      06-22-2023, 12:20 PM   #45
Keyser Soze
Keyser Soze's Avatar
Drives: 2023 X5
Originally Posted by BigEvan1923 View Post
I just sent you a PM on this - thanks in advance!
I used SEM Self Etching primer #39673 ($30 Amazon) but also Rustoleum has one in dark green that would work (I used it on my 535 exhaust tips and it had no issues after years) and is available at Lowes Depot along with the engine paint - Duplicolor Low Gloss Black Engine Enamel #DE1634.
I might actually go back and put a coat of semi-gloss black engine paint on it since that would match better with the surround.
Also, doing this with cans is harder than just using an airbrush, where you can be very precise. I got a Paasche H-3MH for $60.
2023 G05 X5 x40i Phytonic Blue
....many prior BMW's back to a 1966 1600
      06-22-2023, 01:17 PM   #46
BigEvan1923
BigEvan1923's Avatar
450
Drives: G05 LCI G07 M50i E46 M3 G01
Thank you!!! I was thinking about using Semi Gloss DE1635 - along with the SEM 39673...might be the move
      07-02-2023, 10:40 AM   #47
BigEvan1923
450
And the results. Not bad. Semi gloss looks good. Thank you Keyser Soze appreciate the help!
Appreciate 3
      07-03-2023, 11:48 AM   #48
Keyser Soze
Drives: 2023 X5
oh, that looks great and so do the flat black emblems!
      07-03-2023, 11:54 AM   #49
BigEvan1923
450
couldn't have done it without you!
      04-16-2024, 03:19 PM   #50
itshere
20
Drives: X5
Originally Posted by xdriv3 View Post
Reviving this thread --
Just brought my car to the dealer, replacement is covered by warranty, but just curious what others have experienced in terms of the replacement part.
I have attached the replacement offered- shadow line trimmed on the outside and regular chrome on the inside. Compared to the old defective part -- the inside is painted dark gray.
Just curious what replacement you guys were offered?
My concern with the replacement is that the inside will not age well.
Hey, how did you remove them? Was it difficult? Mine are also showing peeling so want to powder coat them
      04-16-2024, 07:57 PM   #51
xdriv3
Drives: X3
So mine were replaced under warranty.
They no longer make the ones w/ the dark coating on the inside. Now it's chrome without the coat.
      04-16-2024, 08:42 PM   #52
itshere
20
Drives: X5
Hmm okay. I was going to powder coat my wheels so figured I’d do that as well but figuring out how to remove it and if it’s difficult or not
      04-16-2024, 09:13 PM   #53
5ive7even
Drives: 2024 X5 40i, E63s AMG
The silver on my 24 X5 was driving me nuts. I sprayed them this weekend using semi-gloss high-temp engine paint. Turned out great. Hopefully, they hold up well. Figure I may need to respray them in a few years, but we'll see.
The silver on the inside of the exhaust ports and the chrome model trim are a big miss by BMW for those of us that spec'ed the M-Sport packages.
Sevn86525.00
      05-01-2024, 01:45 PM   #54
Keyser Soze
Drives: 2023 X5
Yes! Looks great! Hopefully you also used a few coats of self-etching primer first or I'd worry about potential longevity. Mine are still looking the same after 14 months now.
It is silly that BMW lazily releases these with unpainted stamped steel but of course makes them overly complicated to remove along with the "trim" pieces.
I have to assume BMW's laziness is inevitably heading towards just having fake exhaust trim and the actual pipe just dumping out below like MBZ and Audi.
      06-19-2024, 08:31 PM   #55
hunter04
hunter04
hunter04's Avatar
18
Drives: BMW X3 30i
Has anyone swapped out the peeling exhaust surrounds themself? I can’t seem to figure out how they are latched on, but I imagine they should come out pretty easy?
TIA
      06-19-2024, 09:28 PM   #56
nZtiZia
nZtiZia's Avatar
Drives: eVeRyOnE mAD!
TIA
not easy. what should take 20-30min doesn’t because there’s areas that are difficult to reach. folks report taking a couple hours with recommendation of bumper removal
      07-03-2024, 05:12 AM   #57
cmores
cmores's Avatar
Drives: BMW X5 M50i 2022, X7 2022
Going through this tip issue now…
Thanks for the details and airbrush tip!
      07-03-2024, 07:55 AM   #58
chefwong
Drives: X5
I can't picture using a rattle can or spray......the mindset of overspray will just want to have at least from passenger door panels and everything backwards from there taped off.
I've considered this slightly as the exterior of the tips of mine is just fine and the inside is -just starting- to peel a smidge.
