08-27-2020, 07:47 PM | #23 | |
Rep 3
How to install?
Just wondering if you can teach me or others how to install the exhaust hangers, would really appreciate it. Thanks. |
08-28-2020, 10:00 AM | #24 | |
Rep 1,241
The new ones? Soak them in some soapy water (not lubricant, because it's bad for poly).... and just slide them in. You don't even need tools. Just do one side at a time. Don't remove both rear hangers at once. Remove one, replace it.... then move to the other side. |
10-24-2020, 10:56 AM | #26 |
36
Rep 37
Similar solution, less work.
2.5" x 3" x 6" bolt on tips. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 |
TomCat6065113.00 radmjk240.50 |
10-24-2020, 02:07 PM | #27 |
Rep 1,241
Looks good. They are going to fall off and/or damage your OEM exhaust shroud though. At least replace the rubber hangers with poly ones. It's not hard to do.
12-06-2020, 11:25 AM | #29 |
Rep 54
Thanks to the OP for posting this. I just ordered the exhaust hangers and I'm looking at these, https://www.ebay.com/itm/203168820370?ul_noapp=true. I waiting on the vendor to let me know if they offer them in all black in the 60mm ID and 80mm OD.
12-07-2020, 11:34 PM | #30 | |
Rep 1,241
However, I'm about 99.999% positive that the answer is "no" regarding those tips you've chosen. If they do, please let me know, because I must have looked at 100 different sellers that offer tips like that, and none of them were the right size. |
12-07-2020, 11:38 PM | #31 | |
Rep 54
https://www.ebay.com/itm/203168820370?ul_noapp=true |
12-08-2020, 02:55 AM | #32 | |
Rep 54
12-10-2020, 01:48 PM | #34 | |
Rep 1,241
With them, the exhaust will hang freely dead center between the exhaust bezels. Without them (OEM rubber hangers)..... the exhaust will rattle against the bottom side of the exhaust bezels, and likely break or bend the 2 outboard tips. 6 months after initial installation. I've even since removed the resonator and welded in a custom double H-pipe. No issues whatsoever. Those poly exhaust hangers are solid: Last edited by Ninefourteener; 12-10-2020 at 01:53 PM.. |
12-12-2020, 08:39 PM | #35 |
1176
Rep 1,502
Probably an unpopular opinion but this looks terrible.
It looks like its 2 exhausts stuffed into the bumper. You either need to find a way to connect the exhaust to the trapezoids or remove them entirely and go X5M look. |
AmooManiak632.00 |
12-21-2020, 02:20 PM | #37 |
Rep 54
My tips came in today and I just finished putting them on. I really like the way they look. I installed the exhaust mounts that OP recommended as well. Overall the install wasn't too hard. It took me about 2 hours. The measurements of the tips are 60mm inlet and 80mm outlet. There is just a tiny bit of space in between the tips. The carbon fiber piece makes them a bit thick. Without the carbon fiber there would be a lot more room but I don't think it'd look as good. I'll keep an eye on it of course to how they hold up after a few rides. If anyone is interestested in getting the tips you can contact this person on ebay. You have to ask him for the measurements as he will have to put a custom order in. They took about 2 weeks to get delivered.
Dr. Jekyll209.50 radmjk240.50 |
12-21-2020, 03:41 PM | #39 |
Rep 54
For that setup you are looking at a cost delta of at least $3000. If you are looking for a new exhaust tone and a slight performance upgrade then sure but if it's just the look you want then just buy the tips.
12-21-2020, 09:23 PM | #40 | |
632
Rep 1,585
I would remove the stock tip if I was to go quad - but to each their own. That's why we don't all have the same cars, which is the beauty of it. |
denniss391.50 |
01-23-2021, 04:33 PM | #41 | |
Gear Head
113
Rep 303
2021 X5 M50i, Carbon Black, Ext Coffee Merino interior, 21" Y Spoke wheels, Matte Poplar woodgrain trim. Adaptive M-Susp, DHP, Exec Package, Park Assist Plus, Driving Assist Pro, Traffic Jam Assist, Heated/Ventilated seats/armrests, Alacantara headliner, Increased speed limiter.
My wife drives a 2020 X2 M35i. |
01-24-2021, 09:53 PM | #42 |
Dragon Slayer
26
Rep 26
I guess, for me, and if it were even an option, I would prefer the dual pipes per side be cut off and a single, larger end be put on with a shape that would match the outlet hole. That would look better than seeing those twin tips sitting back there. But I do like the finished product of the OP.
2020 X6 ///M 50i
01-24-2021, 11:58 PM | #43 |
Rep 1,241
Thanks for all the insight and opinions folks...... good and bad.
My taste isn't everyone's taste, and that's ok. I didn't like to look of "fake" tailpipe finishers, and prefer the look of a "true" exhaust. With that said, I'm already planning an "upgrade" which will include removal of the finishers entirely, possibly minor cutting of the bumper, modification/re-welding of the muffler itself, and 4 much larger tailpipes, similar in design to the X5M. Lots of planning. More to follow. Need warmer weather. |
Burnt C6257.50 |
01-25-2021, 08:25 AM | #44 |
632
Rep 1,585
I don't think either is "fake." The BMW comes with quads stock (for the M50i), they just don't stick out.
One is a minor continuation of the stock look, which is fairly simple to do and barely noticable. It's for people who either have chrome tips and just want to change them to black or they want the quad tips to be better presented through a separation without actually having round quad tips. The other one is a double tip look, which I think some people here don't prefer because it looks like a tip coming out of a tip. If I was going for a true quad round look myself would have done what I did with my 550i - which is to replace the whole diffuser and just get the quad look without the "double" tip (stock tip and quads on top.) But like you said, this is what sets the BMW community apart from others. We have options and we all prefer different things. That's why you will not see the same car twice from an enthusiast perspective. There really is no right or wrong answer with something as subjective as this. Last edited by AmooManiak; 01-25-2021 at 12:02 PM.. |
