      11-26-2019, 09:18 AM   #45
dubsesd
#dubspec
dubsesd's Avatar
6336
Drives: G05 X5/ 2016 F80 M3 INDVL
Originally Posted by isrodrig View Post
In my opinion, on of the best looking G05 in ths forum so far
Thank you, I appreciate that
LCI ///F80 M3 Individual Atlantis Metallic / Black Full / Carbon Cermics / 6MT
MPE / M Performance & Carbon package / KW v3 / 20" HRE R101LW / 20" HRE 527s / Michelin PSS / 20% tint / 3d Design / Streckenn splitters / OEM GTS hood / EAS Carbon seatbacks / Carbon RKP sideskirt / Bootmod3 / M Performance Tri color alcantara / AWE S Flow
instagram: @ dubsesd
      11-26-2019, 08:42 PM   #46
Luminor513
Luminor513's Avatar
1243
Drives: 2020 G07 x40i BSM/Blk Merino
I second that. This car was my inspiration for ordering a G05, up until I saw this thread I was on the fence about getting X5.
2022 Audi E-tron S Mythos Blk/Blk Valcona
      11-28-2019, 02:24 AM   #47
X5Guy
Drives: X5
What size tires are you running?
      11-28-2019, 06:39 PM   #48
dubsesd
#dubspec
dubsesd's Avatar
6336
updated with new lip and custom lowering links for the air ride
CGJ999123.00
      11-29-2019, 01:08 PM   #49
black_F10M5
black_F10M5's Avatar
289
Drives: F10 M5
the lip looks amazing bro! Give the M sport bumper an even more aggressive look
2016 M5 | Instagram: @black_f10m5
IND cosmetic | M Performance , RKP , 3D Design aero | Eisenmann Race exhaust | AMS catted downpipes | MSR intake | CSF charge coolers | DME Stage 2 tune | KW v3 coilovers | BBS FI | Michelin Pilot Sport 4S
dubsesd6335.50
      11-29-2019, 03:25 PM   #50
dubsesd
#dubspec
dubsesd's Avatar
6336
yes it totally completes the front end
Appreciate 4
      11-29-2019, 03:42 PM   #51
atl_1M
Drives: '11 1M, '20 X5 40i
What do you mean by custom lowering links? Please explain. Btw your car is my inspiration for really obsessing over ordering an X5 haha.
      11-29-2019, 05:02 PM   #52
dubsesd
#dubspec
dubsesd's Avatar
6336
I have the air suspension option. You can lower the car in any mode even further by swapping the OEM fixed plastic leveling arms with shorter adjustable ones. 100 dollar swap
      11-29-2019, 05:25 PM   #53
dubsesd
#dubspec
dubsesd's Avatar
6336
      11-30-2019, 03:38 AM   #54
Kief
Kief's Avatar
4440
Drives: '24 iX50; '23 i4 M50
Looks awesome! Obviously you are lowered, but the stance is so much better than the new F95. And you better stop postponing swapping on those winter shoes!!! j/k I'm holding out a little longer myself!
'24-I20 iX 50; '23-G26 i4 M50; '22-G82 M4Cx*;20-G05 M50i*; '20-F82 M4CS*; '18-F80 M3CS*; '18-F80 M3CS*; '18-F85 X5M*; '18-G01 X3M40i*; '18-F80 M3ZCP*; '17-F80 M3ZCP*; '15-F15 X5*; '15-F82 M4*; '12-E92 335is*; '11-E70 X5d; '11-E89 Z435is*;'09-E89 Z435i*; '08-E92 335i*; '06-E90 330i*; '05-E83 X3*; '04-E83 X3*; '03-E46 325Ci* *retired
dubsesd6335.50
      11-30-2019, 09:38 AM   #55
dubsesd
#dubspec
dubsesd's Avatar
6336
winter wheels are patiently waiting in the corner of my garage lol. not swapping till the day it snows
      11-30-2019, 10:19 AM   #56
Kief
Kief's Avatar
4440
Mine too
dubsesd6335.50
      11-30-2019, 03:39 PM   #57
atl_1M
Nice, I'll have to look into that once mine arrives. A few noob questions:
Mind sharing the source for the shorter adjustable arms?? And how much lower does it go compared to stock air suspension? And how do you go about adjusting the height of the new leveling arms?
Thanks!
      12-06-2019, 09:35 PM   #58
dubsesd
#dubspec
dubsesd's Avatar
6336
Thanks!
bbm motorsport in germany. its about 1.5-2 inches lower in each setting. you adjust the arms as per instructions. 6mm extended up front and 5mm shortened in the rear.
Appreciate 3
r33_RGSport12971.00
atl_1M1520.00
      12-07-2019, 08:24 PM   #59
atl_1M
Oh wow, quite low then. Looks slammed and aggressive. Any rubbing? And do you know if they sell arms that aren’t as low, maybe 1” lower than standard? I couldn’t find them on their website.
Thanks!
      12-08-2019, 08:03 AM   #60
dubsesd
#dubspec
dubsesd's Avatar
6336
They are adjustable. Standard setting is about 1.2-5" lower in each setting. Your loading height becomes drive height in sport
atl_1M1520.00
      12-10-2019, 01:15 AM   #61
bhe
Belgium
105
Drives: X5 G05 45e
Is it this ?
https://www.ebay.co.uk/itm/223701956817
Hamann has also something but quite expensive, see
https://www.hamann-motorsport.com/en...lists-for-bmw/
https://www.hamann-motorsport.com/fi...W_X5_G05_E.pdf
      12-10-2019, 09:42 PM   #62
dubsesd
#dubspec
dubsesd's Avatar
6336
Yes, the BBM links are what I have
      12-24-2019, 10:24 AM   #63
BA
Drives: BMW G05 X5 40
Your car looks amazing!! Just purchased a g05 40, I’m interested in the lowering links that you have, are you able to adjust the front to 3mm instead of 6mm if wanted will it give less of a drop?
After lowering did the ride become harsh?
Did your car need an alignment? And did the instructions come in English?
      12-25-2019, 12:12 PM   #64
dubsesd
#dubspec
dubsesd's Avatar
6336
There is no difference in ride quality. It's identical. 6mm on the links equals to about a 1.5-1.8" drop. 3mm is also possible and would equal about .75 -1" drop. Alignment is recommended but it was not off by much after my installation. I used Google translate on my instructions but it's pretty straight forward. Installation level is about 4/10. You have to be gentle removing the plastic links from the plastic ball fittings. If not heated up they will break
      12-25-2019, 12:22 PM   #65
BA
Got it. So they sent you the instructions over email & than translated. I figured maybe the ride will get a little more bouncy due to the height
Now the loading height does it get lower than the previous height? If so an additional 1.5" must be slammed
      12-25-2019, 12:54 PM   #66
dubsesd
#dubspec
dubsesd's Avatar
6336
Instructions come on a paper included in the box. Google translate app allows you to take a photo of the paper and gives you a direct translation . Yes. In loading mode it's tucking tire
