10-20-2020, 04:17 PM | #1 |
90
Rep 398
45e and don't plug it in
Hello,
Considering this option, but not having a charger installed in the garage. Anyone else not charge when they pull in to the home? We have had Lexus RX's previously and used them this way. Coming from X5d - like the mpg and also want performance. if MPPK was avail for 4.0, I may just go that way.... Thx |
10-20-2020, 07:35 PM | #2 |
Rep 531
i'm in your situation waiting to move to the next house where I already installed 240v out let and charger for our cars.
In meantime we use 115v and it's able to charge around 20miles overnight - actually more than enough for my wife daily commute so not a big deal. |
10-21-2020, 10:03 AM | #4 |
Rep 502
45e has about 20 times the battery size of the 450h hence the need to charge externally vs 450h's small battery pack quickly charging through regen and combustion engine. You really should charge 45e even if it is just the regular 110v plug otherwise you will get 40i fuel economy at best. Performance wise not charging externally shouldn't make any difference though...
10-21-2020, 06:08 PM | #5 |
90
Rep 398
Thx - did not realize there was a 110 option, but actually had a X3e today as a loaner. Overall a different ride than the X5, and so much tech in it I could not figure it all out in a day... :-( I need to check out an 45e and see vs th3 x5M.
10-21-2020, 07:38 PM | #7 |
Rep 6,789
If the battery is nearly flat, it can take longer than that! 10A * 120v = 1200W, and it's not perfectly efficient (like maybe low 90% range). 240vac is more efficient and doubles the power from the P=V*A formula, plus, can handle more amperage than the supplied device up to about 3700W maximum. Now, if you're where you get a 220-240vac unit, it's better, but still limited to I think 10A with the factory supplied unit.
10-22-2020, 02:23 PM | #9 | |
Rep 2,420
Without tax benefit it doesn't make sense to drive a 45e without charging. That said in Europe a big part of the PHEV never charge and are only purchased for the tax benefit. Some still have the charger wrapped in plastic in the trunk. |
10-22-2020, 03:03 PM | #10 |
Rep 6,789
Doubling the voltage, doubles the amount of power, so 10.5-hours on 220, is nominally over 20-hours with 120vac. BMW supplies an EVSE suitable for the normal plug-in voltage of the country it's sold in, so in the USA, we get a 120-vac device, which much of the rest of the world gets a 220-240vac one with their local country plug on it. So, in the US, the supplied EVSE probably won't recharge the battery fully overnight unless you don't use much! Throw in the conversion in the vehicle to DCV is less efficient with 120 versus 220-240, that can add some time and actually cost, too.
10-22-2020, 03:23 PM | #11 | |
Rep 2,420
Also interesting. The new My BMW app shows how much and how long the car charged. In this case I had no range left when plugging in (= 5% battery charge). It took +/- 10 hours and total of 23 kWh. The netto capacity in Europe is 21,x kWh. This was on 220V and the normal charger. |
10-22-2020, 03:26 PM | #12 |
Rep 6,789
Some of the power is related to the efficiency of the ACV-DCV conversion, some may be for the cooling. The efficiency of that conversion from 120vac is lower than that for 220vac, so that will affect things somewhat, too, as will the ambient temperature conditions and the battery temperature during the charging process.
10-23-2020, 02:44 PM | #13 |
Rep 50
You can probably get by with the 110 volt 10 amp charger. It will recharge the car at the rate of about 1 kWh per hour. The battery pack has 17 kWh of usable capacity. So it is easy to tell how much you will get based on the number of hours you are parked there each night. The EV range is about 2 miles per kWh. If you give it 10 hours of recharging time (8 pm till 6 am) then you will add about 20 miles of pure EV range to the X5.
These are all just rough estimates. Everyone is of course going to have difference circumstances. I personally think it is worth installing a level 2 charging unit in your garage. We are going to see more and more EV options in future years. Install something that can recharge at 240 volts and 48 amps. Be future proof. |
mdm_boulder9.00 |
10-23-2020, 04:41 PM | #14 |
Rep 6,789
What would be ideal is a big solar array with a large battery backup capability, and eventually, that might even support CCS charging rates, but it won't help with the X5. It might when more BEVs are around.
A 48A EVSE would require a dedicated 60A breaker in the USA and probably a fairly significant panel and supply. We haven't gotten to this in most places, but I expect in the future more demand charges...IOW, the more you COULD use, the higher the base rate you might pay. That exists around me for things like water supply, but not so much for electrical or natural gas loads. |
volodp196.50 |
