05-29-2020, 07:40 PM | #2 |
Rep 4,246
Ummm behind the door release handle...
05-29-2020, 07:44 PM | #3 | |
Rep 64
Try and let me know. |
05-29-2020, 07:50 PM | #4 |
Rep 4,246
There's a owner's manual - online or provided, suggest you read it.
05-29-2020, 07:55 PM | #5 |
Rep 64
05-29-2020, 07:59 PM | #6 |
Rep 4,246
05-29-2020, 10:51 PM | #7 | |
Rep 2,420
She will probably make you remember not to this a second time. Edit. Just reviewed the app: the car recognizes a person in the passenger seat. If the seat belt is attached it won't activate the alarm and it won't lock the flap to the fuel inlet in automatic lock. Good thinking BMW. |
maxim38rus11.00 |
05-30-2020, 02:12 PM | #9 | |
Rep 7,484
Prior to the 2000 model year...if you locked anyone inside a BMW...there was no out at all. The interior door handles would be in “double-lock” mode...won’t open from the outside or inside...which made car thieves that break the glass to get in...would have to crawl through the broken glass because the doors aren’t going to open no matter what. Then BMW changed things in 2000 and made an out by designing an “out” (but most people including owners never read it in the owners manual)...but if you would press the central lock/unlock button...you could then do TWO pulls on the interior handles and the door would unlock and then be opened. As more technology evolved and CAS & CA (car access system & comfort access) came along...some markets got “outs” some may not have...as mentioned already...READ YOUR OWNERS MANUAL. You can see in the BMW info below the procedure for getting out of the car when it is double locked...see FROM 2000 MY: The info below discusses the central locking system’s “states” aka single-lock or double-lock. But this was BEFORE the new gen BMW’s CAS/CA systems when the lock/unlock command came from the GM (general module). But although the control module may have changed since then...the single-lock & double-lock feature is still part of the vehicles central locking design:
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 05-30-2020 at 02:23 PM.. |
05-30-2020, 02:56 PM | #10 | ||
Rep 2,420
I couldn't find the unlocking technique you describe did you get this for the G05? |
05-30-2020, 03:30 PM | #11 | ||
Rep 7,484
These new gen BMWs may not work the same way...they have so many electrical nannies (like the front passenger occupation sensor detecting passengers for locking as well as air bag deployment).
06-10-2020, 06:44 PM | #12 | |
Rep 64
Follow up
I believe the US models may have an alarm of some sort. This could have serious consequences as i left my parter rest in the car the other day as i went to do something both thinking she could get out. I returned 30min later and she, lucky it is winter and not 45 Deg C The dealer wrote down to investigate. |
06-11-2020, 10:14 AM | #13 | |
Rep 7,484
Is there anything in the G05 owners manual that give this type of warning? I ask because my f06 BMW owners manual does give a warning just like my other manuals in regards to locking passengers inside the vehicle. The "special knowledge" required to unlock the doors when they've been double-locked may be what's written in the BMW tech info above about the central locking system. Back in 2000 when they designed an "out"...you were to press on the central locking button, then pull twice on the door handle. Since the g05 doesn't have the single central lock/unlock button...but know has lock/unlock buttons on each door...try those instead...then pull twice on the door handle to see if that will let locked in passengers escape. See some example below of the warning not to lock passengers inside the car...1st pic is from my f06 BMW owners manual...2nd pic is taken from a G05 X5 owners manual I just googled today...and it has the same warning as BMWs from the past about not locking passengers in the car from outside the vehicle:
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 06-11-2020 at 10:34 AM.. |
Arfy22.00 |
06-11-2020, 06:52 PM | #15 |
Rep 7,484
So the same scenario continues...if you’re going to leave passengers in the car...have them LOCK the car from inside if they are going to remain with the vehicle. This will then not make them a prisoner inside the cabin...where the IMS (interior motion sensor) won’t go off after approx 30 seconds when they make a move...and the passengers (or your pet) is stuck inside with the alarm blaring and lights flashing.
timmahh483.00 |
06-12-2020, 01:19 AM | #16 | |
Rep 64
06-12-2020, 01:27 AM | #17 | ||
Rep 64
My issue i do 18 hour drives only stopping for diesel and eat and breaks. My senario is my partner is sleeping and want to stay sleeping either when we arrive at the farm or in a town along the way while i do other thing and she gets out when she wants and stays with the car. This is the only car i have had that she will now be locked in. I just need to make sure the spare key is always in the car. |
06-12-2020, 05:42 AM | #18 | ||
Rep 2,420
06-12-2020, 09:58 AM | #19 | |
Rep 7,484
If the interior handles are still disabled (double-locked)...perhaps pressing the lock/unlock button on the door (1st) then pulling on the interior door handles will release from double-lock.
Arfy22.00 |
06-12-2020, 08:31 PM | #20 | ||
Rep 64
06-14-2020, 06:17 AM | #21 |
Owner
132
Rep 566
Drives: G05 30d M-Sport
Careful if you have Comfort Access, as the car will lock /anyway/ when you walk away, even if thre's someone in the passenger seat.
This occured to be a couple days ago; I walked away from the car with my wife inside, it locked itself (and folded the mirror) and she was locked in *even tho she has her one key for the car!) and she had to use her own key to unlock and walk out. I think the comfort access is a bloody nuisance; they actually never thoguth thru what to do if 2 people have a key each, it's so irritating to walk to the driver door, open, she see the seat moves itself back to /her/ position just because she arrived at the passenger door 10ms quicker than I did. You then have to tell her to walk away, re-lock the car, re-unlock the car and watch the seat move back. So much for "comfort"!
Received 190911: X5 30d M-Sport:Artic Grey:Comfort Pack:Tech Pack:Visibility Pack: Driver Assist Pro Pack:Heat Pack:Glass Roof:Leather Dash
Arfy22.00 |
06-14-2020, 07:10 AM | #22 |
1037
Rep 1,526
I turned off the auto lock when walking away as it was such a nuisance locking and unlocking when working around the vehicle. Now I just tap the outside door handle when exiting the car.
2021 M40i Phytonic Blue / Black Vernasca
2020 X5 xDrive 40i Tanzanite Blue / Coffee Vernasca 2011 328xi. Space Grey - Sold 188,925 great miles |
Arfy22.00 |
