      08-21-2021, 06:27 PM   #1
wall_nut
Drives: 2022 BMW X5 x45e
DIY Wireless Charger Install (not OEM) (2022 X5 45e)
For those that didn't get the OEM wireless charger...maybe this will help. This post will have a lot of photos. I decided to install my own wireless charger since I couldn't get the OEM one due to the parts shortages. I decided I wanted the charger to be in the area where the OEM charger is. I don't really care that I might be blocking the digital key card area. I've been wanting to try working with some walnut so I picked up a small piece from the local hardwood store and designed roughly what I had in mind on a piece of scrap paper and then spent a couple days crafting the phone holder with embedded wireless charger. I'm sure you could just buy something similar and toss it in there but I wanted to create something a bit sleek. One issue is that it won't hold a large phone with an otterbox but it's not much of an issue for me right now as I enjoy smaller phones.
Install Sequence (this took about 6 hours for my install):
1. Move both front seats all the way down and back for access to center console T20 screw access. Also retract the thigh extenders.
2. Disconnect the main 12v battery only. If it's a PHEV you may need to wait until the car goes to sleep for power to be cut from the car entirely.
3. Begin disassembly. The T20 screws in this car are torqued pretty high so make sure you have a good T20 driver and a straight shot at the screws.
4. Follow the disassembly instructions from the TIS guide. I found it over here.
5. 12v socket wiring:
a. Red w/ Green Stripe wire is hot
b. Brown wire is ground
c. Yellow/Green wire is for LED
6. Plan your wiring path, route the wires in place, and make your connections. I planned it out so the USB connection and fuse holder are accessible by simply removing the console side carpet on the passenger side.
Reassemble everything and enjoy. Good luck!
Parts:
Qi Charger (USB Type C for easier routing): https://www.amazon.com/gp/product/B08X16PKSZ
12V to 5V/3.1A USB Adapter (with Fuse): https://www.amazon.com/gp/product/B01DYE54LI
2.5" Forstner Bit: https://www.amazon.com/gp/product/B00EPBVL5S
Car Removal Tool Set: https://www.amazon.com/gp/product/B08DHVCKP8
AJFord115.50
      08-21-2021, 06:30 PM   #2
wall_nut
Woodworking / Install Part 1
      08-21-2021, 06:33 PM   #3
wall_nut
Install Part 2 / Wiring
      08-21-2021, 06:36 PM   #4
wall_nut
USB Routing / End of Photo Wall
ladra17.50
      08-22-2021, 08:46 AM   #5
black_F10M5
black_F10M5's Avatar
289
Drives: F10 M5
Really great writeup , thanks for taking the time to put it all together.
While I do like what you made , would we simply be able to source the OEM parts separately and retrofit after taking delivery?
2016 M5 | Instagram: @black_f10m5
IND cosmetic | M Performance , RKP , 3D Design aero | Eisenmann Race exhaust | AMS catted downpipes | MSR intake | CSF charge coolers | DME Stage 2 tune | KW v3 coilovers | BBS FI | Michelin Pilot Sport 4S
      08-22-2021, 02:46 PM   #6
wall_nut
Perhaps. I'm not remotely anyone who could speak about this with any accuracy. Someone around here mentioned the OEM charger part was pretty expensive but I don't know myself. Further I would think there could be some complications with swapping the digital key pad out but again I don't know.
      08-24-2021, 11:39 PM   #7
JimVR4
JimVR4's Avatar
Drives: 21 X5 M50i M-Sport
Great work wall_nut I have the weak stock charging pad (5W??) and hope to change it to a 15W pad
2021 G05 X5 ///M50i / Phytonic Blue / Cognac Vernasca
iStep 03/2023.50
      08-25-2021, 11:18 AM   #8
Tim@codemybimmer
Tim@codemybimmer's Avatar
569
Drives: 2022 X4 M Competition F98 LCI
Pretty good handiwork!
Upon reading the schematics, the NFC Digital Key pad and the Wireless Charging NFC Digital key pad are wired the same, save for the LTE compensator for "extended" cellular coverage.
Therefore it is mainly plug and play to swap out the NFC pad for the Wireless charging pad with NFC, save for coding it with 6NW if you needed the "forgot device" notification. Wiring would only be involved if your vehicle had 32Z - Digital Key Deletion, since there wouldn't be a NFC pad there at all.
      08-25-2021, 11:55 AM   #9
black_F10M5
289
Drives: F10 M5
This is GREAT info , thanks for providing.
Now, to see if the Wireless Charging NFC digital key pad is an available part number..
      08-25-2021, 09:54 PM   #10
wall_nut
this is the wiring for my NFC pad in case it helps determine anything. 4 wires. let us know if the part is orderable and price.
      08-26-2021, 09:10 PM   #11
SmartSaves
X5 Enthusiast
SmartSaves's Avatar
461
Drives: 2021 X5
2021 BMW X5  [10.00]
Well, this is nuts! In a good way
2021 X5, Excellence, M Sport, DHP, DAP, RSE, MW, Merino.
      08-28-2021, 02:05 PM   #12
JimVR4
JimVR4's Avatar
I took apart my console to remove the wireless charging pad. It's all integrated with the NFC and Booster.
iStep 03/2023.50
      08-29-2021, 03:09 PM   #13
tedbird
Drives: 2020 BMW X5 xDrive40i
Plug and play alternative
Hi everyone,
Here is a plug and play wireless solution for wireless charging:
https://www.aliexpress.com/item/1005...6f2e4c4dQqdFpD
      08-29-2021, 05:14 PM   #14
wall_nut
Originally Posted by tedbird View Post
Hi everyone,
Nice find. Odd that it covers up the right hand side storage pocket but still looks like a simple upgrade.
      10-05-2021, 01:14 PM   #15
Chick Webb
Drives: '10 E92, '17 540i, '21 X6 M50i
FWIW, I posted up a solution that is a little simpler, though not as clean an install, here - https://g05.bimmerpost.com/forums/sh....php?t=1864111
      10-06-2021, 05:41 PM   #16
wall_nut
after having mine installed awhile now I can report I've had some issues with what I'm guessing is heat build up on longer trips. of course using wireless AA seems to put a tax on my phone and I've noticed it hasn't been able to keep the phone charged up either. I think the wireless connection gets weak or something as the sound starts dropping out. cycling wifi seems to solve it but not sure for how long. could be a wifi signal strength issue leading to all of this heat and problems so this could be something that acts different device to device. Galaxy S10e is my current poison.
      10-07-2021, 05:20 PM   #17
JimVR4
JimVR4's Avatar
I have an S20. I do have the wireless charging pad but I commute with wired fast charging. For long trips we will have two phones plugged in and fast charging. No need to move the phone while driving so this seems the best solution
iStep 03/2023.50
      06-17-2022, 10:06 AM   #18
TPX01
Drives: X5
Is this connector identical to the one where you only have NFC or do you think you nee to reroute the power from somewhere?
      06-18-2022, 12:09 PM   #19
JimVR4
JimVR4's Avatar
Originally Posted by TPX01 View Post
Is this connector identical to the one where you only have NFC or do you think you need to reroute the power from somewhere?
I don't know for sure but I suspect the connector is not different for the two options. The wiring would likely include both power and communication signals
iStep 03/2023.50
      08-04-2022, 05:26 AM   #20
2Slow.
2Slow.'s Avatar
32
Drives: X5 Xdrive45e, M135I
Old thread, I know.
But OP, with tools you have, you should be able to integrate few air channels around charging pad and install small 30mm x 30mm fan on the back of the timber frame, to push air thru.
All you need to do, is just push some air between wireless charger and phone to keep it cool. Custom wiring kit can be ordered with this wire harness manufacturer company in China, they are subcontractors to OEM automotive sector.
      08-23-2022, 10:46 AM   #21
vr005
Drives: BMW X5 45e
For those who doesn't have the heat and cool cup holders. This may be an easy option
ElecHavk 2022 Upgrade Wireless Car Charger Compatible with BMW X5 X6 X5M X6M X7 2020-2022 F85 F86 Center Console Accessory Panel, Qi https://a.co/d/cjDfNq8
You can also order directly from AliExpress for around $90 w/ free shipping.
