03-01-2021, 10:17 AM | #45 | |
Happy M Driver
241
Rep 390
I know that this is NOT an ideal solution. I did want to keep my gesture control enabled so that was the choice I made.
2020 X5 40i M Sport - The "Unicorn" (B&W Sound, Touch Screen, Heated/Cooled Cup Holders, Soft Close Doors, Acoustic Glass, Full Alcantara & Glass Controls, Luggage Compartment Package, Heated/Ventilated Seats, Laser Lights, Fog Lights)
2016 M4 Coupe; 2008 Dinan S1 M5; 2006 530i; 1998 328i Last edited by Cooltones; 03-01-2021 at 10:29 AM.. |
03-19-2021, 11:42 AM | #46 |
Rep 115
Has anyone figured out the wiring so that the radar does not stay on for like ~5mins after car is shut off?
For people that has x45e, do you see significant battery drain if radar is left on for the 5 mins? This is my deciding factor if I want to get a radar for my x45e. |
03-25-2021, 11:47 AM | #47 |
Rep 77
2021 X6 and Escort Passport Max Setup
Removing the plastic trim was not trouble at all. Just open at the bottom side first in the middle by using a credit card or flat screw driver. Again slowly at the top middle above mirror holding pivot. They should come apart with little bit of wiggling.
Wire tap is done per the picture attached (4015 harness red wire to bottom mirror harness red wire at right end; black wire to brown wire on left hand side of mirror harness). It powers off with in 5 mins of locking the car, at the same time as the glass control knob lights off. Using the 2 zip ties provided, tied the harness way close in the beginning where they are inserted in so that hooked in wires won't come loose , another at the top trim end point, tied to 2 other harnesses so no one pull it out. Parts used: https://blendmount.com/aluminum-rada...y-3032-series/ https://blendmount.com/power-cord-mt...25-lg-mt-4015/
2021 BMW X6 x40i; 2017 Ducati Diavel Diesel Limited Edition bike; 2018 Honda Accord Touring
2017 Audi A4; 2009 BMW 535i; 2006 BMW 530; 2007 Acura MDX; 2002 Cadillac Escalade 2001 Honda Odyssey; 2000 Lexus RX300; 1997 Jeep Grand Cherokee; 1994 Toyota Camry |
aps335.50 |
04-28-2021, 11:46 AM | #48 |
Rep 760
Drives: '23 BMW i7 xdrive60
This is a great thread! Warm weather is here in NJ so took the time to do the mirror tap this morning. I was done in less than 10 mins. Thank you!
'23 BMW i7 xdrive60 - Frozen Deep Grey
'22 BMW 228xi Gran Coupe - Phytonic Blue |
05-29-2021, 11:21 AM | #49 |
Rep 57
Hi all, just wired my Escort Max II to the mirror. I'm getting anywhere from 13.3Volts to 14.7 volts according to Escort display. Any issues with this?
In my Raptor, same detector using the cig lighter, get 12.3volts. Thanks! |
11-27-2021, 02:34 PM | #50 |
Rep 2
Mark this thread. Thanks for all the descriptions.
Installed mirror tap radio detector and hard wired dash cam. Thanks to everyone. Last edited by ericmeiguo; 11-27-2021 at 02:42 PM.. |
03-28-2022, 04:07 PM | #52 |
Rep 2,402
Wanted to bump this....tried this today on my X5M and broke a couple small clips on the trim piece that separates into two pieces. Good thing is it appears that part is only $25 and you get BOTH sides for that. In other words, not a huge deal if you break it.
2022 M8 Comp GC, 2021 AMG GT53, 2022 X5M Competition, 2021 X7 40i, 2019 M5, 2018 M550I, 2017 Audi Q7, 2014 M6 GC, 2013 Mercedes CLS550, 2011 750LI, 2008 M6 Cabrio, 2008 Porsche Cayenne S, 2004 Mercedes SL55 AMG, 2003 Mercedes SL500, 2000 Mercedes CL500, 1993 Lexus SC400, 1989 525i, 1985 318i
05-15-2022, 08:55 AM | #53 |
Rep 212
In other "accidents while doing this" FYIs, I just had a windshield replacement, and they of course didn't reinstall the mirror taps in the process. When doing it on my own, I learned, never rotate the mirror counterclockwise when the trim pieces are off - it'll literally rotate off the clip mounts and pop off entirely. Luckily, I had just wrapped the wiring harnesses in cloth tape and they didn't do any damage in the fall to the dash, but be careful!
09-12-2022, 07:52 PM | #54 |
Rep 181
Thanks for the thread guys. Got my pony tail installed today for my Radar detector. This is the third car doing it, it’s getting a bit short since I cut it each time rather than rcersing the install ;-)
I used about 1/2” cut from paper clips soldered to the end of the wires to insert into the harness. That harness is a “mimi” and would have been much easier one size up. |
10-20-2022, 04:45 PM | #55 |
Rep 11
Thank you for the detailed instructions guys. I had done this before with my previous car, but it had been a few years and needed a refresher on the disassembly and mirror tap for my Uniden R3. I used this one as the one from my previous car was too small (needed a new Blendmount as well, BNR-3032):
https://www.amazon.com/gp/product/B08726N2LN/ |
11-17-2022, 07:15 PM | #56 |
Rep 112
Anyone tap the fuse box under glove bax on a 2023 (or earlier) X5?
I need to do that to a switched fuse as I use a smart cord so not using the mirror tap/mount. I could not (yet) find a switched fuse there so have to unplug detector each time. |
12-12-2022, 01:28 PM | #58 |
Rep 181
12-12-2022, 05:31 PM | #60 |
Retired Navy
39
Rep 118
07-11-2023, 11:11 PM | #62 |
Rep 109
Thanks to all for the info here. Hoping the wiring isn't too different on the '24 - hopefully I'll be able to let you all know in a few weeks after taking delivery.
07-12-2023, 05:14 AM | #63 |
Rep 103
I wired my 24 with the black wire tapped into the left wire on the plug and the red wire tapped into the right wire and the V1 shuts off after 5 minutes.
07-12-2023, 08:23 AM | #64 |
Rep 109
07-17-2023, 08:46 PM | #66 |
239
Rep 319
Drives: 2024 X5 M60i, 2020 RRS SE, 201
I completed the mirror tap install on my 2024 X5, was same setup as my 2020. I attached some photos but again same process as before so can refer back to earlier posts if needed.
RADMJK
2024 BMW X5 M60i Brooklyn Gray Metallic 2020 Range Rover Sport SE White 2017 BMW 530i xDrive Black 2005 BMW Z4 2.5i Jet Black |
