      10-18-2020, 05:22 AM   #1
rolllikero
Drives: BMW X5 40i 2020
How can I check if my car comes with anti dazzle?
Hi guys. I'm getting the G05 in India and it comes with the laser lights as standard. How can I check if my car comes with the anti dazzle function activated?
[IMG][/IMG]
      10-18-2020, 10:19 AM   #2
TurtleBoy
TurtleBoy's Avatar
12885
Drives: 2019 X5 40i,2021 M340i
Probably the easiest way is if the blue high beam light doesn't turn off when a vehicle is coming at you in the opposing lane.
      10-18-2020, 10:44 AM   #3
LexxM3
LexxM3's Avatar
1698
Drives: E46M3, G05X5
2019 X5  [0.00]
Check whether option 5AP is part your build. If it is, your anti-dazzle function was "decoded" and anti-dazzle is not turned on in your car. If 5AP is missing from your build, your lights should have anti-dazzle available and will be active in auto-high beams mode.
If you're doing a VIN lookup (or ESys FA read) to check your options, it will be called S5AP or S5APA).
      10-18-2020, 10:55 AM   #4
rolllikero
Thank you so much. I'll have to check with the VIN since I am not aware of how to check if it is part of my build in the first method you mentioned.
