10-11-2020, 03:38 PM | #1 |
Rep 33
Air Suspension not back to normal height after lowered one level down
Hello Everyone
just kind curious I did manually lower -20mm at comfort mode after drove for a while at comfort mode and never exceed 70km even the car is in parked and did restart the engine the while the level control still indicate that the air suspension is in -20mm setting is that supposed need to be back to normal height +/- 0 please help Thanks a lot |
10-11-2020, 03:56 PM | #2 |
12885
Rep 19,397
That is normal, it will stay at the lower level until you switch drive modes, raise it manually, open your tailgate or remote start (last two being "features"). I use Adaptive as default and lower mine. I only have to lower it again if I remote start or open the tailgate.
FreddyBMW94.50 iconoclast7257.50 |
10-11-2020, 05:58 PM | #3 | |
Rep 33
raise it manually is definitely works did pressed the comfort button that go back to regular height but open tailgate and remote start keeps the same level -20mm my adaptive default as normal height |
10-11-2020, 06:06 PM | #4 |
12885
Rep 19,397
10-11-2020, 11:40 PM | #5 |
488
Rep 1,702
Can you share more info about the bug?
10-12-2020, 01:50 AM | #7 |
Rep 183
Also happy to know more about the bug. I have talked to my dealer about the car changing ride height sponaniously.
When I get out i often set the car to its lowest setting for my kids to be able to get in and out more easily (3 and 5yr olds) Sometimes after opening a door, or indeed maybe the trunk, the car goes back to its normal middle level. Perhaps this is part of the bug you are referring to. I drive a 45e with the latest software. |
10-12-2020, 02:04 AM | #8 | |
Rep 33
Havent try to open the tailgate but opening door is not affect for me lower down one level will not go back to normal height while i Have to raise up no matter the X5 is in parked, turned off or restart the system keeps the same level at -20mm |
10-12-2020, 06:51 AM | #9 |
12885
Rep 19,397
As has been mentioned, the vehicle goes to normal height after opening the tailgate or remote starting. We have been calling it a "feature" or bug in the other threads where it has been discussed but it very well could be by design. It also can be dependent on coding since many have changed the default drive mode.
Edit: I should add that it is likely the height goes up after closing the tailgate not when it is just opened. At least I have never noticed it changing right after it was opened and don’t think others have reported that either. So for accuracy the “feature” is when the tailgate is opened and closed. Last edited by TurtleBoy; 10-12-2020 at 04:00 PM.. |
Oigon210.00 |
10-12-2020, 06:54 AM | #10 | |
12885
Rep 19,397
10-12-2020, 01:08 PM | #11 | |
488
Rep 1,702
Remote start is OK because I think car should go back to normal height for safety reasons, especially if it was left at higher level for some reason, like getting out of low ceiling garage, you don't want it sitting too high.
10-12-2020, 01:19 PM | #12 | |
12885
Rep 19,397
