      03-09-2020, 02:00 PM   #969
samvora
The Dark Knight
samvora's Avatar
Drives: E36, E46, E90, G05 and MB W205
Originally Posted by ikheetleon View Post
You can automate this on iphone with the “shortcuts” app. As condition you can set it when bluetooth or airplay connection is made.
I wasn't able to figure this out. How would you do this to ensure that the moment I get into the car, the adapter connects to my phone bluetooth automatically and opens the bimmerlink app?
      03-09-2020, 03:21 PM   #970
ikheetleon
Netherlands
219
Drives: BMW X5 45e 2020
In the “shortcuts” app, in the bottom you have 3 options. The middle one is “automation”. Go there and choose “personal automation”. There you can choose carplay or bluetooth as condition, after that you can choose as action “open app”.
At first I couldn’t figure it out from the “my shortcuts” tab either.
      03-17-2020, 11:17 AM   #971
e45
Drives: 45e, GT3, 968CS
As I got 03/2020.30 there is basically nothing to program anymore (at least in standard mode), how long it normally takes for Bimmercode to update software to newest version?
      03-17-2020, 11:50 AM   #972
Resjudicata
Resjudicata's Avatar
Drives: M850i convertible
A while.
I call r33_RGSport to help.
r33_RGSport12971.00
      03-17-2020, 03:10 PM   #973
TSMC55
Australia
127
Drives: BMW X5 2019 GO5
I am on 03/2020.24 and can program everything that was available on 07/2019.xx since the last update a week ago (android beta). I would doubt there would be too many changes from .24 to .30. I would be surprised if it takes very long to update.
      03-18-2020, 06:48 AM   #974
ikheetleon
Netherlands
219
New version of the iPhone app is out. Version 3.5.
- "Body Domain Controller" coding for all G Series cars
- Updated coding data
- Bug fixes and stability improvements
eagle_bmw182.50
VTENGR1052.50
      03-18-2020, 08:10 AM   #975
eagle_bmw
Drives: 2019 BMW X5 40i
Thanks. Long press to AppStore -> Updates doesn't show BC so had to launch AppStore, search BC and update from there. Says released 13 hours ago. From previous beta testers it looks like the car can now be started in any drive mode, e.g., Adaptive or Sports+. Will have to try this out.
2019 X5 40i M-Sport
07/2020.54 -> 11/2020.50 -> 03/2021.50 -> 07/2021.85 [All OTAs]
      03-18-2020, 08:20 AM   #976
eagle_bmw
The list that can be coded has increased to 22 including driving mode, but there's no Sports+. Hopefully it is available in expert mode. I'd be happy with Adaptive, though.
2019 X5 40i M-Sport
      03-18-2020, 12:58 PM   #977
VTENGR
1053
Drives: 2020 X5 M50i
Just coded adaptive drive to default (iOS). Now when I have a minute or two I want to code aSLA. I'm thinking I can do it via bimmercode since the BDC has expert functions in it. Has anyone done it yet via bimmercode?
Edit: nevermind - doesn't seem you can code this via Bimmercode. Don't have access to expert mode for HU_MGU or the ECUs for SAS2/42C1. Guess I'll just keep waiting on Token Master for Launcher Pro.
      03-18-2020, 02:23 PM   #978
scottjays
Starfleet Command
scottjays's Avatar
315
what about coding for the rear deck lid to close from key fob?
      03-18-2020, 02:26 PM   #979
VTENGR
1053
Didn't see that. Maybe in expert mode.
      03-18-2020, 02:31 PM   #980
mobilejo
mobilejo's Avatar
United Kingdom
1115
Drives: G06 X6 40i
UK cars allow you to close the trunk from the key fob, but the button has to be held down during the process.
Using Bimmerlink, I was able to code it so it works with one touch of the button.
Not the same as what you're trying to code (I understand that in America, the trunk cannot be closed from the fob at all right?) but if Bimmercode can access that module for the coding that I did, it should at least be possible to code what you require in expert mode shouldn't it?
      03-18-2020, 02:42 PM   #981
ifr
ifr's Avatar
United Kingdom
1198
Drives: Tesla MY LR AWD
You might have a long wait.
Mappings are messed up for newer codes anyway. I'd just get esysx. Much better product and obtainable.
      03-18-2020, 02:53 PM   #982
VTENGR
1053
I may just have to do that. Feel like a fool donating to TM though only to get EsysX.
      03-18-2020, 03:08 PM   #983
ifr
ifr's Avatar
United Kingdom
1198
Just look on it as a charitable donation.
It's not that pricey in the grand scheme of things. You only need to avoid 1 speeding ticket to be on your way to making your money back
      03-18-2020, 03:24 PM   #984
VTENGR
1053
Very good point!
      03-18-2020, 06:17 PM   #985
X54TH
Member
X54TH's Avatar
899
Drives: 2019 X5 40i M Sport
If I recall you can just go into Sport Individual and change all the Options to Sport Plus.
I set my to Adaptive as well.
2019 X5 Alpine White M-Sport
Software Version 11/2022.31
2023 M2 (HEA) Brooklyn Gray
2021 330i XDrive Alpine White M-Sport
      03-18-2020, 06:33 PM   #986
James_G0540i
Australia
446
Drives: 2021 X5 G05 40i M Sport
My advice would be to not code the car to start by default on Sports+.
I have my default at startup set to "Adaptive", but I would only use Sports+ mode after the car has warmed up and at normal operating temperature.
Sports+ really opens the car up, throttle and transmission wise - and I wouldn't want to use those until the engine and transmission is warm, else you risk damage.
LexxM31698.50
eagle_bmw182.50
      03-18-2020, 06:38 PM   #987
LexxM3
LexxM3's Avatar
1699
Drives: E46M3, G05X5
2019 X5  [0.00]
Sport+ can be coded in Expert Mode as follows:
  • BDC ECU
  • Expert Mode
  • search for FesPiaDefaultLastUserMode
  • change it to 02 for Sport+
  • Code
Note: per @James_G0530d, with great power comes great responsibility -- if you code Sport+ start mode, take care to not rev high from cold. It takes some self-control, but no different than older M cars required.
A more complete but still partial table for FesPiaDefaultLastUserMode modes is as follows (there are additional PHEV, etc. modes as well):
  • 01 = Sport
  • 02 = Sport Pro/Plus
  • 03 = Sport Individual
  • 04 = Comfort
  • 05 = Comfort Plus
  • 06 = Comfort Individual
  • 07 = Eco
  • 08 = Eco Plus
  • 09 = Eco Individual
  • 0A = Adaptive
Appreciate 3
      03-18-2020, 06:40 PM   #988
eagle_bmw
  • BDC ECU
  • Expert Mode
  • Code
  • 01 = Sport
  • 04 = Comfort
  • 05 = Comfort Plus
  • 07 = Eco
  • 08 = Eco Plus
  • 0A = Adaptive
Thanks LexxM3 !
2019 X5 40i M-Sport
      03-18-2020, 06:43 PM   #989
LexxM3
LexxM3's Avatar
1699
2019 X5  [0.00]
My perception is that Sport+ is greater than Sport Individual all turned up to Sport+ settings — I don't think these are equivalent.
      03-18-2020, 06:44 PM   #990
eagle_bmw
Good point, wife won't like it as well.
2019 X5 40i M-Sport
