      10-18-2020, 03:31 PM   #1
VTENGR
1053
Drives: 2020 X5 M50i
I want to take the dive to create my own XML / Cheat Code for all the coding I've done. I think I have it about 80% down, but I can't figure where the values for "start", "end" and "mask" are derived in the function parameters. What am I missing here?
Thanks.
Edit: was able to figure out that you extract this info from "storage info" found in Esys.
LexxM31698.50
      10-18-2020, 06:29 PM   #2
Deja011
Drives: BMW X5
Thanks.
Hi VTENGR,
You need to enable Function Memory.
Esysx -> Options -> Settings
Go to Options Tab and check Show function's memory layout in CafView"
Now you should see the memory as per the screenshot below.
LexxM31698.50
VTENGR1052.50
      10-18-2020, 06:42 PM   #3
Deja011
Drives: BMW X5
Sample Coding for LCA
<cafd id="000042C1" name="SAS3" author="Deja011" series="S18A">
<code description="[3/3]Automatic Lane Change Assistant(7083 3E52 42C1)">
<group id="3001">
<function start="137" end="137" comment="C_SWA_VORHANDEN" mask="11111111b">01</function>
</group>
</code>
</cafd>
      10-20-2020, 02:56 PM   #4
medphysdave
medphysdave's Avatar
Drives: M2 CS | 85 of 592
Following.
      11-04-2020, 07:37 AM   #5
VTENGR
1053
Thanks for everyone's help! I was able to create my own XML file but I noticed odd behavior with how Esys-X applies the changes. For one of the coding modules I want to change the value from "USA" with a werte value of "01" to "Allgemein" with a werte value of "00". When the cheat code gets applied it changes the werte value from "01" to "00" like it should, but the description cell above the werte value still shows "USA" instead of "Allgemein". Now I know when I code things manually I was told to never change the werte value and that I should always change descriptor cell to what I needed it to be and the werte value cell will automatically update. I'm not sure if I setup my XML incorrectly or if there's something else going on, or if this isn't anything to be concerned with. Can anyone shed some light on this for me?
      11-04-2020, 02:23 PM   #6
Deja011
Drives: BMW X5
Hi VTENGR
Save the caf and reload the same caf and check if the description is updated.
VTENGR1052.50
      11-04-2020, 02:30 PM   #7
VTENGR
1053
Originally Posted by Deja011 View Post
Hi VTENGR
Saving it did the trick - thanks for the help!!
