      03-28-2024, 12:34 PM   #1
PattoLFC
Drives: 320d Sport
Leaking Sky Lounge Roof?
Hi,
Has anyone came across a leaking sky lounge roof before? Purchased a 19 plate X5 a few weeks ago from a BMW dealership, had a few issues shall we say, then discovered this earlier when driving it in the torrential rain.
I've double checked the roof and it's shut properly etc.
Video: https://streamable.com/8nnx4q
Thanks
      03-28-2024, 12:40 PM   #2
Marty in NY
Marty in NY's Avatar
Drives: 21 X5 40i, 18 GTi, Snowblower
Originally Posted by PattoLFC View Post
Hi,
Thanks
That's a "somewhat" common issue on the early G05 years, like yours. There are quite a few posts on the forum pertaining to the symptom, like yours, and the solution. As I recall, it was either from plugged sunroof drains or defective sunroof seals that seemed to have shrunk over time thereby leaving a gap for water to get it. Even so, if water gets in, the drains should adequately handle it so my bet would be plugged or partially plugged drains.
Do a search on the forum for it and you will find some nice details and helpful instructions. If you have a warranty, you could simply go complain to your dealer and let them sort it out
      03-28-2024, 12:42 PM   #3
dream54ing
dream54ing's Avatar
Drives: 428xi F32- X5 X5 G05 -640i F06
Might be from the antenna fin. I recall reading a while ago there were some issue from there.
      03-28-2024, 12:46 PM   #4
bandersen
Drives: MY22 X5 40I M-Sport
Can you describe exactly where you are seeing the leak/water?
      03-28-2024, 12:55 PM   #5
PattoLFC
Drives: 320d Sport
Front driver side roof vent is it? In the video it shows it :-)
Entire area around it is soaking wet.
I only purchased it a few weeks ago so I'll complain to the dealership, well add it to the list of issues I've had with the vehicle so far!
bandersen590.00
      03-28-2024, 12:57 PM   #6
Marty in NY
That's a microphone, you have or should have two, one for the driver and one just like it for the passenger.
      03-28-2024, 12:59 PM   #7
PattoLFC
Drives: 320d Sport
LOL, I'm an idiot, yeah you're right.
Guess that is getting piss wet through currently then
      03-28-2024, 05:58 PM   #8
Marty in NY
Here is one such thread on the leaking sunroof issue...there are many others. https://g05.bimmerpost.com/forums/sh....php?t=2091840
      03-28-2024, 06:27 PM   #9
malvern_man
United Kingdom
520
Drives: X5 40i xDrive
I've just got my 22 plate back from the dealership, it's the 3rd time it's been in for a sunroof leak, from the microphone. This time they've changed every seal possible in the sunroof, under warranty. Let's hope it's 3rd time lucky.
Ask your dealership to check that the drain tubes aren't blocked, drivers and passenger sides.
      03-29-2024, 09:25 AM   #10
MissVito
MissVito's Avatar
217
Drives: '24 X5 M60i, M240ix
4 weeks after I picked up my brand new ‘21 it got a leak that appeared at the microphone area above the driver’s head. It happened when it was only a misty rain. Took it to the dealer and they found that the moonroof’s cassette had a fine crack in it. None were available in the country at the time during Covid so it sat in the shop for 40 days waiting for a shipment to come from Germany. It was a manufacturer’s defect and no problem after that. It was a known issue.
'24 X5 M60i Tanzanite Blue II/Coffee
'21 X5 M50i Tanzanite Blue II/Coffee (RIP)
'21 M240ix Long Beach Blue Metallic/Red
'14 X5 s35i Lux Line Mineral White/Mocha (re-homed)
