05-26-2021, 03:55 AM | #1 |
Rep 18
Wheel spacers
Hi Guys,
M5 F90 with 20" wheels. Which thickness of spacers should I use on front and back? Links to purchase would be much appreciated. |
05-26-2021, 04:16 AM | #3 |
Rep 18
Thanks a lot for the advice.
I was under the impression that the wider would be at the rear, is this not the case? My RS6 had 15 at rear and 10 on the front I think... |
05-26-2021, 07:03 AM | #4 |
Rep 118
No, 12mm rear is the biggest you can go, otherwise the wheel will stick out about 3mm from the arch on 15mm. 15mm on the front is fine and will match the rear perfectly. It's the most common fitment, some people actually go 10mm on the rear, but 12mm is fine.
05-27-2021, 04:38 AM | #5 | |
Rep 279
05-27-2021, 08:25 AM | #6 | |
13070
Rep 18,773
aerospace100 , PM me if you want a quote. I have done many of F90 M5 in different configuration.
05-27-2021, 08:56 AM | #7 | |
162
Rep 329
I had an rs6 allocation until the dealer screwed me so I got back into an m5. But the rs6 itch is definitely still there. |
05-27-2021, 02:31 PM | #8 | |
Rep 18
Audi had awful finance deals and the Vorsprung was the only model I would consider after my time in the C7 PE. BMW on the other hand had better APR and because I had never owned one before I thought f*** it, variety is the spice of life. The M5 is a beast, but the RS6 is the best car I have ever driven for pure enjoyment. |
05-27-2021, 02:51 PM | #9 | ||
162
Rep 329
The lease rate difference was a major factor in going with the m5 comp as well. Pricing out an rs6 in the US based on msrp would have been $1900 give or take vs $1340 with nearly the same msrp. But I am still looking at the rs6 hopefully in the near future. |
05-27-2021, 03:16 PM | #10 | |
Rep 18
Over here the M5 was $700 cheaper p/m and yet over $10k more expensive on the book price than the RS6, for the spec I opted for. I just hope I enjoy it, the M5 has RS6 sized boots to fill... And they are big boots |
05-27-2021, 03:57 PM | #11 | ||
162
Rep 329
I'm sure you have checked out most videos but here's one comparing the two. There's another member here also from the UK I believe who had the m5 but had to trade it in for an rs6 to accommodate a family. I'm sure if you search around you will see his post. Good luck and let us know what you think. |
05-27-2021, 04:34 PM | #12 | ||
Rep 5,236
Amazing customer service from Ben!!
CURRENT: 22' INDIVIDUAL M5| CHALK | TARTUFO | CCB | MPE | H&R | IND
GONE: 19' M5C| SINGAPORE GREY| ARAGON|VELOS VLS-06|H&R|iPE|IND|XPEL|CF|RADENSO GONE: 15' F10 M5|BSM|BLACK|VELOS VSS-S2|KW|AKRA|IND|CF |ESCORT 360|VELOS PIGGY GONE: 13' F10 M5|SG|BLACK|AKRA|KW|IND LONG GONE: 09' E60 M5|02' E39 M5 |
r33_RGSport13070.00 JRod1980391.50 |
05-27-2021, 08:29 PM | #14 | |||
13070
Rep 18,773
05-27-2021, 08:30 PM | #15 | ||||
Rep 279
r33_RGSport13070.00 |
05-27-2021, 08:33 PM | #16 | |||||
13070
Rep 18,773
05-28-2021, 05:54 AM | #17 |
Rep 85
Drives: f90 M5, incoming M2
05-28-2021, 06:31 AM | #18 |
Rep 279
r33_RGSport13070.00 AnthonyOB36.00 |
05-28-2021, 10:30 PM | #19 |
Rep 85
nice. i used the MSS automotive set. really happy with ride and handling
06-11-2021, 12:26 PM | #20 |
36
Rep 40
06-12-2021, 05:38 AM | #21 | |
Rep 279
