      09-27-2020, 12:38 PM   #23
speedyman
429
Drives: 2021 X5 M50i, 2016 Z06
Originally Posted by Tim2189 View Post
Haven't tried E85, at 22psi I'm pretty sure I'm maxed out already with the JB4, not sure.
Station that has E85 is a good distance from me so maybe later on I'll give it a go
Same thing here, E85 is available but a 25 minute ride each way, PIA.
BTW, did Burger give you any idea when we will have an update that will allow us to connect the EWG plugs and move to that level?
      09-27-2020, 12:45 PM   #24
Tim2189
Russian in a Bimmer
Tim2189's Avatar
Drives: X5 M50i
No update in regards to EWG, Terry said they'll look into it at a later date
2013 X6 - retired
2015 X6 - retired
2015 435GC - retired
2018 X5 40e - retired
2020 X5 M50i - Current
      09-27-2020, 04:24 PM   #25
speedyman
429
Sounds like that might be a while. Did you get your down pipes installed?
      09-27-2020, 05:58 PM   #26
UltraDave
UltraDave's Avatar
127
Drives: 2020 BMW X5 M50i
If anyone is interested in seeing the logs
car is stock (resonator delete) waiting on downpipes install
1st log - 4th gear from 2k to redline map 2
2nd log - 3rd gear from 2k to redline, Map 0 and Map 2 are on the same log
I reached out to burger tuning to see if there are any tweeks that need to be done and if I am able to run map 3 and 5
Looks like Greek to me 😂
Addbuyer832.00
      09-27-2020, 06:00 PM   #27
Tim2189
Russian in a Bimmer
Tim2189's Avatar
Drives: X5 M50i
Not yet, running out of patience but should be next week.
2013 X6 - retired
2015 X6 - retired
      09-27-2020, 06:01 PM   #28
Tim2189
Russian in a Bimmer
Tim2189's Avatar
Drives: X5 M50i
Simple translation
Stock - vroom vroom
JB4 - VROOM VROOM
2013 X6 - retired
2015 X6 - retired
      09-27-2020, 07:47 PM   #29
speedyman
429
Simple translation
Stock - vroom vroom
JB4 - VROOM VROOM
Looking forward to getting my JB4 installed, should order it soon and will get it onboard after there about 1500 miles on the clock.
I'll be very interested to hear how the down pipes work out.
      09-28-2020, 01:33 AM   #30
Addbuyer
Addbuyer's Avatar
832
Drives: X3MC
Wow I am sure those columns of figures look look even more impressive, if only I could understand them
      09-29-2020, 06:20 PM   #31
speedyman
429
Originally Posted by 130FeetDeep View Post
That pull shows the timing retarding 2 degrees while the throttle snaps to 66%. There is a second notable timing drop at 5k rpm but not as large of a throttle closure. It is pulling 4 degrees of timing. You are not getting those timing drops on the Map 0 run, so that would personally bother me.
So the values in the ign 1 table are the degrees of spark advance? Seems to be all over the place in those other logs.
      09-29-2020, 09:02 PM   #32
130FeetDeep
Drives: BMW X5 M50i
The arrow on the left shows the timing drop on Map 2. The right arrow shows the timing increasing advance through the RPM range on Map 0 (stock) as one would expect. If Tim runs some MS109 or Ethanol, we can see if that is too much boost for the supporting mods. My guess is his downpipes might very well fix it.
One should expect to see a smooth increase in timing through the RPM range if the DME is happy.
      09-29-2020, 09:48 PM   #33
speedyman
429
^^^^^I see exactly what you are pointing out. The obvious question is why. Thank you very much for the help with reading and understanding the data.
      09-30-2020, 12:22 AM   #34
130FeetDeep
Drives: BMW X5 M50i
Timing pulls from the DME occur because it detects knock and this is a safety reaction. Beyond the safety, timing drops equal horsepower drops. Generally knock will occur if IAT get too hot or back pressure causes high combustion temps. I am pretty sure he can log IAT off the JB4. That said, I am willing to bet the stock downpipes are a big, big contributor. If he logs after he installs the pipes, we can safely assume that was a big part of the problem.
Either way, we can 100% tell if that timing drop was knock by increasing the octane with a few gallons of MS109 or running a few gallons of ethanol. The higher octane is more resistant to knock, so we would be sure. My guess is that 22 psi is too much with an otherwise stock vehicle. You may need downpipes to run that much boost.
      09-30-2020, 08:31 AM   #35
speedyman
429
I follow that, makes good sense. The HP tuners software that I used on a C6 Corvette had something in the log that measured or counted the signals from the knock sensors if I remember correctly. I wonder if some SUNOCO 94 would be worth a try.
      09-30-2020, 02:54 PM   #36
130FeetDeep
Drives: BMW X5 M50i
BMW's DME does have a value called KR or Knock Retard. It has been shown over the years to be somewhat unreliable, so most focus on the timing drops.
      03-19-2023, 06:44 PM   #37
gtenedio
Drives: '%E2%80%9909 e92 m3, '19 X3, %
did you ever throw the downpipes on?
