      05-14-2019, 12:27 PM   #1
Oliver@VelosDesignwerks
Drives: E46 330ci
Talking BMW X5/X6 (G05/G06) | Velos Designwerks OBDII Summer Promo going on now!!
Hello Bimmerpost Forum Members!
We are excited to offer you our OBD2 tuning for your X5/6! After years of various direct to ECU tuning, our engineering team along with the majority of the industry, Velos Designwerks is pleased to offer our OBD2 tuning solutions for your BMW X5/X6 (G05/G06)!
The G05 X5/X6 50i boast an amazing maximum output of 456HP and 479 lb ft of torque from the factory! BMW has done an amazing job with the vehicle, but our engineering team has spent countless amount of hours in R&D to provide a reliable tune that will stay well within factory safety parameters set by the manufacturer.
After much success with the previous Generation X5 & X6’s tuned the results on this platform has gone through a few stages with the most recent allowing us to produce gains of 115 hp and 130 tq on the G05 & G06 50i platform! Thats a 25% increase of factory power output!
Below you will find customer submitted videos, dyno sheets (Mustang Dyno), as well as dragy data!
With our tune your vehicle will never be the same! It is a must for the enthusiasts looking to maximize their vehicles potential. Please feel free to reach out by reply, phone or email to inquire about our early bird, and forum member special pricing! Below you will find a video and real time stats provided by one of our other forum members!
Oliver@velosdesignwerks.com
786.401.6520 ext. 104
- - - - - - - - - - POWER GAINS for 40i models - - - - - - - - - -
+78hp
+86tq
- - - - - - - - - - POWER GAINS for 50i models - - - - - - - - - -
+115 HP
+130 TQ
Make your X5/X6 the king of the rest today!
MystroX56292.50
      05-14-2019, 01:26 PM   #2
dream54ing
dream54ing's Avatar
Drives: 428xi F32- X5 X5 G05 -640i F06
still trying to figure out what to do with the first 335HP on our 40i
Appreciate 4
gpitts247.00
bichoo280.50
kleo12.00
Ftpohyeah285.00
      05-14-2019, 02:52 PM   #3
Drives: E46 330ci
All PMs replied
      05-14-2019, 04:31 PM   #4
AndroidRobot
AndroidRobot's Avatar
  [0.00]
what are the true stock uncorrected dyno numbers, BMW always underrates their engines Please also list the dyno type
gpitts247.00
      05-16-2019, 09:17 AM   #5
Drives: E46 330ci
Depending on your dyno and conditions power would range anywhere from 440-460 to the wheels.
We have tuned the G05 before with much success and I am reaching out to our marketing team for dyno graphs.
      05-16-2019, 10:11 AM   #6
AndroidRobot
  [0.00]
Can I see some data from a stock G05 X5 50i?
      05-16-2019, 10:36 AM   #7
Drives: E46 330ci
Will upload the data shortly!
      05-16-2019, 10:58 AM   #8
AndroidRobot
  [0.00]
for the stock car uncorrected right? I'm trying to see the true baseline at the wheels since we all know BMW understates the output
      05-16-2019, 12:42 PM   #9
Drives: E46 330ci
Understood, in this case you can clearly see that. For Austin's car above he was not able to get a printout for the true stock run. Will work to see if we can obtain it from his end. Also waiting to see what other local data we have available. We typically use a dynojet and post videos, etc once the client(s) are ok with it.. any dealer cars we use for Demo cannot be posted.
      05-16-2019, 12:44 PM   #10
Drives: E46 330ci
Updated original post with random independent data that was sent back.. including draggy runs and a before and after vid.
      05-16-2019, 02:39 PM   #11
AndroidRobot
  [0.00]
thank you! I see, mustang dyno so the numbers will be lower than a dynojet ie they're more conservative.
let me clarify: assuming both dynos are calibrated properly and everything else is the same a DynoJet usually reads higher than a Mustang but the accuracty of either is not something I'll go into.
I take it the top most chart is stock then stage 1, 2?
      05-16-2019, 02:56 PM   #12
Captain Gumbo
Drives: 2019 X5 50i
This is a bad idea, this is a bad idea, this is a bad idea....dammit it's 45 minutes from me. I don't need 571 hp, but this seems like it'd be crazy fun.
      05-16-2019, 03:46 PM   #13
Ken6096
Ken6096's Avatar
108
Drives: BMW X5M F95 2022
I think the same. I almost buy it but asked for some advise from member in this forum and got some point to think about this. I need more information or honestly, need the review from real user. But really wanna try my most concern is it is not gonna blow my engine in long run and dealer will not notice.
BMW X1 F48 2017 sold
BMW X5 G05 50i 2019 sold
BMW X5M comp F95 2022
Mini clubman JCW F54 2019
      05-16-2019, 03:50 PM   #14
AndroidRobot
  [0.00]
Go to the DIY subforum (I believe it's that one), Austin (user on here) has it on his which is the car pictured above. He should be able to give you more insight
      05-16-2019, 05:00 PM   #15
Drives: E46 330ci
Ken,
Luckily our tunes are kept within BMWs safety parameter for this reason. The goal of our tune is for you to enjoy the additional power and drivability of the vehicle without sacrificing reliability. As far BMW noticing we recommend returning the vehicle to the stock tune, which with our handheld takes only about 15 minutes. You can feel free to PM or Call me for more info!
      05-16-2019, 09:37 PM   #16
AndroidRobot
  [0.00]
Ken,
On that note, you're pushing the same boost as a full ///M car (25-26psi) with less cooling, less reinforcement etc so I'm curious to know why BMW engineers thought it was needed for that much boost in the X5M/M5 because I doubt it was for fun. Tunes can be safe, a 10psi tune is a lot for any car (based on what iDrive was showing which is a measured value if I'm not mistaken) I'd think a larger/better intake would be needed for proper air flow. Don't have any additional data showing the engineering parameters of the N63M engine in the G05?
      05-17-2019, 08:47 AM   #17
Drives: E46 330ci
Hey, thanks for the reply. Majority of increases whether a BMW, Ferrari, Mercedes, etc is 3.5-5.5 increase with boost tapering off towards redline mimicking the factory power band (no 10 psi increase on any stock platform. Cannot see what you are mentioning in I Drive but increase is not 10 psi)). Same holds true for the E70 chassis, F15, and now the G05 family. Regarding the parameters those are all within the tuning area of what is changed by our team. Majority is torque limiter, fuel, ignition control... Intakes are hit or miss , in our opinion the factory intake system is perfect.
All pm's have been replied to, thank you. If I have not gotten back please let me know and always available via phone here at the office.
      05-17-2019, 11:31 AM   #18
AndroidRobot
  [0.00]
how is this not about 25psi of boost. the value is measured not calculated per BMW NA
Pic link incase the forum is dumb again. https://photos.app.goo.gl/qMxy7wsNbUWhDWCa7
that's from the members car you tuned btw
      05-17-2019, 02:02 PM   #19
Drives: E46 330ci
Hey,
Here are two screen shots from the videos above. Regarding the Drive gauges they are also not accurate but these screen shots give a good comparison. Not sure which member that was from but everyone is running the same or a few detuned. Let me know if you have any other questions regarding the tune for your car or feel free to give us a call 7864016520
      05-17-2019, 02:25 PM   #20
AndroidRobot
  [0.00]
Hey,
[img]https://live.staticflickr.com/65535/...02fcd32e_o.png[/img]
[img]https://live.staticflickr.com/65535/...e81d75ef_o.png[/img]
Austin G05 I'll link the OP he's the guy whose car you tuned
here you go!
https://g05.bimmerpost.com/forums/sh...1570329&page=2
I took a screenshot for you too. please explain the boost now I'm not trying to be a dick but what you're saying doesn't match up with his car from your shop.
https://photos.app.goo.gl/hmCm1DfuVizNn9Fk8
gpitts247.00
      05-17-2019, 03:33 PM   #21
Drives: E46 330ci
here you go!
No one ever said you were being that, not sure why you feel that way. I think your contribution to the forum is top notch. Regarding his screen shot maybe, a spike or something but a 10 psi increase is not possible and the factory fuel system would not be able to support it. Accurate data can be retrieved via the adjustments made in any editing software or an actual gauge but it would require tapping into the factory system.
Increases are not 10 psi and we received two videos with the screen shots above.
Thanks again for the input and taking your time to clarify.
      05-17-2019, 03:38 PM   #22
Drives: E46 330ci
haha
Tags
bmw, bmw x5, bmw x6, g05, g05 x5, g06, g06 x6, suv
