      05-21-2020, 07:41 AM   #67
HomeIn2
HomeIn2's Avatar
Drives: 2020 X5 M50i
charcoal filter delete
Great find...Thanks! I just removed mine.
I believe the secondary charcoal filter in the air intake is designed to limit vapors from coming out of the car when it is turned off. Didn’t realize the M50i had em. .
      05-22-2020, 01:40 AM   #68
Ninefourteener
Ninefourteener's Avatar
1346
Drives: 2020 X5 M50i, 2020 Alfa 4C
DYNOTUNE SCHEDULED FOR SATURDAY, JUNE 13TH!!!
Wicked excited about this. More to follow then!
Unit218.50
      05-24-2020, 03:14 AM   #69
Dr. Jekyll
Dr. Jekyll's Avatar
Originally Posted by Ninefourteener View Post
No... I don't like the look of them. Looks too "body kit" to me. Just my opinion.
I did however..... Order tires and TPMs last night. 335/25/22 rear, and 295/30/22 front. I havent even bought the wheels yet, but I figured it would be smart to buy everythinh I needed in "sections".
Going with a 22x12 on the rear, and a 22x10.5 on the front. My #1 choice is the Vossen HF-2..... but we'll see.
Why can't you reuse the OEM TPMs? Isn't it easier since they're already programmed?
      05-24-2020, 03:15 AM   #70
Dr. Jekyll
Dr. Jekyll's Avatar
Well...... in a miserable attempt to see if BMW used the same filters in the M50i as they do in the M550i.... I learned...... they don't. Gotta send the K&Ns back..... still waiting for K&N to make one for my car I guess.
But...... time was not wasted. Removed those silly charcoal filters in the top side of the airboxes. Not sure if those are a "noise device" or what...... but I do know that be removing them, I literally freed up HALF the airflow.
And.... I found this FLIMSY plastic line that was EASILY rattling against the chassis brace. A little padded tape, a zip tie, some preventative maintenance, and piece of mind.
That's "sorta" a mod...... right?
These are the filters you removed? The ones pictured? Just confirming since you said charcoal and they look like regular filters to me. You notice a boost in performance, sound or both?
      05-24-2020, 04:59 AM   #71
Ninefourteener
1346
Yes, paper air filters are (of course) still in the car. They are in the lower section of the airboxes.
The darker grey filters are located in the top half of the airboxes... and they are now gone.
I haven't driven the car much. No difference is sound. I imagine there is probably a small hp increase, probably only noticeable at high RPMs. I mean, there has to be, I removed literally HALF of the airflow restriction. I posted many more pictures in the engine forum, about the M550i K&N filter thread. But since doing so, several folks went out and removed theirs too.
One person mentioned that in the old F85 models, those charcoal filters were worth like 15 rwhp.
Worthwhile note.... EU cars don't have them
      05-26-2020, 05:34 AM   #72
Ninefourteener
1346
Tires arrived this morning. Still haven't bought wheels yet..... but this is a nice start.
Wheels will be 22x10.5 front, and 22x12 rear.
Front; 295/30/22
Rear; 335/25/22
These rears are MONSTERS.
      05-26-2020, 07:37 AM   #73
Ninefourteener
1346
I don't want to have to have both sets of wheels tires mounted and dismounted every season.
I'll have a full set of the OEM 21s with TMPS and all season tires, and a full set of 22s with TPMs and Summer tires. That way, I can swap them out in a matter of minutes in my driveway. No need to bring it to anyone.
BTW... TPMs are pretty simple. You just tell the seller what type of car you have (sometimes they'll need your vin), and they will program them before sending them to you. I bought an OEM BMW set, so the car will recognize them immediately once the new wheels are put on.
15+ PAGE BUILD THREAD:https://g05.bimmerpost.com/forums/sh....php?t=1694019
690HP / 928nM Dynotune:https://g05.bimmerpost.com/forums/sh....php?t=1729813
6-Piston/4-piston BBK:https://g05.bimmerpost.com/forums/sh....php?t=2097342
      05-26-2020, 07:50 AM   #74
HomeIn2
HomeIn2's Avatar
Front; 295/30/22
Rear; 335/25/22
What tires did you go with? (mfg. & model). I’m looking for OEM 21” size summer/performance non-RFs.
      05-26-2020, 09:57 AM   #75
Ninefourteener
1346
I "wanted" to go with toyo proxes stIII for these new 22s.
But the only (non cheap china garbage) that I could get sent here (APO address in Belgium) are the vrederstein ultrac. They look great though. I'm pretty confident in them, and the ratings are good. Time will tell
For my 21s, I removed the stock Conti runflat Summer tires..... which are garbage.... and now sitting in my basement..... and I installed an OEM sized set of Pirelli scorpion non- RFT all-seasons, and they are CONSIDERABLY better.
      05-28-2020, 06:26 AM   #76
Ninefourteener
1346
Yea! My black diffuser panel came in from Lithuania this morning. Total removal and installation time? Maybe 15 minutes.... and that was including time for pictures, and the removal and reinstallation of plastic rivets (I have a tool that does those)
The color is "slightly" off..... very slight. You really have to get up close to notice the difference.
And of course.... you can still see the trailer hitch..... but ot doesn't "stand out" quite so obviously as before.
I believe it gives it a more aggressive appearance. I like it.
Now..... if my damn exhaust tips would come in... I'd be in business.
Appreciate 3
      05-28-2020, 02:36 PM   #77
VTENGR
1053
Looks good! What tips did you buy? I'm looking for some.
      05-28-2020, 08:07 PM   #78
atlas
Australia
383
Drives: F10 535i, M2 LCI, G05 X5 40i
Looks great! I also recently installed a gloss black diffuser and agree it was very easy, especially compared to the Maxton front lip which I also did yesterday. I used the supplied hardware and supplemented with 3M tape and you're right - there's very little room to move inside that bumper!
      05-29-2020, 01:27 AM   #79
Ninefourteener
1346
I've bought a total of FOUR sets. Ironically, only the first ones showed up..... ever.
I have over $800 invested in exhaust tips..... and shady retailers keep screwing me over. It's a long story.
As soon as I have them installed, I will share my measurements. I don't want another incident to happen where sevetal people buy a set that doesn't fit correctly. I'm 99% sure my measurements are good.... but I want to be 100% sure. More to follow.
      05-29-2020, 09:17 AM   #80
VTENGR
1053
Keep me posted. I've seen pictures of the X5M tips and now I'm wanting to upgrade mine.
      05-29-2020, 02:30 PM   #81
Ninefourteener
1346
So.... ironically, 2 (of the 4 that I ordered 3 months ago from China and were lost, and I've already received a refund for) arrived today.
Can't install.... because I don't have all 4..... but I can test fit.
Diameter was 2mm off.... but I can correct that easily with my pipe expander. NBD.
But.... the way the tips come from behind the exhaust trim rings, they hang low, so they are closer to the bottom than the top. No good. However, the factory exhaust (rubber) hangers have stetched from 35mm to 45mm in only 4500 miles. If they were still at their original 35mm length.... I'd be good.
35mm poly exhaust hangers ordered, and on the way. They won't stretch like rubber. New tips on the way from California.... and "maybe" the other long lost set from China will show up?
More to follow.
      05-31-2020, 01:30 PM   #82
Ninefourteener
1346
I just came to the intetesting revelation that in every pic I've posted..... the car was filthy.
I do clean it periodically..... lol
      06-08-2020, 01:38 PM   #83
Ninefourteener
1346
First time for everything
LexxM31698.50
      06-08-2020, 02:35 PM   #84
LexxM3
LexxM3's Avatar
1699
Drives: E46M3, G05X5
2019 X5  [0.00]
That trailer would look great with future matching gold wheels
      06-08-2020, 09:23 PM   #85
Dr. Jekyll
Dr. Jekyll's Avatar
Nice set up!
Hey did you ever get your brake pads converted to ceramic?
      06-09-2020, 12:27 AM   #86
Ninefourteener
1346
Nice set up!
Not yet. I have the pads in my garage. Honestly, I haven't noticed the excessive amount of brake dust that everyone complains about. I actually don't think it's that bad. Nevertheless, hasn't really been a priority.
I was kinda waiting to make a decision on whether or not I wanted to epoxy/paint my calipers another color. I figured that would be a good time to do the pads.
      06-13-2020, 07:24 AM   #87
Ninefourteener
1346
I know I posted a full comprehensive thread on my experience at the Dynotuners..... but I like to keep track of it here as well.
Huge shout out to BR-Performance in Willobroek, Belgium.
Baseline dyno -536 hp / 826nM
US measurements - 529hp / 609 ft lb
After remap - 690 hp - 928nM
US measurements - 680hp / 685 ft lb
Here's the full write up I did on the whole experience: https://g05.bimmerpost.com/forums/sh....php?t=1729813
      06-13-2020, 07:28 AM   #88
Ninefourteener
1346
Baseline dyno
