      01-21-2020, 05:10 PM   #45
KCH1984
Drives: Tesla Model Y LR
Originally Posted by maczrool View Post
You need Esys 3.33.4 to do that.
Thanks mate.
Is that going to be the case for VO coding LCA as well as enabling ADV?
Gone: G05 X5 40d M Sport, F15 X5 30d M Sport, F30 330d xDrive, F21 M135i, E87 123d
      01-21-2020, 05:27 PM   #46
ifr
ifr's Avatar
United Kingdom
1197
Drives: Tesla MY LR AWD
Originally Posted by KCH1984 View Post
Thanks mate.
It's not the version of esys that is the issue.
Launcher Pro 2.8.2 does not have FDL mappings for the G05.
You need to get a paid launcher pro 3.x or esysx.
You don't need a launcher to VO Code, just use esys, which is fine for LCA.
3.27.1 should be fine, but no harm in using the later version. I use 3.34.0.
You can't VO Code ADV but could use bimmercode if didnt fancy buying esysx or battling with tokenmaster for launcherpro.
Edit: Well technically you can VO Code ADV but only if you have a Japanese build car.
      01-21-2020, 05:32 PM   #47
maczrool
Drives: 22 M50i Carbon Black
So what version of esys is required for ADV if not using bimmercode? My eaglesrest guide indicates 3.33.4 and I used esysx and assumed that it was required since it’s listed as such.
      01-21-2020, 05:34 PM   #48
ifr
ifr's Avatar
United Kingdom
1197
ADV in this instance - the car has drive assist pro from factory, but not LCA being a UK car.
On LCA we couldn't find the SASx module to code, but that's a separate issue. Here we were trying to enable the ADV view in the instrument cluster.
As stated you can VO Code LCA by removing 8TR from your FA, and VO Coding SASx, BDC BODY (7083) and HU_MGU.
You couldn't see SASx as you didn't have the engine running when you did Read ECU.
KCH1984933.50
      01-21-2020, 05:36 PM   #49
ifr
ifr's Avatar
United Kingdom
1197
3.33.4 is recommended but not mandatory. 3.27.1 should work fine. I'd use the later version personally, but upgrading esys won't fix his issue.
The key issue is Launcher Pro 2.8.2 is the free version that TM released in a strop. Its old and doesn't have the newer psdzdata mappings used on the G05.
      01-22-2020, 01:11 AM   #50
KCH1984
So what version of esys is required for ADV if not using bimmercode? My eaglesrest guide indicates 3.33.4 and I used esysx and assumed that it was required since it's listed as such.
Thanks for the replies across both threads mate...in short I should look to upgrade my esys and use with an alternative launcher, but for LCA itself I should be fine if I have engine running while reading the ECU?
      01-22-2020, 02:02 AM   #51
ifr
ifr's Avatar
United Kingdom
1197
Yep you can VO Code LCA now. You'll see SASx, and other engine running dependant ECU, appear in the list.
LCA is a way better feature than ADV anyway
      02-11-2020, 08:57 AM   #52
chen060510
Drives: g05
Hi brother, I would like to ask how to activate the G05 driver advanced view. Can you share the code?
      02-14-2020, 10:48 AM   #53
maczrool
Use bimmercode or you can PM me. I have a cached copy of eaglesrest’s instructions.
      09-01-2020, 03:31 PM   #54
dominguez255
Drives: BMW Serie 1 F40
Originally Posted by LexxM3 View Post
Sorry to sound, uhm, uncooperative, but this is becoming unreasonable. Please do a search on the forum, multiple threads and posts on this exact topic. Including the link literally 2 posts above yours on this current thread ...
... grr. Here is the exact link to an exact post in that thread: https://www.bimmerpost.com/forums/sh...php?p=25641809
Hello, I know this is not my forum, but I have a 118i with manual transmission, I have Driving Assistant and Cruise Control with brake function, I have activated as you said the ADV in the instrument panel and it appears to me to select it on the screen idrive, but I don't have the two buttons on the steering wheel, does the ADV still work? or will only the view be shown in the instrument cluster?
      09-01-2020, 03:40 PM   #55
LexxM3
LexxM3's Avatar
1698
Drives: E46M3, G05X5
2019 X5  [0.00]
I know nothing about 118 iDrive or anything else about 118, but a) ADV itself is just the view (V in ADV stands for "view" ;-), and b) it sounds like you have the requisite assist functions optioned on the car, so I don't really understand how you could not have the buttons needed to control it. ???
Also, if you intended to attach a picture, it didn't seem to go through, can't see anything.
      09-01-2020, 05:14 PM   #56
dominguez255
I dont have this buttom
      09-01-2020, 05:29 PM   #57
LexxM3
LexxM3's Avatar
1698
2019 X5  [0.00]
I dont have this buttom [IMG]https://i.ibb.co/18M2m33/volante.jpg[/IMG]
Ah, those are follow minimum distance controls used by adaptive cruise control. A bit weird that your model doesn't have that, but that's all those are.
Update: Actually, sorry, that's not a pic of your car I guess so the following original comment doesn't particularly apply: "On the other hand, you don't have the Assisted Driving Mode and On/Off buttons either, so it doesn't look like your car has the equivalent of Assisted Driving Plus/Pro faculties. So I am surprised that ADV is available and useful for you, but who knows what BMW is ever thinking."
Below is what mine looks like.
      09-03-2020, 03:49 PM   #58
Saunders17283
Saunders17283's Avatar
Drives: 2020 M850xi Gran Coupe
- cheat files are actually handled by launcher, not directly by ESys, although the launchers incorporate its use into ESys; as such, how cheat files are handled is not the same between Launcher Pro and ESysX; ESysX can only handle a single file at a time, configure in setup
Is it still the case that eSysX can only handle one xml cheat sheet at a time? I’m just getting started and I’ve got a folder with a dozen or so XML files. Thx!
      09-03-2020, 05:32 PM   #59
LexxM3
LexxM3's Avatar
1698
2019 X5  [0.00]
Yes. Improving that is a feature requested a few times. In the meantime, you can combine the desired xml files manually into one.
      09-04-2020, 04:00 AM   #60
mij
Germany
Drives: BMW 330e
If someone did this already, could we maybe share this somewhere?
      09-04-2020, 05:02 AM   #61
Saunders17283
Haha! that's exactly what I was planning to do if this was the answer I got. I love a good workaround
Current Ride
Previous Rides
2019 X7 / 2018 X5 / 2012 X5 / 2014 750xi / 2011 750Lxi / 2008 335xi
      09-07-2020, 05:54 PM   #62
Thrangster
Drives: ‘22 m850 Convertible
Strictly speaking, by the way, you don't need an ESys setup for ADV and ASS coding. Both can be done with Bimmercode, former in Expert Mode and latter in the standard simple mode.
Sorry - can you advise how to code ADV with bimmercode (iOS if it matters) ? I've been searching around for an hour and can't find with expert codes to use
was also hoping to disable the speedomter correction and enable the additional Sport mode... most everything else I've figured out.
Thanks
      09-07-2020, 06:01 PM   #63
LexxM3
LexxM3's Avatar
1698
2019 X5  [0.00]
Thanks
Here for ADV with Bimmercode: https://www.bimmerpost.com/forums/sh...php?p=25641809
      09-07-2020, 06:23 PM   #64
Thrangster
ty
      09-29-2020, 12:29 PM   #65
ElectroGeek
Drives: X5 G05 50i
can someone help me, I'm trying to figure out what one adapter to buy to use Esys, is there one on Amazon ?
      09-29-2020, 12:51 PM   #66
VTENGR
1044
Drives: 2020 X5 M50i
Search the forum. There's several threads discussing the pros and cons of the different types of adapters.
