11-03-2021, 07:27 AM | #1 |
Rep 108
best and easiest wheel cleaner?
I know this has probably been discussed but interested in thoughts on the best, safest, and easiest wheel cleaner out there
suggestions welcome |
11-03-2021, 08:21 AM | #2 |
Rep 82
My go to is the same car wash soap I'm using on the rest of the car. I wash my car regularly enough where this, along with a nice soft wheel cleaning brush, does the trick with little effort. I might be wrong but I assume most wheel cleaner sprays are much harsher, especially if the manufacturer claims that no scrubbing is required. I plan to ceramic coat my wheels when I switch them up for winter time, and I'm pretty sure that will make the job even easier.
11-03-2021, 03:57 PM | #5 |
Rep 82
Ceramic coating won't change my process since I just use car wash soap and a soft brush. Hopefully they get a little less dirty between washes with the coating and when I do wash I expect they are slightly quicker to clean.
GrussGott18116.50 |
11-03-2021, 10:04 PM | #6 |
535
Rep 364
Drives: 2011 AW E92 ZCP 6MT
Garage List 2021 Toyota Tacoma [0.00]
2020 BMW X5 [9.00] 2020 Subaru WRX [0.00] 2019 Ford Raptor [0.00] 2011 BMW M3 [0.00] |
This is what I use with a foam cannon and dedicated wheels brushes. So far all P&S products are recommendable, but their interior cleaner is the subtle winner. (Yes, even more then bead maker).
AW 2011 E92 ZCP 6MT single hump w/speed cloth.
Alpine Stage 2 | Apex Manufacturing X-Pipe | Corsa | BayOptiks | Haimus Racing CF Plenum MW 2020 G05 X5 with delicious coffee interior |
11-05-2021, 08:15 PM | #7 | |
18117
Rep 11,746
Drives: 2018 M4 Comp Indv
The con of non-acidic cleaners is they don't dissolve brake dust so it makes cleaning harder & shittier. The con of acidic is, they can damage raw metal ... but in general, people with BMWs, don't have to worry about that unless you have horrible (like, really horrible) curb rash you don't intend to have repaired, but somehow want to "maintain" ... seems low probability but people be freaks, ya know? Pan talks about some of them here: In general I'd recommend: (1.) EZ Detail's boar's hair brush set, & Braun's boar's tire brush (you can cheap knock-offs, but you get what you pay for here) (2.) Superclean diluted 5:1 (3.) Tire first, spray on, dwell, agitate, rinse. (4.) Dress & protect |
12-01-2021, 07:43 PM | #8 |
Rep 57
Adam's wheel cleaner. They also have a wheel woolie for the inside of the wheel, but for the spokes on my 740M style wheels, I use Adam's Wheel Cleaner and a microfiber towel.
