      10-25-2021, 05:09 PM   #1
Roch M4
I /// M FAN
424
Drives: M4 SS/SO 2016 / X5M C 2023
DIY 5$ X5 G05 Side reflector delete
I wanted to share with you a cheap cosmetic modification I just did to hide the horrible orange side marker / reflectors
1 - I bought from AliExpress a black tint film wrap sticker
2 - Clean the reflector with some rubbing alcohol to improve the sticking of the film
3 - Cut a 3 x 12 inches film
4 - Remove the back of the film to expose the sticky part
5 - Apply the sticker on the reflector
6 - Remove the protective layer on the sticker
7 - Press the sticker on the reflector to expose the contour of the reflector
8 - Cut carefully with a blade the film around the reflector and
remove the excess around
KLCC79.50
      11-01-2021, 03:54 PM   #2
Ashme
Ashme's Avatar
31
Drives: Viper, GX460, BRZ
I've done this. If you use a heat gun first (a blow dryer will probably work too) the film will start to wrap around the reflector too.
2019 X5 XDrive50 - Stock for now
2013 Viper GTS- DSC/Tractive coil overs, Sway bars, big aero, carbon stuff, exhaust
2014 BRZ - Race/track car. Cage, gutted, aero, big brakes, race prepped, etc.
2011 Lexus GX (for sale soon)
Roch M4424.00
      11-01-2021, 07:29 PM   #3
Roch M4
I /// M FAN
424
I didn't know that, but to wrap it around the reflector must be removed, no?
      11-02-2021, 04:28 AM   #4
Ashme
Ashme's Avatar
31
No, it will kind of just melt around it so you don't see edges.
Roch M4424.00
KLCC79.50
