      12-12-2021, 10:55 PM   #1
Nigel1500
Australia
28
Drives: BMW X5 (G05) 30d M-Sport
iDrive Problem
Hi Folks,
My car developed a problem with iDrive early this year. It has stayed with the car through subsequent updates. BMW Service has been unable to fix it. The problem is that sometimes the car changes from EcoPro back to Comfort without me pressing the button. I like to drive in EcoPro simply because I like the blue screen. Also, I press the button to disable the Start/Stop ... but that turns itself off sometimes. The Air Recycle button also turns itself off sometimes.
Details:
  1. Press Start Button
  2. Press Eco Pro
  3. Press A-Off to turn off Auto Start/Stop
  4. Press Air Recycle button
  5. Put Car into gear
  6. Release parking brake
Then .... any one of the following can happen during the first five minutes of driving:
  1. The car will put itself back into Comfort mode
  2. Auto Start/Stop will renable
  3. Air Recycling will be turned off
  4. ... or none of the above
I can have 3 or 4 days with no problem, then one of the above will happen. Sometimes when I press the appropriate button to correct the problem it will happen again several minutes later.
The car is due for a service. I thought I'd ask here if anyone else is experiencing this before I put the car in.
      12-13-2021, 09:40 AM   #2
maxim38rus
maxim38rus's Avatar
Drives: BMW X1, X5, i3, 6GT
Originally Posted by Nigel1500 View Post
Hi Folks,
Details:
  2. Press Eco Pro
Is any of the following the case for you? If yes, that may explain why the car switches the driving mode. Though, it's strange the car does so silently.
      12-13-2021, 03:14 PM   #3
JimVR4
JimVR4's Avatar
Drives: 21 X5 M50i M-Sport
I would guess the control panel is faulty. It seems to be sensing button presses that you did not make.
2021 G05 X5 ///M50i / Phytonic Blue / Cognac Vernasca
iStep 03/2023.50
      09-23-2022, 08:49 PM   #4
Bking60
Drives: BMW X5 2019
Multiple control panels involved per your description. The Body Control Module controls dozens and dozens of things so I would say replace it. BMW does not like them testing that way unfortunately so they should at least reseat the connectors and reflash that module. On second thought, the recirc should be part of the HVAC control module. Are you sure it's not a battery(s) problem?
