12-14-2023, 11:35 AM | #111 | |
Rep 4,405
12-14-2023, 12:19 PM | #113 |
Rep 4,405
12-14-2023, 01:42 PM | #114 |
13549
Rep 20,193
That likely is part of it from what folks have reported. You will probably see/hear better results when playing from a USB.
12-14-2023, 04:32 PM | #115 |
199
Rep 323
12-14-2023, 05:00 PM | #116 |
Rep 4,405
Any airborne transmission of data is compressed. There are factors involved in just how much compression is used and how much fidelity is lost. If you want to compare anything, it needs to be as direct from source to player as possible. This can be done via a USB drive, SSD drive, etc. Many people complain about the quality of sound from Satellite radio, like SiriusXM, that too is compressed transmission.
12-14-2023, 06:11 PM | #118 | |
199
Rep 323
So I was just using that as a reference point in that in my old vehicle I typically used Bluetooth and it sounded far better than this does with CarPlay over WiFi. I just did a test with FLAC files on a USB drive and went back and forth with the same tracks with USB vs @Music/CarPlay. The bass response is about the same. The overall sound is slightly more detailed but the main difference is you have to increase the volume by about 30% when using CarPlay. That's annoying. This isn't a problem with the audio source. It's a problem with the sound system and either an amp that isn't powerful enough or low quality speakers (or both). And before you disagree with me more, keep in mind that we don't have the same vehicle so we don't know what changed in the 3 years and specifically with the LCI. We also seem to have very different expectations from audio. Even listening to pop music I wouldn't turn the 5k and 10k levels anywhere close to that high. So I'm returning to my question in a prior post about the sensitivity and impedance ratings of the subs, but at this point I really think both the subs and the amplifier going to them will have to be replaced. Last edited by mscot; 12-14-2023 at 06:17 PM.. |
Marty in NY2778.00 |
12-14-2023, 06:15 PM | #119 | |
Rep 4,405
12-14-2023, 06:20 PM | #120 | |
199
Rep 323
I'm also curious to hear what someone with an LCI and B&W system has to say about the bass. |
12-19-2023, 10:53 AM | #121 |
199
Rep 323
I went to the dealer yesterday and sat in a new X5 with HK.
It's definitely just how the current HK system sounds. Very little bass response. I guess I'll start reaching out to some of the audio providers to discuss it with them. I see that neither Bimmertech nor Bavsound lists the 2024 G05 with HK in their drop down. Anyone know why? I'm wary about simply replacing the subs. I dont think they're getting enough power. Also, I can't imagine that enclosure has much room beyond the cage of the sub so that's likely a problem as well. Last edited by mscot; 12-19-2023 at 11:02 AM.. |
12-19-2023, 11:05 AM | #122 | |
Rep 4,405
12-19-2023, 01:54 PM | #124 |
Rep 78
hmbmd116 have you replaced the subs without adding an amp in all of your trials? Did that help?
Yes, the Bavsound Subs remain in my car. They certainly sound better than stock with the HK amplifier in it. You can clearly hear the difference. It sounds much better being amplified. I’m still trying to get the Bimmer Tech amp to work without bricking the microphone and assisted driving feature and my new harness should be arriving later this week. What I have been doing in the interim when taking long trips is to disconnect the ram unit from the amplifier, but keep the booster which drives the subs. I maintain, assisted driving, and the driver side microphone yet get better amplification to the subs. It’s a bit unbalanced and I have to turn down the bass with the iDrive screen, but it definitely sounds better than not having the amplifier connected at all. I’m really hoping that this new harness fixes the issue. When the Bimmer Tech amp is fully connected, the sound system is at its best. In my opinion, it sounds better than BMW’s that have Bowers and Wilkins installed. I’ll report back as soon as I get it. |
12-19-2023, 06:24 PM | #125 | |
Rep 1,364
For anyone else, don't turn up the bass by much because that just makes it instantly muddy. Turn it up just a very little amount - or leave it centered. Then adjust the sliders as shown in this thread. Rob |
12-21-2023, 02:09 PM | #126 |
Rep 78
SUCCESS!!
I am happy to report that I received my new harness today and all issues are now resolved! The driver's microphone and full assisted driving works with both the RAM unit and Booster connected to the amp. The system sounds great! I recommend it highly! The customer support from Bimmertech has been exceptional. Anyone dissatisfied with the Harman Kardon stereo should absolutely consider this amp. It is expensive but still half the price of the Bowers and Wilkins system (not available of all X5 models). In my opinion it sounds better than Bowers and Wilkins.
12-21-2023, 02:11 PM | #127 | |
Rep 4,405
12-21-2023, 02:17 PM | #128 |
Rep 78
Here are two pictures of the new harness. Notice all the resistors that were inserted near the amp inputs. These will give the BMW computer the correct impedance levels and allow the assisted driving to function. As far as the driver's microphone was concerned, they think there might have been cross wiring on the original harness and was unrelated to the speaker impedance. The microphone works now so I am guessing that is what the issue was.
Marty in NY2778.00 WagonFan271.50 |
12-21-2023, 05:20 PM | #129 | |
Rep 1,364
Rob |
12-21-2023, 05:42 PM | #130 |
Rep 78
I first replaced all the speakers and subs with Bavsound products. This caused the assisted driving problem. I removed the speakers but left the Bavsound subs in place under the front seats. The assisted driving worked with this setup. So now I have the bimmertech amp with 14 stock Harman Kardon speakers and 2 Bavsound subs.
12-21-2023, 06:27 PM | #131 | |
Rep 776
12-21-2023, 07:24 PM | #132 |
Rep 78
I returned them early on for a full refund. I may try Bimmertech Alpha One Speakers for the 2 front doors and center speaker (3 midrange and 3 tweeters). I would think the BMW computer now reads impedance from the resistors installed in the harness. I have an email pending to them. It sounds really good right now so maybe I should leave well enough alone, however, I like to tinker and probably after the holidays I'll try it. In the meantime I have a 350 mile trip coming up right after Christmas and I am excited about finally being able to use it for a long trip with assisted driving!!
