10-07-2020, 09:07 AM | #1 |
Rep 121
Will 20x9 with 40 offset work all 4 corners
Hi,
I'm guessing yes but just wanted to check, found a wheel refinishing company that has stock of the 741m wheels but they list them as staggered sets with the 20x9 in front and 20x10.5 in rear, I want to do a square winter setup and they have 4 fronts available so just want to make sure they'll work all around TIA |
10-07-2020, 10:16 AM | #2 |
Rep 697
Are they OEM? I thought the 741M wheels are 21" in diameter? Also, I thought the front offsets are +37?
A square set up should work, although a 40 offset is 3mm less aggressive than 37. I see that you have an M-Sport; hopefully the 3mm won't cause issues with M-Sport brake clearance. |
10-07-2020, 10:19 AM | #3 | |
Rep 121
10-07-2020, 11:54 AM | #4 |
Rep 697
Got it. Then you are referring to the 740M wheels that are 20x9 +35. With that said, you should be good to run a square set of 20x9 +35 740Ms. I ordered a square set of wheels that are 20x9, although the offset is +30 for winter.
10-07-2020, 11:56 AM | #5 | |
Rep 121
