      01-02-2020, 07:55 AM   #23
LexxM3
LexxM3's Avatar
1698
Drives: E46M3, G05X5
2019 X5  [0.00]
Originally Posted by maczrool View Post
Anyone have a link on how to use the cheat codes with Esys? I've been looking for days and can't find anything.
https://github.com/jokinawa/bmw-f/bl...s/jokinawa.xml
- simplest is to get a github account and then download the file above; you can also just copy-paste-save from the file box at link above, but more prone to copy-paste errors
- cheat files are actually handled by launcher, not directly by ESys, although the launchers incorporate its use into ESys; as such, how cheat files are handled is not the same between Launcher Pro and ESysX; ESysX can only handle a single file at a time, configure in setup
- when you open an ECU image (NCD file) in the FDL Editor that matches a set of cheat codes for that specific ECU in the cheat file, you'll see the cheat codes in a box on the right
- you'll want to get at least superficially familiar with the format of the cheat codes XML file; cheat codes are a convenience, you still need to be clear about what you're doing and to which ECU you're doing it to; once you can accurately read the cheat code file, you're both ready to use it and don't actually need it
- note that cheat codes are for FDL coding (individual parameters); VO coding (feature/option-level coding) doesn't require either launchers nor uses cheat codes
      01-02-2020, 08:10 AM   #24
maczrool
Drives: 22 M50i Carbon Black
Awesome, thanks! I had that but is there anything that tells you how to use it? So if you have Esysx do this, if you have Launcher Pro, do this. That's what I'm looking for and coming up empty.
      01-02-2020, 08:12 AM   #25
LexxM3
LexxM3's Avatar
1698
2019 X5  [0.00]
Take a look at ESysX settings dialogs, there is a spot where you specify the cheat code file path. It is actually good to explore every nook and cranny yourself as there are a lot of moving pieces and you'll want your brain primed with what you see during exploration.
mattsrs600.00
      01-02-2020, 07:44 PM   #26
VTENGR
1053
Drives: 2020 X5 M50i
If you head over to Bimmerfest (am I allowed to say that?) and find your way to the coding forum, there's a pretty comprehensive DIY for beginners. I would strongly suggest you read through those threads because they're a wealth of knowledge.
      01-02-2020, 09:11 PM   #27
maczrool
Hmm. I've been over there and did search for some things, but at least on my first attempt or two didn't get what I was looking for. I'm sure I just overlooked it though so I'll take another look.
I did get the Esysx linked up with the cheat codes though and found which of my ncd files have what needs to be coded just by loading them one at a time in the FDL editor and seeing when the cheat codes popped up. I'll go through them tomorrow and see if it works as expected. Thanks!
      01-02-2020, 09:18 PM   #28
VTENGR
1053
Yeah. You're probably not going to find a step by step on how to code a lot of the newer features, but the coding forum has a lot of info on how get started and all the basics so you get a solid foundation of knowledge. From there you can tool around and figure a lot of stuff out.
      01-09-2020, 07:26 AM   #29
maczrool
Is there a way to have ADV going with assisted driving turned off? Eaglesrest mentioned there was a setting under displays but that only turns it on when assisted driving is enabled.
      01-09-2020, 07:28 AM   #30
LexxM3
LexxM3's Avatar
1698
2019 X5  [0.00]
Try unchecking that setting. It might seem counter-intuitive, but you are dealing with German engineering after all :-).
      01-09-2020, 07:29 AM   #31
maczrool
Thanks! Yes I tried that but that turns it off entirely.
      01-09-2020, 07:35 AM   #32
LexxM3
LexxM3's Avatar
1698
2019 X5  [0.00]
Did you code all 4 parameters or skipped the FES one as many have? I haven't tested all permutations of random coding choices that people use, so just brainstorming. As usual, might need ALL details and pictures to diagnose.
      01-09-2020, 10:01 AM   #33
ifr
ifr's Avatar
United Kingdom
1197
Drives: Tesla MY LR AWD
Try this:
https://g05.bimmerpost.com/forums/sh...&postcount=765
      01-09-2020, 10:02 AM   #34
maczrool
I did code all 4, but while documenting my settings under Car, Displays, Instrumental Panel, I found Central display area, Assisted Driving View. Enabled this and now it’s working with assisted driving off too. Thanks again!
      01-12-2020, 11:52 PM   #35
B530e
B530e's Avatar
284
Drives: 2023 BMW 760xi, 2024 BMW 530i
2021 BMW 540i  [0.00]
2020 BMW 530e  [0.00]
Strictly speaking, by the way, you don't need an ESys setup for ADV and ASS coding. Both can be done with Bimmercode, former in Expert Mode and latter in the standard simple mode.
If I may ask, how can I code ADV with Bimmercode?
      01-13-2020, 12:09 AM   #36
LexxM3
LexxM3's Avatar
1698
2019 X5  [0.00]
Sorry to sound, uhm, uncooperative, but this is becoming unreasonable. Please do a search on the forum, multiple threads and posts on this exact topic. Including the link literally 2 posts above yours on this current thread ...
... grr. Here is the exact link to an exact post in that thread: https://www.bimmerpost.com/forums/sh...php?p=25641809
      01-13-2020, 11:28 PM   #37
B530e
B530e's Avatar
284
Apologies, didn't mean to bother you. I tried that and it didn't work. That's why I reached out to you. I'll scrap it but thanks for responding.
      01-14-2020, 06:01 AM   #38
LexxM3
LexxM3's Avatar
1698
2019 X5  [0.00]
Well, you didn't say it didn't work, you just asked a question that was answered very clearly dozens of times. It's one thing to ask for help for something that isn't working and should, it's another to display blatant laziness. Communication counts too.
What didn't work? Walk us through in excruciating detail through your entire process of what equipment you used, your versions, and what steps you performed and let's figure it out.
      01-21-2020, 03:50 PM   #39
KCH1984
Drives: Tesla Model Y LR
Evening folks
Trying to assist a mate coding his X5 for ADV. we've managed to enable all other changes for LCA etc but can't locate the option within the DKOMBI CAFD to activate this view. Anyone know which folder we should be looking in? Screenshot attached.
Cheers
Gone: G05 X5 40d M Sport, F15 X5 30d M Sport, F30 330d xDrive, F21 M135i, E87 123d
      01-21-2020, 04:23 PM   #40
maczrool
Are you trying to code LCA or ADV?
      01-21-2020, 04:37 PM   #41
ifr
ifr's Avatar
United Kingdom
1197
Originally Posted by KCH1984 View Post
Evening folks
Cheers
That looks wrong.
What version launcher are you using, or esysx, and what psdzdata?
      01-21-2020, 04:45 PM   #42
KCH1984
ADV in this instance - the car has drive assist pro from factory, but not LCA being a UK car.
On LCA we couldn't find the SASx module to code, but that's a separate issue. Here we were trying to enable the ADV view in the instrument cluster.
      01-21-2020, 04:48 PM   #43
KCH1984
Evening folks
Cheers
That looks wrong.
Evening folks
Cheers
That looks wrong.
E-sys version 3.27.1
E-sys Launcher Pro 2.8.2
Psdzdata lite 4.21.12
      01-21-2020, 05:00 PM   #44
maczrool
You need Esys 3.33.4 to do that.
KCH1984948.50
