01-15-2024, 09:02 AM | #1 |
Rep 273
Antenna/Telematics Module DIY question
Replaced the battery, the telematics module and the antenna + Cap. They were all water damaged.
Does anyone know if I need to go to the dealership to get this programmed? It's still showing Emergency call malfunction and the Navigation is not working. Tried resetting the idrive but did not help. Surprised that the cap for the antenna didn't just fall off on it's own, barely put any pressure when trying to remove it and the cap just flew off. Looks like its the paint on the inside of the antenna cap that was the weak link. |
01-15-2024, 12:04 PM | #2 |
257
Rep 332
Did you do the 20-30 second iDrive reset or longer?
There's been conflicting info on this but supposedly you can do a TCU reset by holding the volume button for about 70 seconds - basically long enough for you to see iDrive start a 3rd reset/restart. Might be worth a try .... Also possible you may need to use an OBD scanner (or something similar) to clear the stored codes in order to get everything working again.
2020 BMW X5 M50i . Tanzanite Blue II . Black Merino . Extended Shadowline . 742M Black / ART Replica 181
07/2019.55 (since birth Oct.1,2019)-> 11/2019.70 (OTA Aug.11,2020)-> 11/2020.36 (Dealer Nov.25,2020)-> 03/2021.50 (OTA Jun.15,2021)-> 07/2021.85 (OTA Mar.1,2022)-> 07/2022.58 (OTA Dec.9,2022)-> 11/2022.60 (OTA Mar.2,2023)-> 03/2023.50 (OTA May.31,2023)-> 07/2023.35 (Dealer Aug.21,2023)-> 11/2023.50 (OTA Feb.9,2024) |
FatHulk127.50 |
01-15-2024, 12:22 PM | #3 | |
Rep 273
01-15-2024, 02:52 PM | #4 |
Rep 8,705
Drives: eVeRyOnE mAD!
01-15-2024, 03:46 PM | #6 |
Rep 273
01-16-2024, 09:45 AM | #9 |
Rep 8,705
and you held the button down constantly through 3 consecutive reboots?
01-16-2024, 10:59 AM | #10 |
44
Rep 37
Have you tried to disconnect the batteries? I had the same error massage and it is the second time the TCM went bad (previous one replaced under warranty but lasted only a year). Besides the error message, my SOS call was also activated and the center screen only showed "emergency call is activated, data is transmitting....". I could not turn that screen off or to display anything else. The screen was basically stuck like that. I tried all kinds of reboot which did not help. I finally disconnected the main battery in the rear truck and the backup battery in the engine bay close to the jump connectors. Waited for 5 minutes before connecting the batteries again and got that screen display back. Now only small text error message in the bottom centre of the dashboard. I am also trying to replace the TCM myself, but not sure if it requires coding. Please let us know what you find out with the dealer.
FatHulk127.50 |
01-16-2024, 11:01 AM | #11 | |
Rep 4,343
In your pic, the antenna film is covering the guts but may I presume that the battery you replaced is under the film? I'm wondering if the water ingress caused a short and damaged the circuitry and that is why you cannot get it working or if a connector or two came loose, popped of, etc. |
FatHulk127.50 |
01-16-2024, 11:10 AM | #12 | |
44
Rep 37
El_zorro20.00 |
01-16-2024, 11:28 AM | #13 |
Rep 273
01-16-2024, 11:32 AM | #14 | |
Rep 273
I replaced with all new parts - Battery, TCM, Antenna, Antenna cap. I'm probably going to put a bead of silicone around the antenna so water can't get in but I'm hoping this gets fixed. Will try unplugging the battery as another user has suggested, but might need to take it to the dealer for programming/coding. |
Marty in NY2727.50 |
01-16-2024, 11:35 AM | #15 | |
Rep 273
01-16-2024, 11:36 AM | #16 | |
Rep 273
01-16-2024, 11:59 AM | #17 | |
Rep 4,343
01-16-2024, 12:41 PM | #18 |
Not So New Member
32
Rep 46
My TCB unit was replaced at the dealer last week for water damage. The notes on the work order state "Performed replacement programming with complete vehicle encoding afterwards." Hope that helps.
2021 X5 45e M Sport, Alpine White/Ivory/Aluminum Dark Mesh Trim
2010 135i M Sport, Alpine White/Black/Aluminum Trim (DIY Edition - 6 speed - No iDrive) |
535gtxenon43.50 FatHulk127.50 |
01-16-2024, 12:44 PM | #19 |
44
Rep 37
01-16-2024, 03:09 PM | #20 |
Rep 273
Thanks looks like a trip to the dealer is the only way to get it sorted
01-16-2024, 03:10 PM | #21 | |
Rep 273
01-16-2024, 04:18 PM | #22 |
Rep 82
Just got the same problem on my car with the the emergency call failure, gps no longer working correctly and loss of connection to the bmw connect drive server. Looks like this is a latent defect as there are number of owners with the same issue. It’s not helped by the fact that the roof is concave where the shark fin is attached which allows water to sit around it.
Bottom1615.50 |
