09-28-2020, 02:53 PM | #67 | |
Rep 165
When set to 100% that would be from what is allocated and not entire 24 kW pack correct? Its because you don't want to go 100% unless its 100% for the 17kW here in US for example. update. I think i found it. I believe its the battery control button correct? |
09-28-2020, 03:00 PM | #68 | ||
Rep 2,420
09-28-2020, 03:14 PM | #69 | ||
Rep 2,420
I charged up to 100% once before a week in the Austrian Alps last winter. I wanted to pre heat every day and couldn't charge. Really nice to get in a heated car and the snow and ice can just be pushed of the windows when it is freezing. |
09-28-2020, 03:19 PM | #70 | |
18136
Rep 11,752
Drives: 2018 M4 Comp Indv
09-28-2020, 03:21 PM | #71 |
Rep 165
GrussGott do you think its possible to increase the lock on US versions to at least UK kW size? Technically yes but BMW won't do it....i guess. Just curious why the difference other than "warranty"?!
09-28-2020, 03:33 PM | #72 |
Rep 4,326
Thank you X5 45e, GrussGott and ketrab for your info. GrussGott, I saw what you said about your info not being from X45e ownership but your info matches what I've been able to dig up elsewhere.
Looks like BMW put a lot of thought into this car, its actually quite nice for a luxo heavy cruiser and I can see the attractiveness to its design as a PHEV. Based on your feedback and what I've read, I now know a lot more about it and am glad I posted my query. Its just not the right car for the way we would use it. |
09-28-2020, 11:17 PM | #73 |
Rep 6,796
The percentage charge listed is not the actual bare battery charge level...it's the level the computer will let you use. The same is true at both the bottom and top of the charge. The computer won't let you fully charge OR discharge the battery to help preserve its life.
BMW's BEV i3 has a heat pump, but the REx version does not. So, it seems the addition of the hybrid may be the reason why it does not (yet?) offer a heat pump in their hybrids. It may be part of the other components heating/cooling requirements with an engine that make it complicated, and not desirable. Your electric range is based on a moving average of your previous driving. I do not know how big that window is, but on the i3, it's about 18-miles. BMW tends to reuse code where it's possible, so that algorithm may be similar in the 45e. I haven't driven my 45e enough to get a good feel for how it calculates EV range. At least at the temperatures I've seen so far, and the roads I've driven, I've done nearly 100% in EV mode. I did put it in sport mode for a short while, but only went a few miles. If you set a destination with the nav system, in hybrid mode, the car will try to manage the battery capacity to run out about when you reach your destination if the trip length suggests it will be useful, so it will also account for elevation changes, speed limits, and how long the trip is. this will allow it to use the electric motor to fill in for climbing hills and the occasional passing maneuver. If you don't set a destination, it cannot manage things as intelligently. So, even if you know the way, it may be beneficial to use the navigation system to set a destination. |
09-29-2020, 10:58 AM | #74 |
Rep 165
So what would be a purpose of even using this feature if its counter eco?! One would think that this regen takes no hit on consumption but I guess without going into the detailed design its hard to say why...
f25@110K and counting...
09-29-2020, 11:50 AM | #75 | |
Rep 2,420
Charging the battery with battery hold is not regenerative but active charging with the ICE. The ICE is powering the dynamo. Otherwise BMW has invented a way to create energy. I only use it when I need a charged battery. And I only need a charged battery to use pre heating or cooling when I am on holidays and I am not able to plug in during the stay. Pre heating is fantastic when the car is covered with snow and ice. And pre cooling the car when it is parked in the sun in the summer is too. Another reason could be to be able to drive electric into the city centre. It could be that in the future some centres would only be accessible for electric cars. So you would have to keep your charge for the city. It should do that anyway if you program it. But is not economic and not environmentally friendly either. |
09-29-2020, 02:25 PM | #76 | |
18136
Rep 11,752
As mentioned, the e-motor can either help spin the drive axle - or be spun by drive axle; and, of course, when the ICE spins the e-motor that charges the batteries, but also puts a new load on the ICE, thus the lower MPG. I'd use battery hold for the reasons X5 45e describes, and also for sport mode so I can have full power - since my primary reasons for getting the PHEV are lower acquisition & operating costs (if I want) and to start understanding the technology (including the trade-offs!). The X5 allows me to do that in SUV packaging and hopefully also provides a more chill experience (which I'm not sure I'll like )
09-29-2020, 02:55 PM | #77 | ||
Rep 2,420
The chill electric mode happened to me and others. And it is relaxing. Somehow it encourages to adapt a more relaxing drive. Releasing gas earlier to regen more and brake less and keeping it in electric for accelerating. You can drive fast, bot you don't have to. |
GrussGott18135.50 RaleighStEclaire26.50 |
09-29-2020, 04:12 PM | #78 | |
18136
Rep 11,752
This is exactly what I"m hoping for: given we won't be flying any time soon, our plan is to do a lot of road trips. In the past that was infrequent so we rented an SUV and my wife always says "how come you drive so relaxed on these trips but going to the grocery store is like Le Mans??" (I made her go to Le Mans). Fantastic to hear I can sport-it-up when I want (and it'll do it automagically) and also put it into spa-mode for a more relaxed chill cruise. |
09-29-2020, 04:30 PM | #79 |
X5 Enthusiast
461
Rep 762
Drives: 2021 X5
Immensely grateful to you all who is contributing on the 45e topic, especially X5 45e. You guys are awesome!
I know the BEVs are the future and wanted to get the 45e to enjoy some electric benefits. For me numbers not adding up for the 45e (lack of tax benefit, added costs, not enough savings etc.). Price difference between 40i and 45e in Ontario Canada is approximately 5700 Euro/$6700 USD/$9000 CDN/$9400 AUD considering home charger installation. Latest recall is giving me a chill as well (pun intended). BMW is relying on Samsung for battery tech, this doesn't inspire confidence either. Given that BMW is refreshing their models quicker than ever before do you guys think we might see an X5 LCI model as MY22? I don't know where iNext will be positioned. I would like BMW to address 45e's current shortcomings that we have discussed extensively? If no 22MY LCI then I'll conclude my position as either gasoline or BEV. I am not in a rush to buy now, but whatever I buy it'll be a long term purchase (at least 10 years). Would love to hear your opinion. Here is a latest video of the iNext. Looks smaller than X5 to me and have that huge grill at front. |
09-29-2020, 04:30 PM | #80 | ||
Rep 2,420
This function you can activate in vitalizing and relaxing mode depending on you state of mind After a long drive and starting to get tired vitalizing mode will give 3 minutes with an energyzing tune, cold air blowing in a activating pattern, car scent active, seat massage on max, , seat ventilation, opening the shade of the moonroof. It really is vitalizing. And if you are ready to loose it in a trafic jam you can put is in relax. Relaxing warmer air, seat heating, chillax yoga tune on the radio, gentle massage and relaxing interior colors. |
GrussGott18135.50 |
09-29-2020, 05:47 PM | #81 | |
Rep 165
09-29-2020, 05:52 PM | #82 | |
Rep 165
The federal 7.5k makes a difference definitely making phev no brainier. Tesla is still using Panasonic and other vendors for their batteries so I wouldn't worry on that part. The recall yes, I'm hoping this is going to be remediated quickly. As far as body refresh I've noticed that 2. This is going to be the 3rd year correct? |
09-29-2020, 06:38 PM | #83 |
Rep 6,796
FWIW, unless you turn on sport mode, the initial operational mode on the 45e is EV mode. It will activate the engine if you request more power than the electric motor can provide. The computer decides which mode, EV, motor, both will work best for your current driving needs and how you have it set. It's pretty seamless when it switches between modes, and the driver's display changes when the engine is on to show the rev counter versus power use.
09-29-2020, 08:17 PM | #85 | ||
Rep 2,420
09-29-2020, 08:22 PM | #86 | |
X5 Enthusiast
461
Rep 762
Drives: 2021 X5
MY22 will be the 4th production year, SOP sometimes in August 2021. It'll feel really bad if we get MY21 and BMW makes substantial updates in MY22.
2021 X5, Excellence, M Sport, DHP, DAP, RSE, MW, Merino.
09-29-2020, 08:28 PM | #87 |
Rep 2,420
US X5 45e owners...some data please!
In Europe we only get the rev counter in sport mode. In other modes the power and speed meters turn form blue (electric) to grey to show what engine is active.
The default start up is hybrid but you can set it to start op in electric individual. |
09-29-2020, 08:48 PM | #88 |
Rep 502
Seeing the G30 update this MY, I can almost guarantee you that there will be no substantial changes with the mid-cycle refresh. G05 is already on the latest CLAR modular platform using the latest interior design and iDrive 7.0 infotainment system. It will be very subtle exterior design changes and perhaps making a few options standard and adding a few new options and colors.
