04-26-2023, 01:02 PM | #1 |
Rep 29
M50i exhaust options?
What is the best way to improve the X5 M50i exhaust? Is there any way to make it sound like it does at startup, when driving in sport mode? Seems as though after 2-3 minutes this engine really quiets down.
I have seen some do a resonator delete, but I am worried about drone. What is the best way to give the X5 M50i a little more life under acceleration? |
04-27-2023, 04:41 PM | #2 | |
Rep 821
I'm having the same issue as you where I want to make it sound like startup when driving in sport mode. |
Bottom1615.50 |
04-29-2023, 03:34 PM | #3 |
Rep 29
Would you recommend the resonator delete?
It’s a shame there is no easy solution to this. I’ve done some research and there seems so be very limited aftermarket exhaust options |
04-29-2023, 06:48 PM | #4 |
Rep 1,354
Drives: 2022 X5 m50i
Resonator delete is not even close to what you hear at start up. You need muffler delete.
2022 BMW X5 m50i
2024 MB S63 on order '18 X5 50i / '16 BMW F10 550xi / '13 BMW F10 535i / '07 BMW E64 630i / '03 BMW E65 745i / '95 BMW E34 540i / '89 BMW E30 M3 |
05-04-2023, 08:36 AM | #5 |
Rep 16
i have a 2019 50i m sport, just did a mid-muffler delete last weekend, save your money and look into modifying the rear muffler, that's what I'm looking into doing now also. mid mufflers are not like past generations when they were bigger, i added an H pipe and it sounds a little deeper and louder, cant speak for what is sounds like outside the car tho
Cruise'n71.00 |
05-09-2023, 11:08 PM | #7 | |
Rep 2
You could also cut open the muffler and redirect some of the airflow within the muffler or just replace the stock muffler with one half the size of it. That'll require a skilled muffler shop and more money to do though - if I had to guess $500-900. |
05-12-2023, 10:29 AM | #8 | |
Rep 2,079
Mods for sound -Resonator delete with straight pipes -AA catted downpipes -Flaps always open
05-22-2023, 12:12 PM | #9 | |
Rep 520
05-22-2023, 07:57 PM | #13 |
Rep 1,354
Exits are completely different as well. Too much fabrication for a part that costs an arm an a leg to begin with.
2022 BMW X5 m50i
MotorboatinSOB17.00 orkinos185.50 |
08-01-2023, 08:59 PM | #16 |
Rep 467
Drives: 2023 X5 M50i
Anyone know if a resonator delete is reversible? I have a lease vehicle so wouldn’t want to do anything that isn’t reversible.
08-02-2023, 09:51 PM | #17 | |
Rep 74
08-11-2023, 08:28 AM | #18 |
Rep 125
Here is my setup:
Xpipe Muffler Delete Exhaust Tips Some droning noise @ 1800 RPM (comfort mode), but drop it into sport mode, and it is fine. Parts: https://g05.bimmerpost.com/forums/sh...&postcount=218 Photo from rear: https://g05.bimmerpost.com/forums/sh...&postcount=232 Startup: Check out this discussion as well.. There may be some other options: https://g05.bimmerpost.com/forums/sh....php?t=1714383
Bill
2019 Range Rover Velar - Retired 2020 X5 40i - Retired 2023 X6 M50i - Race Chip GTS Black 2024 Porsche Macan S |
j_LaSalle_561315.50 |
08-12-2023, 01:05 PM | #19 |
Rep 821
08-20-2023, 03:12 AM | #20 |
11
Rep 35
Drives: 2022 BMW X5 M50i
Hey man do you have any pictures of your exhaust setup? Did you pretty much do what hufington did and add the 2 single resonators in place of the muffler? Thanks!
08-20-2023, 11:46 AM | #21 |
Rep 125
08-20-2023, 03:49 PM | #22 |
11
Rep 35
I definitely think that sound so far is the cleanest. Not a huge fan of just the resonator delete/x pipe install. Haven’t heard it in person, but through video just seems to raspy. I guess I could always start there and then add the rear setup later. Do you get a lot of cracks and pops when revving? Also, what brand did you go with for the resonators? Vibrant?
