode over night and drive at parking lot speed for calibration. It is fully aligned now. So hopefully that might help you. This is the before pic (even though I was pretty much perfect straight. I will snap some new ones tomorrow. Last edited by mavjay; 07-08-2020 at 10:47 PM.. Reason: adding picture |
07-08-2020, 10:58 PM | #5 | |
Rep 459
Mine was in pretty good shape after they did those things... So, it seems like the first troubleshooting is to update SW, reset things (not sure exactly what...), then re-calibrate the camera(s). If that doesn't do it, then the pull the camera and try to shim it around a bit, then walk back through the reset and re-calibrate... |
08-27-2020, 07:58 AM | #6 |
Rep 4,503
Drives: 2022 iX xDrive50, DGM
Been awhile on this thread, but I just wanted to verify that this issue was resolved on my car with the 11/2019.70 iDrive update. Apparently not a hardware problem, in my case, that has been reported elsewhere. Mirror cameras are now perfectly aligned post-update. I'll try to load "after" shots when I get a chance, but this is the "before" issue:
kkratochvil313.50 dds007411.00 |
10-22-2020, 02:39 PM | #7 |
552
Rep 1,746
I should have searched first but I have the same problem.
Just took delivery yesterday was built around 10/5/2020 or so. Does this impact lane keep assist or anything else?
10-22-2020, 02:53 PM | #8 | |
Rep 459
As noted in some of the details, get your dealer to take a look at it and provide them with the SIBs, etc. Some resolved with just recalibrating the cameras, while others required the camera to be physically re-positioned.
10-22-2020, 03:12 PM | #9 |
Rep 4,503
Post-software update (now v7/2020.54):
10-22-2020, 04:05 PM | #10 |
552
Rep 1,746
kkratochvil, I'll have to try, I don't think I have any time to visit dealer soon, so I hope this is a quick fix not a day long or drop and we'll let you know type of situation. I will need to visit dealer for state inspection anyway but with Covid I heard registrations might be running late.
Paladin1, that looks perfect! I think you are using remote view, what about in-car view, is it same? I thought software updates were supposed to be over the air. I'll check mine hopefully I am not running v7/2020.54 or it would mean it's camera issue.
10-22-2020, 07:00 PM | #11 | |
Rep 4,503
10-22-2020, 11:28 PM | #12 |
552
Rep 1,746
Hi Paladin,
Confirmed I am on 07/2020.48, so it's possible mine is a hardware issue if the camera issue was fixed on earlier versions. Was the update a long process, or is it a quick in and out, in case, but I do think I will need to make an appointment to drop it most likely. I got it from a dealer 1:30hr away, hopefully local dealers don't play hardball with service.
10-23-2020, 08:17 AM | #13 | |
Rep 4,503
hyde551.50 |
10-30-2020, 09:28 AM | #14 |
Rep 1,348
Well I took delivery today and have this issue on the drivers side so clearly there's still something going on with either the initial calibration or the camera hardware. Guess I'll see if they can update it to the latest software to see if it fixes the issue. Thanks for documentation kkratochvil!
21 BMW X5 xDrive40i
20 BMW M2 CS 19 Mini Cooper S Countryman ALL4 6MT |
kkratochvil313.50 |
10-31-2020, 06:19 PM | #15 | |
552
Rep 1,746
11-01-2020, 03:32 AM | #16 |
Rep 1,348
I made the appointment yesterday and they were not familiar with it. So I told them I'd bring the SIB with me tomorrow when the drop it off. They want it for half a day, so I figure they're going to try updating everything as part of the fix.
I actually noticed this issue the first time I went to park and my wife was complaining that I was crooked in the space. I insisted I was perfectly straight and she got out of the vehicle to walk around and "check my parking". That's when I looked more closely at the display and you could see where the parking lines did not line up correctly and she was looking at the drivers side one that was askew as I was pulling into the spot.
21 BMW X5 xDrive40i
11-01-2020, 05:19 PM | #17 |
552
Rep 1,746
Thank you, I am still waiting for my registration to arrive, I'll be making an appointment right away for my state inspection and this camera issue, it's extremely annoying, I park in a very narrow garage, and I always go by the lines, if lines are visible I leave enough space for car next to me, if line is not visible I move back and go in. Now I find myself too close the other side since there is no line there. Ugh, first world problems
01-01-2021, 02:06 PM | #18 |
Rep 11
kkratochvil thanks for posting this and the SIB!
I have the same issue (see picture). I previously drive Mercedes and the Surround View was perfectly aligned, so I thought it's just BMW thing. My car have the latest update (07/2020.54) I am going to bring this to my dealer for service. Everyone else having the same issue but repaired by dealer (not software OTA update): how long did it take? Due to COVID, all dealers near my area no longer provide loaner. |
01-01-2021, 02:25 PM | #19 |
Rep 961
Drives: G87 M2, G20 330d, Brabus Smart
I recently developed this issue with first the front camera, and now the rear on my August build M50d. I plan on bringing it up to the dealer when I head there this coming week. Perhaps it'll be a quick software fix.
@DBV_
Current: '23 G87 M2 6MT / '21 G20 330d / '18 Brabus Smart Gone: '21 G05 X5 M50d / '18 MB C63s (632hp) / '16 F80 M3 6MT (570hp) / '09 F01 750i / '16 Abarth 595 Competizione (202hp) |
01-01-2021, 03:06 PM | #20 | |
Rep 459
Good luck! |
01-01-2021, 04:05 PM | #21 | |
Rep 11
This is the part that worries me. Had some issue with my previous car HUD and it took 2 dealers and a bit of arguing before the Service Advisor acknowledge the issue. I hope the dealer I am going to tomorrow won’t give me this grief. |
02-20-2021, 04:11 PM | #22 |
2019 X5 40i
115
Rep 226
Am also having the exact same issue, thanks for posting the service bulletin detail, easier to get this fixed with reference to the bulletin ..
Thanks
2019 X5 40i (Mar-2019 Build)
iDrive ver -- 03/2022.30 |
kkratochvil313.50 |
