      10-23-2020, 11:21 AM   #1
iconoclast
Self-Deprecating Narcissist
iconoclast's Avatar
7266
Drives: Audi BMW Ferrari LR MB
K&N Drop-In Filter...
Does anyone on here know if K&N 33-3128 would fit X5 M50i? The angles at the very bottom look different. If these do not work any recommendation on which K&N will fit?
      10-23-2020, 12:22 PM   #2
BMWBear
Ultimate Driver
BMWBear's Avatar
Drives: N/A
A thread about K&N filters. I just flashed backed to 1995.
People still use those things over dry filters?
PhatBoyG211.50
      10-23-2020, 01:23 PM   #3
iconoclast
iconoclast's Avatar
7266
Yes. I have installed high flow intake filters on nearly every car I have owned or own. No different than Dinan or BMC air filters. There are few bench flow tests with results on here showing improved airflow however I simply would like a louder engine note at WOT and am not looking for any real WHP gains.
      10-25-2020, 04:50 PM   #4
M50iStiller
M50iStiller's Avatar
49
Drives: 2024 M340i Xdrive
Ben
_____________________
24 X5 50e - 24 M340i xdrive
22 992 GTS - 14 F-Type V8S
      10-26-2020, 12:16 PM   #5
denaliman
denaliman's Avatar
470
Drives: 2021 BMW X6M Competition
2013 X6M  [0.00]
Have you seen this:
https://www.schmiedmann.com/en/bmw-x...ct=ACCDA85-150
_____________________________________
2021 X6M Competition, 2021 Audi SQ5 Technik, 2013 Audi S4
      10-26-2020, 12:35 PM   #6
iconoclast
iconoclast's Avatar
7266
I have not but I would like to retain the OEM look however this may be a viable option down the road.
I did remove the charcoal emissions filters in the top half of the box and noticed there are two dummy flaps inside the lower half of the air box facing the firewall. I am sure they can be removed as well and it will improve the engine note but I believe it will suck in a great deal of hot air decreasing the output enough to be noticed. The filter you posted above may achieve the goal I am aiming for. Thanks for the lead and if I wind up purchasing I'll post details/review.
Additional filter discussion here for anyone who is curious:
https://g05.bimmerpost.com/forums/sh...php?p=26835977
      01-21-2021, 11:36 AM   #7
iconoclast
iconoclast's Avatar
7266
Finally something available:
M50i & X5M Fitment:
BMC code: FB01103
https://www.bmcairfilters.com/eng/ca...01103/1735/art
      01-21-2021, 03:13 PM   #8
VTENGR
1053
Drives: 2020 X5 M50i
M50i & X5M Fitment:
BMC code: FB01103
Does the M50i have the same intake as the X5M? They don't list the M50i as compatible, just the X5M and X5Mcs
iconoclast7265.50
      01-21-2021, 05:24 PM   #9
130FeetDeep
Drives: BMW X5 M50i
Click compatibility and you will see G05. It appears it does fit the M50i.
iconoclast7265.50
      01-21-2021, 06:52 PM   #10
iconoclast
iconoclast's Avatar
7266
I am fairly certain they are a match however I will test fit before I give official confirmation. I just need to find a vendor who can sell this to me since nobody has it or can get it.
      01-22-2021, 07:49 AM   #11
VTENGR
1053
Thanks - I've very interested in the before/after impressions. If you have a draggy, take some sample points from before and after.
iconoclast7265.50
      01-22-2021, 07:51 AM   #12
VTENGR
1053
I was just questioning it because on the website when you look at the engine trims, it doesn't list M50i or 50i, just M and M competition.
      01-22-2021, 11:03 AM   #13
130FeetDeep
Drives: BMW X5 M50i
There always has been a strong belief despite the difference in part numbers that the filters were the same. It can be something as simple as a denser filtrate causing less air flow. BMW is known for trying to separate the numbers of the M as much as possible, so it could be a purposeful choke point that they put it. The fact that BMC lists G05 is almost a confirmation of that point.
iconoclast7265.50
      01-22-2021, 11:05 AM   #14
iconoclast
iconoclast's Avatar
7266
Exact same thing on the F15 vs. F85. Filters were identical shape but the media was different. M50i and X5M SHOULD share the same filter but I will confirm once I have one of these in my hand.
