05-31-2020, 07:38 AM | #1255 |
817
Rep 1,785
Where do you purchase the MHD Adapter and how much did it cost? Will it work with an Android phone? Thanks.
COL(Ret), US Army Hagerstown MD 2019 X5 40i MSport Alpine White/Coffee (my 13th BMW) 2015 Mercedes SL400; 2009 Lexus RX350 |
05-31-2020, 10:09 AM | #1256 | |
Rep 419
https://www.bimmercode.app/adapters/
2019 X5 40i M-Sport
07/2020.54 -> 11/2020.50 -> 03/2021.50 -> 07/2021.85 [All OTAs] |
05-31-2020, 06:55 PM | #1257 | |
2020 Mineral White 30d MSport
524
Rep 2,146
Drives: 2020 Mineral White 30d MSport
These are the options shown" Comfort 0x04, Eco ProEfficent, PHEVElectric, PHEVHHybrid, Unassigned value 0x0A and Custom Value Thanks in advance
05-31-2020, 07:24 PM | #1258 |
Rep 264
I need help.
I can not make connection to my OBdLINK MX+ with Bimmercode app. It's keep telling me connection has been terminated. Am I doing anything wrong? My OBDLINK firmware version is 5.5.0 |
05-31-2020, 07:28 PM | #1259 |
Rep 853
I have the Veepeak which isn't supported any longer. With the recent update, I can now close the trunk via inside door and remote. I'm happy!
2018 540ix msport
2015 X5 msport 2013 750ix msport 2011 550ix msport 2009 e92 335i msport |
05-31-2020, 07:28 PM | #1260 | ||
Rep 2,609
If Sport+ is not available stock on 30D, we'll need to do a bit more.
05-31-2020, 07:34 PM | #1261 |
Rep 2,609
Hm. Did you select that exact interface in the Bimmercode setup before trying to connect? Is the car on (sorry)? Did you select G05 X5 when connecting? iOS or Android? Airplane mode with everything except Bluetooth off? Bluetooth on?
Habsone73.50 |
05-31-2020, 07:44 PM | #1262 | |||
524
Rep 2,146
05-31-2020, 07:57 PM | #1263 |
817
Rep 1,785
Interesting. I also have a Veepeak. Did you use an Android phone?
05-31-2020, 08:44 PM | #1264 | |
Rep 264
iOS. I was able to code some of the features like 5 blink turn signal,Alpina in instrument cluster etc. this morning. After doing all that I updated OBDLINK to 5.5.0 version and after that I tried to code again and since then the app is keep telling me connection error. All the coding was done with engine running if that's make any difference. I have tried to code with engine running and off. Even tried with pushing the ignition button on without pressing brake paddle. When I try connecting the app. with engine off and as soon as I select X5 on the app instrument cluster comes on by itself and i get connection error. I have deleted bimmercode app. and reinstalled it just to see if that would help but nothing is working. I'm sure I am not doing something right but I just can not pinpoint what it is. I have 03/2020.40 My apologies for long post. UPDATE Just received an email response from Bimmercode. Hi, this is a problem caused by the latest OBDLink firmware. Please contact OBDLink support for a solution. Downgrading the firmware will work most likely. I'll downgrade firmware and try again later this afternoon. Last edited by Habsone; 06-01-2020 at 02:56 AM.. |
LexxM31698.50 |
05-31-2020, 09:12 PM | #1265 | |
Rep 853
I haven’t checked for other features ie: driving mode or expert mode coding but I will tomorrow.
2018 540ix msport
06-01-2020, 03:08 AM | #1266 | ||
Rep 71
All works fine with version 5.40. Stay away from 5.50. |
06-01-2020, 04:02 AM | #1267 |
Rep 264
Thanks Jeet. I'll install 5.40.
One more thing if you or other members can help me with. Do i code with SAV running,Off or One push of start button without pressing the brake paddle? Which is the safe and more efficient way to code? I have read all the pages and just can not remember. Thank you |
06-01-2020, 05:10 AM | #1268 | |
Rep 810
Body Domain Controller (BDC) ECU:- 3221 PfFesMaster module: - FesPiaDefaultSportWorldMode: change to 0x02 (SportExpert, aka Sports Plus) - FesSportWorldMode1: change to 0x02 (SportExpert, aka Sports Plus) HU_MGU ECU (Head Unit):- 3008 FES module: - FES_SPORT_EXPERT change to aktiv - SPORT_CONF_ATTENUATION_SPORTPLUS change to active - SPORT_CONF_STEERING_SPORTPLUS change to active |
LexxM31698.50 |
06-01-2020, 07:33 AM | #1269 |
Rep 583
Drives: F10 535i, M2 LCI, G05 X5 40i
So today I was playing with Bimmerlink, opening and closing the exhaust flap. I then coded Active sound design off in Bimmercode, and now Bimmerlink throws an error when I try to control the exhaust flap.
Anyone else experienced the same? |
06-01-2020, 07:46 AM | #1270 | |||
Rep 2,609
Habsone73.50 |
06-01-2020, 10:12 AM | #1271 | ||
524
Rep 2,146
Cheers mate
06-01-2020, 07:05 PM | #1272 | |||
Rep 71
Habsone73.50 |
06-01-2020, 09:34 PM | #1273 |
524
Rep 2,146
Successfully coded, will test it tomorrow on my daily commute to work after engine gets into normal working temperature
James_G0540i446.00 |
06-03-2020, 08:01 AM | #1275 |
Rep 810
