05-28-2020, 08:05 PM | #1 |
Rep 29
03/2020.30 and Heads-up Display
Just picked my picked up my X5 from service and on the way home noticed that my green icons for the cruise control on the heads-up display aren't displaying anymore when I go to activate the cruise control or make adjustments to the speed. I'm not sure if something got deactivated in the settings or there's an issue with this software upgrade.
Anyone else notice this? |
05-28-2020, 08:24 PM | #2 | |
Rep 4,246
Sport mode will switch to Sport display in heads up unless you change the HUD settings.
coolerbythelake282.00 |
05-28-2020, 09:20 PM | #3 |
Rep 29
I'm driving in comfort mode - speed limit (left), vehicle speed (right). I do have the tachometer turned on (via the HUD setting) which appears above those two and had it on since delivery last summer, and the green icon used to appear. I was previously on 07/2019.xx
05-28-2020, 10:10 PM | #4 | |
Rep 4,246
I recall enabling tach in HUD display or sport mode that adaptive cruise control speed did not display. My G05 is on 07/2019.63.
MDBMW7619.50 |
05-28-2020, 10:59 PM | #5 | |
Rep 2,415
Chosen speed. Current speed. Speed limit are displayed. If the speed limit changes in the bottom left an icon "set" appears. If set is pushed on the steering wheel it goes to this speed. I have chosen to set it 5 km/h higher. In sport like mentioned by Auricom it is different but I disabled this. Maybe do a good old push the volume button 30 sec Idrive reset? Solves a lot. |
05-29-2020, 11:41 AM | #6 |
9
Rep 45
I know on my 2020 X5 M5.0 with 11/2020.55 running that when the tach is on the HUD, some of the other elements disappear. They reappear when I get OUT of Sport mode, or remove the tach.
So, guess I am seeing the same thing. Adam |
MDBMW7619.50 |
05-29-2020, 12:39 PM | #7 |
Rep 2,415
05-29-2020, 01:08 PM | #9 |
Rep 2,415
05-29-2020, 06:35 PM | #10 | |
Rep 4,246
I took quick photos of the HUD displays with sport display active and inactive. G05 was in driven in Adaptive Mode and Active Cruise Control, Active Lane Keeping Assistant and Steering and Lane Control Assistant active. TLDR; With SPORT display on in HUD, active cruise control, lane keeping, steering and lane control info are not displayed. HUD display showing speed limit, current speed, active cruise, steering and lane control assistant active HUD display showing speed limit, current speed, and sport display on - note active cruise, steering and lane control assistant are still active HUD iDrive Setting where you can set SPORT displays always on or only in SPORT mode
volodp193.50 |
05-30-2020, 09:14 PM | #11 | |
Rep 29
