      06-26-2021, 01:14 PM   #23
Tenac
Tenac's Avatar
4539
Drives: All
Originally Posted by HZX540e View Post
If someone told me about this I wouldn't believe them. As you know the flaps on my FI exhaust are always open (I took the plug out after they were opened). When I press the exhaust button (in the car next to the shifter) to the off position the car does NOT pop on up shifts. When I press it to the on position (green light on) the car pops like crazy on up shifts. You hear it in the videos I posted. The crazy thing is that I thought this button controlled the flaps and active sound. Well the flaps are always open on mine, so the button must be doing something to make the car pop so loud (no the sound is not from inside the car, see the video).
I learned something new today.
Funny you caught this as well. I have a local performance shop digging into it. So far the thought is just like programming the exhaust burble out of the newer cars from BMW this puts some back in.... Only issue is to confirm that we would need to crack a bench tune which no one local here will. So by pressing that button on we are basically enabling a medium setting in the ECU.
2022 M8 Comp Convertible
2023 718 Cayman GTS 4.0
2019 718 Cayman Base
2015 M235 Manual
On the list for the M2 CS
HZX540e373.50
      06-26-2021, 01:58 PM   #24
HZX540e
HZX540e's Avatar
Drives: 2021 X5MC
I discovered it by accident, I wanted to hear what it would sound like without active sound and I noticed that the up shifts pops were completely gone. Pressed the button and it was a different car all together. It must be ECU drive, interesting to see what it actually is.
Tenac4538.50
      06-27-2021, 08:51 PM   #25
HZX540e
HZX540e's Avatar
Drives: 2021 X5MC
I will post detailed instructions and videos. For now I installed the FI Exhaust secondary down pipes and cat delete. Leave it up to BMW stupidity to put bolts in places impossible to reach. Took about 8 hours with simple metric tools, and the level of difficulty is about 6 out of 10 for a handy person, I think a pro can complete this job in 4-6 hours.
      06-28-2021, 09:22 PM   #26
HZX540e
HZX540e's Avatar
Drives: 2021 X5MC
I have looked everywhere but could not find instructions for replacing the secondary downpipes on F95. Many thanks for Ben from RGSports for insight and tips. It goes without saying, if you are a motor head like me Invest in a quality metric tool set, sockets, torx…. Etc. having an impact drill and torque wrench will come in handy for the exhaust removal part. A safe and secure way to lift the car is a must. Below is the step by step process with pictures. It helps a lot if you remove the entire exhaust you need the room.
1. In the engine bay, all the way in the back.Remove the wire brace, 2 torx screws on the side and one nut holding a reservoir. This is tricky because the passenger side one is under a wire then unclip the wire from the sides and use a flat head screw driver to remove the middle piece (image courtesy of dpie)
2. Use a ratcheting wrench to remove the downpipe screws (image courtesy of dpie). They are facing the heat shield on the firewall. Do not drop the wrench! Once the screw is all the way loose, use a flat head screw driver to pry open the clamp
3. Under the car: Remove a what appears to be a useless square metal piece under the transmission. It is held by plastic nuts on the sides and two metal screws to the underbelly
4. Remove the 2 11mm nuts holding the downpipe to the side of the engine. Use an extension bar along with swivel joint head that's the only way to get to these nuts
5. Now that the down pipes are free to slide out, mark them L/R as they're not identical
6. Match your new downpipe to to the ones you removed to know which one goes on the right or the left
7. If your new downpipes didn't come with the gaskets. Carefully remove the only one to the new set (thanks Ben RGSport)
8. Slide the new downpipes into place, put the clamp on the downpipe before sliding it back into position
9. Align the downpipes to the 2 screws protruding from the engine and place the nuts without tightening
10. Align the secondary downpipes to the primary downpipes
11. Now move back to the top of the engine. This trick alone is worth a lot of money. Position the clamp so that the primary and secondary downpipes are perfectly aligned then get a zip tie to pull the clamp ends closer to each other. Thread the clamp screw back on and tighten it back in place
12. Slide back under the car and tighten the 2 screws holding the down pipes to the engine
13. Slide the exhaust back on
14. Reverse steps 1, 2 and 3
Appreciate 4
155ND907.00
FiEXHAUST196.50
ed41367.50
      06-28-2021, 09:41 PM   #27
dpie
dpie's Avatar
Drives: X5M
Nice write up! Glad you were able to tackle it.
HZX540e373.50
      06-28-2021, 10:06 PM   #28
HZX540e
HZX540e's Avatar
Drives: 2021 X5MC
I received the FI Secondary Down Pipes (cat delete) and installed them on my F95 (see instructions above). Other than a glitch that I am still working with Chris Kuo, things were pretty smooth. The sound quality and loudness is day and night from stock exhaust and noticeable improvement from just that catback system. I recommend setting the full down pipes and exhaust system to unlock the full potential of this beast. As you know I have the flaps forced open all the time, I am tempted to reconnect them to control closing them especially for late night pull into the neighborhood. I have some videos and sound clips, waiting to resolve the issue with Chris from Fi Exhuast before I upload the videos.
If anyone in the DC DMV area has APK or just down pipes I would like to meet to compare the FI System to others.
hdahman236.50
      06-29-2021, 10:20 AM   #29
hybrid_eg
hybrid_eg's Avatar
Drives: 90 S13, 22 MSP, 23 JLUR 4xe
that definitely sounds like its tied to burble mapping or what not but a very tame one.. someone on this forum told me that ASD is integrated into the amp on F95/96 chassis unlike on F85 where you could simply unplug the connector.. so that's disappointing.. those with aftermarket exhaust systems will have to put up with ASD until coding is available at which time likely it can be coded off while retaining same pop's on upshifts.. (or more pops/bangs for those who desire).
Retired: '02 E46 M3, '02 E46 M3 Vert, '11 E90 335d, '15 F10 M5, '17 F85, '18 F90, '02 E46 M3, '21 F96 Comp
HZX540e373.50
      07-04-2021, 10:45 AM   #30
HZX540e
HZX540e's Avatar
Drives: 2021 X5MC
Sorry about the delay in posting the videos. Enjoy the sound, turn the volume up to feel the joy of unleashing this beats.
Setup for these videos. Secondary cat delete with FI Exhaust Down Pipes and exhaust Cat Back system (flaps forced open all the time).
https://youtube.com/shorts/1LFF3BkUvvY?feature=share
https://youtube.com/shorts/SdguKvJiLD0?feature=share
https://youtube.com/shorts/cqqteHYtEsg?feature=share
https://youtube.com/shorts/-sIo4FA_-Qc?feature=share
P.S. Recorded in a private parking lot with permission.
ed41367.50
FiEXHAUST196.50
      07-05-2021, 01:59 PM   #31
zjaiz
zjaiz's Avatar
Drives: F95 X5MComp
sounds amazing .. guess this is gonna be my next move
HZX540e373.50
FiEXHAUST196.50
      07-06-2021, 11:56 AM   #32
hybrid_eg
hybrid_eg's Avatar
sounds great!! reminds me of my screaming remus F90 exhaust..
ed41367.50
      07-07-2021, 05:58 PM   #33
bellabimmer
Drives: BMW X5M F95
those bangs in gearshift do they happen just with exhaust upgrade or secondary downpipe is a must can somebody tell me ?
I have X5M EU version so soon I will install exhaust without OPF so I am interested to know this info.
      07-07-2021, 06:26 PM   #34
HZX540e
HZX540e's Avatar
Drives: 2021 X5MC
Remember I installed the catback exhaust system and used it for 3-4 weeks before adding the catless secondary downpipes. Your hear the pops on up shifts WITHOUT the downpipes, but with the downpipes they become way more prominent, much louder and crisper (if that makes any sense).
ed41367.50
FiEXHAUST196.50
      07-07-2021, 09:52 PM   #35
ed4
ed4's Avatar
1368
Drives: '21 F96 X6MC, '18 G30 M550i
… sharper and louder burps and snaps!
'23 F93 M8 GC ZCP
- HRE S101SC - Full Akrapovic - '15 Audi R8 4.2 S-Tronic
(Past) YouTube '21 F96 X6M ZCP Akrapovic/MSS/BC Forged, ‘18 G30 M550i, '18 G01 X3 M40i, '15 F10 M5 ZCP HRE S101 #1 & #2/Akrapovic, ‘13 W204 C63 AMG - ADV1 5.01SL's
FiEXHAUST196.50
HZX540e373.50
      07-15-2021, 06:34 AM   #36
HZX540e
HZX540e's Avatar
Drives: 2021 X5MC
The FI Exhaust with forced open flaps made me realize I'm not 17 anymore. The dealer pulled up driving my car right after a cold start, although the sound was amazing I couldn't see myself leaving a business meeting like this. So, I reconnected the flaps wires again. The car can drive in well behaved adult mode. And with a push of a button (or even just pressing the gas hard) the beast wakes up and the roaring begins. I love having this option, so it's not loud all the time but can be when you want it.
Appreciate 4
ed41367.50
Alan l.5450.00
-Vanguard-1177.50
Mr.blue223.00
      08-05-2021, 10:37 AM   #37
DeeM3
Drives: M
Did you get a CEL with the secondary down pipes?
HZX540e373.50
      08-05-2021, 11:56 AM   #38
HZX540e
HZX540e's Avatar
Drives: 2021 X5MC
No, and I shouldn't because in the US the second cats are NOT monitored
ed41367.50
      08-05-2021, 12:09 PM   #39
DeeM3
Drives: M
Thank you, sir! Inspiration for my next setup.
ed41367.50
HZX540e373.50
      08-05-2021, 12:36 PM   #40
ed4
ed4's Avatar
1368
Fantastic inspiration 👊
'23 F93 M8 GC ZCP
HZX540e373.50
      08-05-2021, 01:10 PM   #41
HZX540e
HZX540e's Avatar
Drives: 2021 X5MC
You won't regret it.
      08-06-2021, 07:13 PM   #42
mokest03
mokest03's Avatar
Drives: F95 X5MCS
Sticks out way too far.
2009 E92
2013 S4
2016 RRS SC
2018 440I GG
2019 M550i
HZX540e373.50
      08-06-2021, 07:42 PM   #43
HZX540e
HZX540e's Avatar
Drives: 2021 X5MC
I agree, they've been readjusted a while back. I need to upload new photos.
      08-06-2021, 11:48 PM   #44
RyanBMW
RyanBMW's Avatar
Drives: 2008 E92 328i, 2011 F10 550i,
Not impress!
HZX540e373.50
