      02-20-2019, 02:56 PM   #23
misterburns
28
Drives: X5 - F15
Agree. I think the all black is my preference on the white colors b/c of the camera zit. If the camera wasn’t there I’d go with the white middle.
      02-22-2019, 08:58 AM   #24
TW516
TW516's Avatar
Drives: 2007 e92 Sprt; 2019 X5 MSprt
Black Grill / Exhaust Trim
Is there a step-by-step guide like this for the exhaust trim as well?
      03-06-2019, 01:14 PM   #25
BMWL0VE
Drives: 135i
It looks amazing with a black grill!
      03-07-2019, 09:21 PM   #26
ATTN
ATTN's Avatar
Australia
96
Drives: 335 E92 DCT
2009 BMW 335i  [10.00]
Black grill makes a a huge difference.
So IND basically re-sell the OEM grill but they have painted it black?
Certified Australian
      09-02-2019, 05:21 AM   #27
Bancroft
Drives: BMW X5 45e
Does anyone now if the new X5 45e is getting the blue elements inside the grille? Something like this: https://cdn.motor1.com/images/mgl/Kk...-xdrive45e.jpg
      11-22-2019, 09:11 PM   #28
Clarke03
Drives: 2019 BMW X5 M-Sport
Just installed mine
Just installed one of these on my phytonic blue g05. I went with the all black version and it is just beautiful.
      11-24-2019, 02:54 AM   #29
ccbl
Drives: AW E93 335i/Jerez E90 M3 6SP
New grill on in gloss black. front plate delete and color matched reflectors to come
Instagram @luongspec
      03-31-2020, 03:56 PM   #30
:chesmu:
Drives: BMW X5
Looks great. Thanks for the detailed pictures
      05-19-2020, 04:15 AM   #31
Bandit-X
Drives: X5 M50i G05
Hi
any nice frontlip coming for the G05 ?
Originally Posted by IND-Distribution View Post
Difficulty (1-5): 1
STEP 1: Begin the IND front grille installation by opening the hood.
Pull twice on the level inside the cabin.
STEP 2: Using an interior trim pry tool, depress the three (3) tabs at the top of each grille to loosen it from the front bumper.
STEP 3: With the grille tabs successfully freed from the housing, slowly pull the grille away from the front bumper working from side to side.
Step 4: If you have Park Assist then you will have a camera mounted in the center of the grille. Release the tabs and the housing will separate.
STEP 5: Align the IND painted front grille set with the tab housings and press in using uniform pressure.
      05-19-2020, 11:20 AM   #32
UltraDave
UltraDave's Avatar
127
Drives: 2020 BMW X5 M50i
Looks great
      05-18-2021, 12:17 AM   #33
Mr.blue
Mr.blue's Avatar
Drives: 2018 M550i Xdrive, 2021 X5M co
I understand that this thread is about the upper kidney grills but I was wondering if anyone had instructions on how to remove the lower grill to be replaced. A few weeks ago I was traveling on the interstate when a piece of shredded semi tire was flung into the front of my X5M. Even though I have PPF on the front, the tire shred broke the lower grill and left scratches on the slats of the upper grill. Some of the scratches were caught by the PPF but the slats were not covered. Both grills are on order and I am planning to install them myself. Thanks for any help
Mike
      08-24-2021, 12:35 PM   #34
drurka
drurka's Avatar
Drives: 2020 X3 M40i
Does anyone have any advice for the cerium/shiny accents located on the active grill shutters themselves.
Ps this isn't my car, just sharing someone else's because it shows how they swapped out the grill but the middle shutter/louvers are still shiny
      08-31-2021, 03:16 PM   #35
Gldngreek
I’m thinking about adding a gloss black grille but I have a M50i that has the cerium grey active grill shutters as well but I want it completely black. When I look online I can’t find the all black one. Also can it be removed when you replace the grille or does the whole front bumper need to come off?
      08-31-2021, 07:26 PM   #36
JimVR4
JimVR4's Avatar
Drives: 21 X5 M50i M-Sport
The outer piece is this one I think:
G05 X5 M Performance Gloss Black Front Grille - vehicles with Park Assistance Plus - BMW (51-13-8-096-590)
The active portion is another part and much harder to change according to this thread.
2021 G05 X5 ///M50i / Phytonic Blue / Cognac Vernasca
iStep 03/2023.50
      09-02-2021, 12:41 PM   #37
10101X5
10101X5's Avatar
465
Drives: 10101X101
Originally Posted by TucErDoc View Post
Huh, I see.
Mine was actually attached to the grill. I've never actually seen it open
On a hot day, remote start and you will see it open. It and the grille are two separate parts.
      08-03-2022, 07:48 AM   #38
I2P
Drives: 2022 BMW X5 xDrive 40i
seller and compatability with the 40i?
Where did you purchase the black kidney grill?
Is this grill compatable with the X5 xDrive 40i?
      09-12-2022, 08:04 PM   #39
gschlact2
Drives: X5 45e
No blue inserts in my 2023.
