      04-03-2020, 08:56 PM   #45
jackaleyess
Malaysia
194
Drives: 2011 528i M-sport (sold), 2018
Originally Posted by edwinliem View Post
Originally Posted by jackaleyess View Post
Kereta abang mmg cantik dan mantap. Berapa ya abang beli kereta ni? Cina Indonesia ka?
Saya beli cuman satu saja kakak, iya saya indonesian born chinese
Damn son ur mod is sick pak... saya Chinese Malaysia. Saya sebelum ni jugak mau beli X5. Tapi malangnya budget tak restui.
How much it cost in Indonesia bro?
      04-04-2020, 07:02 AM   #46
edwinliem
Indonesia
44
Drives: X5 G05
Usd 100.000
      04-04-2020, 03:48 PM   #47
Jayden_F87
'20 M2 Comp.
Jayden_F87's Avatar
Drives: '20 M2 Competition DCT
AMAZING build!! Gotta take some time to appreciate those Focal Beryllium tweeters. How do they sound? I love seeing more of these audio upgrades
'20 BSM M2 Competition DCT
IG: @porky_m2c
      04-06-2020, 08:17 PM   #48
jackaleyess
Malaysia
194
Usd 100.000
Wow, not a bad price. U got any discount on that? Its around USD150k in Malaysia.
      04-08-2020, 04:17 AM   #49
edwinliem
Indonesia
44
Drives: X5 G05
No discount, since I was indent 6month before it delivered.
      04-09-2020, 03:49 PM   #50
dubsesd
#dubspec
dubsesd's Avatar
6332
Drives: G05 X5/ 2016 F80 M3 INDVL
Originally Posted by Ninefourteener View Post
Wow... that was unexpected..... so I'm really looking at only changing the overall length about 3mm then huh? I'm going to go out on a limb and say that "careful precision" is a priority.
How many times did to have to remove and reinstall the wheels?
this is wrong information. you do NOT lengthen the links. there are front and rear links provided. you shorten the front link 5mm over oem and shorten the rear links by 6mm over oem
LCI ///F80 M3 Individual Atlantis Metallic / Black Full / Carbon Cermics / 6MT
MPE / M Performance & Carbon package / KW v3 / 20" HRE R101LW / 20" HRE 527s / Michelin PSS / 20% tint / 3d Design / Streckenn splitters / OEM GTS hood / EAS Carbon seatbacks / Carbon RKP sideskirt / Bootmod3 / M Performance Tri color alcantara / AWE S Flow
instagram: @ dubsesd
      04-09-2020, 08:03 PM   #51
edwinliem
Indonesia
44
Drives: X5 G05
https://youtu.be/34_g2dPJ_C4
I just do it what i found on youtube. 5mm length change= 28mm drop
Front link longer will provide drop
Rear link shorter will provide drop
It also works for me
      04-09-2020, 08:56 PM   #52
dubsesd
#dubspec
dubsesd's Avatar
6332
this means the longer of the 2 links goes in front. you do not extend the links longer than oem.
      04-11-2020, 12:16 AM   #53
edwinliem
Indonesia
44
Drives: X5 G05
Here is the link that you can hear the ipe exhaust system
      04-20-2020, 06:21 AM   #54
edwinliem
Indonesia
44
Drives: X5 G05
      05-07-2020, 09:27 PM   #55
bimmermann88
Drives: BMW g05
That sounds AMAZING for a 40i! Definitely this will be my first mod on my upcoming G05
      05-10-2020, 04:26 PM   #56
bhe
Belgium
105
Drives: X5 G05 45e
No I think you are wrong the front bbm links are longer then oem. see pictures
Correct
I did install them this weekend and have a lot of pictures.
First pictures bbm links, the longer go in the front.
Second pictures oem links.. all the same length
The reason why it works reverse is because the front ones are above the axe , they can be removed without removing the wheel if you lift it enough. The rear ones are under the axe.
I still have fine tune the new links a little bit, this van be done without removing the back wheels but there is verry limited space if you don't have a bridge.
I will write a howto soon ;-)
One tip. leave your door open so the car won't lower when disconnecting the links.
atl_1M1520.00
      05-17-2020, 08:06 AM   #57
edwinliem
Indonesia
44
Drives: X5 G05
Sneak preview 😎
      05-17-2020, 11:24 PM   #58
edwinliem
Indonesia
44
Drives: X5 G05
New Brembo
      05-18-2020, 06:19 AM   #59
edwinliem
Indonesia
44
Drives: X5 G05
Update
      05-18-2020, 10:19 AM   #60
Alan l.
Alan l.'s Avatar
5437
Drives: 2020 F95 X5M Competition
You def need some spacers in the rear. Would look a lot better.
How do the brakes feel compared to stock?
      05-18-2020, 03:31 PM   #61
ted920
Drives: 2019 BMW X5 40i, Lexus GS 300
I like it.
I recommend that you black out the exterior trim and steps.
      05-20-2020, 05:08 AM   #62
edwinliem
Indonesia
44
Drives: X5 G05
I will update my new spacers 20mm f&r. Also exterior accessories that i change it to carbon style
      05-22-2020, 04:03 AM   #63
edwinliem
Indonesia
44
Drives: X5 G05
Here we go
      05-22-2020, 11:14 PM   #64
edwinliem
Indonesia
44
Drives: X5 G05
Some update
tvasica70.50
      05-24-2020, 08:35 PM   #65
edwinliem
Indonesia
44
Drives: X5 G05
Pic
tvasica70.50
      05-29-2020, 09:19 AM   #66
VTENGR
1053
Drives: 2020 X5 M50i
Looks like you're getting bad contact on your calipers from your brake pads. Nice and shiny in the middle but rusted on the outer and inner rings.
