      01-30-2022, 12:53 PM   #199
IFlyX5
IFlyX5's Avatar
Drives: '21 X5 s40i, '22 X5 x45e
Originally Posted by antonkrajzler View Post
Hello everyone )) Who needs to make ambient lighting B&W, write in a personal, I'll do it
Magenta color in the photo
Please post the instructions here so we all can read. Thank you!
2021 G05 X5 s40i Phytonic Blue | Ivory White Vernasca | Anthracite-Brown Poplar Matte Trim
2015 F10 535i M-Sport Space Gray | Black Nappa (Gone)
Appreciate 3
mobilejo1114.50
thereef5101165.00
      04-17-2022, 04:38 PM   #200
Xmel`
Drives: BMW X5 G05
Here you go.
I modified the blue scheme
with red lower colour and red B&W all around.
But you can change whatever you want
So we need to change some parameters in RAM.
- 3004 (from 1 to 7 scheme)
- 3005 (from 8 to 11)
It almost the same as we did with other lights but the RGB code is located in 3 lines (1R,1G,1B)
So in AMBIENTE_FARBE_ENSEMBLE_6_LAYER_1_R
6 is the blue scheme that we want to change
1 is the place of the speaker (two upper front speakers)
Global it looks like that
RAM
XX_LAYER_3 - B&W (weiss)
XX_LAYER_1 - Hi (weiss/colour)
1_LAYER_(1-6) - bronz
2_LAYER_(1-6) - bronz/weiss
3_LAYER_(1-6) - orange
4_LAYER_(1-6) - orange/weiss
5_LAYER_(1-6) - weiss
6_LAYER_(1-6) - blau
7_LAYER_(1-6) - blau/weiss
8_LAYER_(1-6) - gruen
9_LAYER_(1-6) - gruen/weiss
10_LAYER_(1-6) - viol
11_LAYER_(1-6) - viol/weiss
You should on/off or reboot your i-drive after coding for modification to take place.
Good luck and share your variants
mobilejo1114.50
zztops327.50
      10-10-2022, 01:02 PM   #201
Setarcos
Setarcos's Avatar
Drives: 2023 X5 xDrive 40i
  [0.00]
Has anyone figured out what one needs to set to gradually cycle from one color to another such as shown in the 3rd video in the post here: https://g30.bimmerpost.com/forums/sh...32&postcount=7 For whatever reason this info seems to be impossible to find...
      10-11-2022, 10:13 AM   #202
elite-fusion
Drives: 335xi
I'd be kinda interested as well
      10-22-2022, 10:17 AM   #203
SLF80
Drives: 2014 F80
Is it possible to rename the color in iDrive?
Or does everyone live with the factory color names, even after coding a custom HEX color value?
      10-22-2022, 02:34 PM   #204
x1noob
Drives: 2020 X5
Originally Posted by [B
*Note... for anyone creating custom colors, you should not use any HTML hex code with the value FF. Substitute FE for the FF part of the HTML hex code and it will look exactly the same but won’t affect the overhead splash LEDs that shine on the shifter area.[/B]
Thanks for this tutorial OP. Much appreciated. Excited to be doing this for my G05. What adapter should I get for a fast connection? Ethernet? Wifi? or Bluetooth?
      10-22-2022, 08:29 PM   #205
IFlyX5
IFlyX5's Avatar
Ethernet is the fastest.
x1noob3.00
      01-19-2023, 10:26 AM   #206
Mitchfin
Mitchfin's Avatar
97
Drives: 2019 BMW X5
Originally Posted by Xmel` View Post
Here you go.
RAM
Thanks for this, can confirm that this works on Bowers and Wilkins systems. It even changes the color of the Bowers and Wilkins logo.
2019 X5 40i
CHP | B&W | Executive | M Sport | DAP | Carbon Blue | Tartufo
      03-11-2023, 02:34 PM   #207
cyberacid
cyberacid's Avatar
Drives: BMW X5
Anybody has a clue for the gradual change effect? It seems to be top secret information
Thanks!
      03-21-2023, 04:35 PM   #208
denaliman
denaliman's Avatar
470
Drives: 2021 BMW X6M Competition
2013 X6M  [0.00]
Did bimmercode remove the ambient light option? I don’t have it in any module. 2021 X6M. I just wanted to use the bimmercode “stock” change from bronze to red.
_____________________________________
2021 X6M Competition, 2021 Audi SQ5 Technik, 2013 Audi S4
      03-28-2023, 04:24 PM   #209
zztops
Drives: 2013 328i (N26) F30 M SPORT
Here you go.
You, Sir, are a legend. At first glance I thought it could only be done via Esys, but they do have the module in bimmercode. Just in an entirely different section called “Receiver Audio Module” my dumb @ss didn’t marry that with the “RAM” you posted above and assumed it meant “random access memory” haha the rest of what you had was verbatim the same in bimmercode. Now me and my Darth Daddy Cruiser (her actual name is Coco) are happy! Thanks a million!
      04-17-2023, 07:39 AM   #210
Kool Kat
Kool Kat's Avatar
Drives: 2022 BMW X6 M50i
2022 X6 M50i  [9.50]
I just had the software update and it undid all my coded changes. This thread is somewhat confusing to a coding rookie. Can someone simplify instructions for how to change my lighting to all red? From there I should be able to figure out other colors. Thanks.
      04-17-2023, 02:13 PM   #211
Chick Webb
Drives: '10 E92, '17 540i, '21 X6 M50i
This is my synopsis of the instructions first posted here:
The stock RGB HEX codes are:
  • White - 90, E0, 90
  • Bronze - D7, 6E, 14
  • Orange - 93, 1A, 01
  • Blue - 00, 20, FE
  • Green - 10, FE, 32
  • Lilac - 78, 3C, FE
The byte numbers for the colors GO5G06_Lichtpaket_code1 packet are as follows:
  • White: 3,4,5 - 8,9,10 - 13,14,15
  • Blue: 18,19,20 - 23,24,25 - 28,29,30
  • Bronze: 33,34,35 - 38,39,40 - 43,44,45
  • Orange: 48,49,50 - 53,54,55 - 58,59,60
  • Green: 63,64,65 - 68,69,70 - 73,74,75
  • Lilac: 78,79,80 - 83,84,85 - 88,89,90
The the G05/6 color assignments (i.e., the value that should be in the profile to get each color) are:
  • 00 - White
  • 01 - Blue
  • 02 - Bronze (now red for me)
  • 03 - Orange
  • 04 - Green
  • 05 - Lilac
So, generally, in order to change a color from one to the other, you have to change the values at the bytes listed above to the color that you want. One RGB hex value goes in each byte. If you change all 3 byte triples for the Bronze color to the color value for Red, then everywhere the system thinks Bronze is selected you’ll get Red instead.
Now, how does the system know when Bronze is selected? That’s in the profile, where the colors that you get when you select them in the display menu are determined by two bytes. The first is the bottom color, and the second is the top color. The first two bytes correspond to the first entry in the display menu, which is Bronze. The second two correspond to the second menu entry (Bronze/White), etc. So if you just want to change Bronze to Red you don’t need to do anything. BUT, if you want to change Bronze/White (really now Red/White) to Red/Blue, you’d change the 3rd byte in the profile data from 00 (White) to 01 (Blue).
Changing Colors in Expert Mode
  1. Connect to car, go into Body Domain Controller
  2. Enable Expert Mode
  3. First, change the colors. Go to 360A LicLciColorLibrary
  4. Go to LIC_LCI_COLOR_LIBRARY_DATA
  5. Go to the GO5G06_Lichtpaket_code1 packet. Note, this should have a check next to it. Highlight it and click the custom values down bottom to enter into the bytes section that needs to be modified.
  6. Change the appropriate bytes to new RGB Hex values.
  7. Save your work.
  8. Now, change the profiles that determine where the colors appear. Go to 360DLicLciColorProfiles.
  9. Go to LIC_LCI_COLOR_PROFILES_DATA.
  10. Go to the G05G06_Lichtpaket_code1, select it, then go to custom values at the bottom of the screen.
  11. Change the appropriate bytes to get the color combos that you want:
  12. To make Bronze/White to Red/Blue, change byte 3 to 01
  13. To make Blue/Whte into Blue/Red, change byte 11 to 02
  14. Save your work.
  15. Code the module.
Hope that helps. Coding, of course, is done at your own risk. I'm not responsible for any issues caused by following the above.
      04-17-2023, 04:21 PM   #212
arRod1981
arRod1981's Avatar
Drives: 2022 BMW X5 45e M-Sport
White - 90, E0, 90
Bronze - D7, 6E, 14
Orange - 93, 1A, 01
Blue - 00, 20, FE
Green - 10, FE, 32
Lilac - 78, 3C, FE
00 - White
01 - Blue
03 - Orange
04 - Green
05 - Lilac
Now, how does the system know when Bronze is selected? That’s in the profile, where the colors that you get when you select them in the display menu are determined by two bytes. The first is the bottom color, and the second is the top color. The first two bytes correspond to the first entry in the display menu, which is Bronze. The second two correspond to the second menu entry (Bronze/White), etc. So if you just [...]
You don't need to go into Expert mode to change all the colors to red. Just select the Bronze (default) and change it to red. It's what I did and works perfectly.
      04-17-2023, 05:56 PM   #213
Kool Kat
Kool Kat's Avatar
2022 X6 M50i  [9.50]
Really appreciate both replies. I was able to follow the details better. Your breakdown made things much clearer. I also stumbled across where you can change the default without being in expert mode (after I updated the bimmercode app). Bottom line...got 'er done! Thanks for the help. I'm a simple dude that likes simple explanations in layman's terms. This forum is very helpful.
      04-18-2023, 10:47 AM   #214
Chick Webb
Yes, I'm aware that you can change bronze to red w/o using expert mode. These instructions are what I have used several times (including last night after the latest update) to set "white/bronze" to "blue/red" and "white/blue" to "red/blue). Which must be done in expert mode.
FYI, there's a typo there at the end. It's not Byte 11, it's Byte 13 that holds the white value for "white/blue". If you change Byte 11, it'll change "blue/blue" to "red/blue". Sorry for any confusion.
      08-08-2023, 02:45 AM   #215
dayfly
12
Drives: X5 45-E
Blue
My blue is not as blue as others x5 cars that i see, its more sky blue.
Anyone know the code to change it to the dark blue
      11-15-2023, 05:14 AM   #216
almostgreen
Drives: BMW X5
Arrow
HI! I just did exactly like you have done it and the green and white are now red and blue but all other colours are white now. if i want to change to lilac lets say, it turns white and all the other colour as well. only green and white are red and blue. is it how its supposed to be, or i messed up something? thanks.
      03-06-2024, 07:51 AM   #217
SulaimanEK
Saudi Arabia
Drives: BMW X6 M50i 2020
Originally Posted by VTENGR View Post
Just ran my little experiment. Nothing changed if I just changed one HEX code within a color slot. What I did notice when I turned the B&W speaker color on is that the old color slot is what the speaker showed. So for example, if I changed the Green color slot to RED, my ambient lights will be red, but my speaker was still green. This was the case for all the colors. My speakers will showing the old colors even though they had been coded to different HEX. That means there must be another module somewhere that controls the speaker colors too. That's good and bad news ... the good news is, you can code your speakers to be any color you want. Bad news is, we have to find that module.
You could just leave the speaker color to white in the the infotainment screen rather than the goofy green or what other color that bothers you.
      04-13-2024, 04:41 PM   #218
F85Matt
F85Matt's Avatar
217
Drives: 2020 X3M / 2018 M3 / 2002 M3
Won’t let me pm you
Attachment 2800911
Attachment 2800912
