11-12-2020, 06:58 PM | #1 |
Rep 158
Exhaust Flap Stays Open?
By setting exhaust flap to "Open" (vs. "Auto" or "Closed") in BimmerLink, does it remain open permanently until changed? Or does the phone/OBD need to reconnect each time the vehicle is turned on for it to re-open? Having a hard time discerning if it's open while in drive, and the setting cannot be checked while the vehicle is in motion.
11-12-2020, 11:51 PM | #2 | |
Rep 2,609
To keep flap permanently open, you need to get it open (BimmerLink or another method) and then a) pull the control cable at the exhaust or b) pull the fuse. Or c) remove the flap spring at the exhaust and tie off the flap open with a wire. Those are the 3 methods.
mrichione96.00 |
11-23-2020, 12:58 AM | #3 |
Rep 709
11-23-2020, 01:27 AM | #4 |
Rep 2,609
Fuse 203 in the rear (hatch, right side) fuse panel.
https://g05.bimmerpost.com/forums/sh....php?t=1603977
