      07-19-2020, 09:55 PM   #45
VTENGR
1053
Drives: 2020 X5 M50i
Those of us with B&W sound - if you have the speakers match the ambient colors, it looks like the door speakers stay with the stock color and the tweeters on the doors will be white or stock colors, depending on which color configuration you choose in the iDrive menu. It would be great if we could crack the code for these so we can have them match or increase the color combos.
      07-20-2020, 06:45 PM   #46
hkleyman
hkleyman's Avatar
Drives: 2019 BMW X5 50i M-Sport
Originally Posted by OzJedi View Post
Just tried my hands on few more colors.
Thanks to this post https://g05.bimmerpost.com/forums/sh...php?p=26169693 for sharing color codes
Awesome. My favorite is green and blue (with both colors set to regular FF values to get rid of the mint green and sky blue and make them true.)
      07-20-2020, 09:18 PM   #47
OzJedi
Australia
107
Drives: X5 2019 40i MSport Carb Black
Nice!! Green looks great with regular FF values, I also like CYAN and Yellow.
      08-20-2020, 11:28 AM   #48
Pumxee
Pumxee's Avatar
104
Drives: BMW X6
Anyone try and change the actual colour names in i-drive?
      08-20-2020, 11:31 AM   #49
Pumxee
Pumxee's Avatar
104
Drives: BMW X6
How has the OP's original post only been appreciated 9 times? Come one guys let's give credit where due. Thanks OP!
      08-20-2020, 02:58 PM   #50
130FeetDeep
Drives: BMW X5 M50i
Haha. Thank you!
      08-20-2020, 03:00 PM   #51
Pumxee
Pumxee's Avatar
104
Drives: BMW X6
Originally Posted by 130FeetDeep View Post
Haha. Thank you!
I just coded the red-blue combo into the bronze color space!
I still find it unbelievable the BMW has not enabled users to choose what color they want. I mean ford has been doing that since 2011.
I wonder wether bimmercode will create a standard mode option to allow for that.
      08-21-2020, 10:40 AM   #52
mnavis29
Drives: BMW 435xD
Anybody tried to access "360A LicLciColorLibrary" with Bimmercode 3.7 (10880) and iDrive FW 07/2020.35?
Getting the "no functions available" notification and am not even able to go into the particular file to change the HEX values.
      08-21-2020, 11:00 AM   #53
The J-Man
Drives: BMW
It appears there are 40+ colors already defined in the color library. It seems BMW may have put them there to open future colors? It would be helpful to figure out how the colors are mapped to the slots in the color profiles. That way, the BMW colors could just be used, but that may be more complicated, I'm not sure. I've also looked high and low for B&W settings and cannot find them in any module - speaking German would probably help, as they've probably named it something obscure. I find that leaving the speakers white is a good solution for now.
2020 X5 M50i Phytonic Blue/Black - PCD 10/21/2019
2015 i3 Rex Caparis White/Tera - Retired
2016 550i M-Sport Alpine White/Ivory - Retired
2011 X5 35i BSM/Black - Retired
2011 335i Coupe Alpine White/Saddle - Retired (ED)
      08-21-2020, 02:38 PM   #54
hkleyman
hkleyman's Avatar
An FYI for everyone, it was discovered on the 3 series forum that if you code any colors to the full FF values, the two small ambient lights on the roof function module (by the sunroof switch) will not illuminate upon vehicle startup. The only way to resolve is changing the color and changing it back, adjusting brightness or unchecking / checking the enable ambient light option will not resolve.
It seems to be a bug with any full values, whereas any amount of mix does not exhibit this issue. I set my green, blue, and red all to their FF0000 / 00FF00 / 0000FF values and have this issue with all of them.
The gent that found this out was able to only change the mapping for the one layer that controls those wash ambient lamps to be slightly mixed while leaving the door / dash / floor strips as full values and it resolved the issue for him.
      08-25-2020, 08:19 AM   #55
garysmith21
United Kingdom
30
Drives: X5 xDrive45e M Sport (ordered)
This would be a very neat solution if anyone has managed to do it?
      08-25-2020, 08:23 AM   #56
Pumxee
Pumxee's Avatar
104
Drives: BMW X6
I tried to snooze the settings but have no clue where this is and don't really want to experiment with it
Pum Performance Website Coming Soon!
BMW Parts and Accessories
https://pumperformance.com
      08-25-2020, 09:36 AM   #57
130FeetDeep
Drives: BMW X5 M50i
Can you elaborate what you mean “Ambient lamps to be slightly mixed while leave the door / dash / floor strips as full values”. You also mention full versus mix. Can you elaborate on that?
      08-25-2020, 10:34 AM   #58
VTENGR
1053
I think what he means is when you put in the hex FF0000 that's full red - 100%. If you do that it bugs out iDrive. However if you put in EE0000 that's so very close to red you will never tell the difference, but won't bug out iDrive.
      08-25-2020, 10:42 AM   #59
hkleyman
hkleyman's Avatar
Can you elaborate what you mean "Ambient lamps to be slightly mixed while leave the door / dash / floor strips as full values". You also mention full versus mix. Can you elaborate on that?
Yep sorry, I'm bad at explaining. That's exactly the issue. For some reason when you tell the system 100% of any of the colors, so the red led is 100% and the green and blue are off for example, the two small ambient lights near the sunroof controls don't turn on after the car fully sleeps.
      08-25-2020, 10:43 AM   #60
biterror
Finland
514
Drives: X5 45e 2021
FE0000 is the next smaller value for red. EE0000 is much smaller already. :-)
      08-25-2020, 01:10 PM   #61
VTENGR
1053
Yes, obviously. I was just using EE as an example. I'm guessing anything with the RED value above 200 will turn out red on the small LED strips we have (maybe even lower). Below that you're getting into the maroon/brick color territory.
      08-25-2020, 03:25 PM   #62
130FeetDeep
Drives: BMW X5 M50i
So going FE instead of FF will solve the overhead LED light issue? FF0000 correlates to 255 0 0 RGB. FE0000 correlates to 254 0 0 RGB. Honestly, the difference is not going to be detectable by the eye. Can we verify the FE0000 / 254 0 0 RGB will make the LED overhead splash lights work?
Once we verify, then I will update the DIY. I do notice that the other colors stock are using FE (254 RGB), so it appears you guys are spot on.
      08-25-2020, 03:34 PM   #63
hkleyman
hkleyman's Avatar
I have been meaning to correct in my vehicle and test but haven't gotten to it. I'll update the thread as soon as I confirm.
      08-25-2020, 04:20 PM   #64
130FeetDeep
Drives: BMW X5 M50i
If you can’t, then I will tonight. Do we know if the vehicle has to be just shut off to trigger the glitch? Does the DME have to go to sleep?
Honestly, looking at the other FE values / RGB 254, I am pretty confident that resolves this immediately. They must worry 255 will affect the life of the LED so explicitly choose 254.
      08-25-2020, 05:24 PM   #65
hkleyman
hkleyman's Avatar
The vehicle does have to fully sleep. It doesn't seem dependent on engine start (DME) but I assume BDC needs to sleep for it to happen.
      08-25-2020, 05:26 PM   #66
130FeetDeep
Drives: BMW X5 M50i
Perfect. Good teamwork to move this project forward. I will make the change to FE0000 / RGB 254/0/0 tonight and report back.
hkleyman135.00
